dubsmith wrote:Loxx, you will definitely need to have your turbo rebalanced if you change out the turbine wheel. I had my K26/27 i built balanced at majestic turbo in texas. It was about two weeks door to door, and was $95 including shipping. Worth the peace of mind i think. Unless you'd like to see what what happens when the turbine grenades at 80,000rpm...
If the turbine and shaft are zero balanced and the compressor is zero balanced then the only unbalanced thing is the nut. If you want to do it just in case I bet most major cities have a local option (at a cost <$100).
I'd be most concerned with the wastegate's ability to keep the boost down and it would be pointless because it would spool so slow and make like no power at low boost.
