Marc's 95 S6 Avant (daily driver)
JShadzi wrote:Just to jump in here, there in no one in the country with more experience installing and supporting customers with these KKK/GT turbos. We've done at least 5 installs here in shop, and have supported and spoken with dozens and dozens of customers here in the states and worldwide during the install of these turbos.
While the physical positioning is slightly different than the original KKK housing, we've had no problems installing OEM, 2Bennett, our own 034 and other custom downpipes onto this turbine housing, the only modification that is required is the removal of the CV heat shield.
Marc expressed difficulty in making the Stromug system fit with this turbine housing, so it could be something specifically different about the Stromug system that causes fitment problems in this particular application.
However we want to be clear, we haven't seen this problem with other, "non-Stromug" downpipe applications as of yet. With that said, astromug specific fit would definitely be interesting.
HTH,
getting back to this thread WRT turbo fitment issues on the GT hot sides. It _is_ possible that I could have gained back some of the flange alignment by losening the turbo nuts and cheating the pipe over and down a mm or two. When I ran into the tie rod issue I gave up trying to fight the positioning problem since I knew I was going to have to reweld the downpipe anyway.
Appologies to Javad/034 Motorsport and Jeff/Stromung.
After playing around with boost control settings and talking with Nate, it looks like the stock WGFV basically gets overrun at this boost level hence the inability to regulate properly above 24ish psi.
I found a reasonably priced alternative that I'm going to try. The subaru guys seem to like this one:
http://www.perrinperformance.com/produc ... l/ebcs.htm
for $80, I figured it was worth a shot.
owdlvr
Post by owdlvr »
Marc,
Is this flex under static tension?
If so, it will fail much quicker.
-Dave
owdlvr wrote:Marc,
-Dave
read the thread dave :)
it isn't under static tension anymore.
owdlvr
Post by owdlvr »
I have been...but I must have missed it. Sorry ;)
-Dave
S4turbo
Post by S4turbo »
Hm, what spring are you using, what is the boost with the WGFV disconnected?
I guess there are limits to the standard motronic system also if you don't change to a stiffer spring when looking for high boost.
And one more question, where do you put your IIC ECU, where the motronic box was or in a different location?
S4turbo wrote:Hm, what spring are you using, what is the boost with the WGFV disconnected?
aftermarket stiff spring, boost is about 10psi with WGFV disconnected.
I think the issue is that the stock valve is wide open and cannot smoothly regulate a constant pressure above that level. Hopefully the new valve will cure this.
close to stock location, I hung it against the HVAC duct but I'm going to re-locate it to the factory motronic location, minus the stock mounting tray as the 034 ecu is a bit bigger.
I also need to update this post with regard to the cam position sensor. More shortly on this.
A quick note on the factory cam position sensor wiring.
The factory ties the power for the CPS in with the TPS and the baro sensor, which doesn't work well with 034 since it expects a 3.3v supply to the TPS. I ignored the issue since the car runs very well in wasted spark mode.
For ha-ha's I decided to try and get the CPS working and made a few wiring changes to make this happen. I stole a pin from the un-used factory IAT wiring to supply 5v from the hall VCC output on 034 to the CPS. After I did that I was able to read a nice smooth signal from the CPS. At the same time I also connected the wire I had left previously disconnected for the CPS signal wire.
Under normal driving the car runs great but as soon as I reach peak boost of around 24psi the cam position signal goes wacky and the car bucks hard as a result.
Looking at the wiring, the ground for the CPS is also tied in with a bunch of other stuff, so I suspect the only way to cure this problem would be to find yet one more spare pin to run a direct ground from the hall ground on the 034 directly to the CPS.
Frankly I dont think I'm going to bother with the CPS any further at this point. I just wanted to point this out for those looking to follow my path with the harness adapter. I'll also update the wiring diagram to remove the provisions for the CPS and provide a note on how to use it for those not wanting to run wasted spark.
Another wiring update
I've been chasing a problem where on occasion my coolant would shoot to the maximum value (114C) and my TPS would read 100%. This happened seemingly at random and I was figuring I had a short in my wiring some place.
The culprit? Do not wire pin 41 of the ecu to pin 3. I was attempting to use this as a trigger into the AUX in on the ecu to rig up an idle up as pin 41 on the motronic is a signal from the climate control system of some kind to tell the ecu to raise the idle. Well, the issue is that channel is expecting a resistance value so what was happening is +12v was being supplied by the climate control on this line and playing all sorts of havoc to the sensors running off the common voltage supply.
I cut this line and all is well again. I have updated my wiring diagram accordingly.
Next update, RE: boost control. The perrin boost controller does work better than the factory valve, although I still wasn't able to get 28 psi consistantly with any of the settings available to me. me and my father have been driving up and down 95 trying pretty much every combination of values until we settled on some settings that came close.
Right now the controller comes up to 25 psi and gradually rises into an overboost condition. To solve the overboost condition I rigged a manual controller in parallel with the electronic controller and now I've got it set pretty much perfectly, boost comes on smooth to 28psi and stays there. Good enough for me, and in time for NHIS :)
3bAudios
Post by 3bAudios »
sounds awsome marc, which day are you going to NHIS? im planning on swinging by to say hi to you and Hayden, just dont know which day yet.
3bAudios wrote:sounds awsome marc, which day are you going to NHIS? im planning on swinging by to say hi to you and Hayden, just dont know which day yet.
october 25th and 26th (Wednesday and Thursday)
HT Motorsport
Post by HT Motorsport »
This weekend at NHIS was AWESOME! I placed 3rd in ST3 with a 1:23.7 something, a personal best for me on that config and only .5 off the track record for my class.
Also met a few more Audi people :)
See you all on Wed.
H
timmmy wrote:This weekend at NHIS was AWESOME! I placed 3rd in ST3 with a 1:23.7 something, a personal best for me on that config and only .5 off the track record for my class.
See you all on Wed.
H
:woowoo:
Good job Haydn!
If you wind up in my run group, I'll check my mirrors often ;)
newt wrote:Did you ever experiment with just static duty cycles on that GPO for the boost controller?
No, I didn't. back out for testing today perhaps then? ;)
S4turbo
Post by S4turbo »
So when you are using wasted spark, there is no need for the cranc pully combo?
I have an early AAN, where the hall sensor (?) is in the "dizzy" box or what you call the distributor position used in the 3B. Are there any differences in how the IIc should be connected to this engine compared to the later AAN engines?
Regards, Johan
a4kquattro wrote:
S4turbo wrote:Marc, just wandered what you needed of bits and pieces for the conversion to 034 management. Does this list cover it:
IIC ECU
Crank pully combo (034)
1,8 T temp sensor (034)
VR extension cable
Cables for connecting the IIC to the Motronic harness
JPT55 connector
Epoxy for filling the connector
Did I miss any important sensors or items that would be nice/necessary to have?
034 flying lead harness (which is usally included with the ECU)
Have you lost any features from the original car from the IIC upgrade? I konw knock sensors are not in use, bur what about AC, instrument cluster?
I dont get an 'idle up' when the AC is on so it idles a little rough running the air conditioning but thats about it. instrument cluster still works, etc.
Twin Staged
Post by Twin Staged »
a4kquattro wrote:After playing around with boost control settings and talking with Nate, it looks like the stock WGFV basically gets overrun at this boost level hence the inability to regulate properly above 24ish psi.
Just so you know that's just a 3 way valve that grainger sells for like 30 bucks. http://www.grainger.com/Grainger/wwg/it ... 1612667260 I use them all the time. I can prolly find them even cheaper then that as well.
Twin Staged
http://www.grainger.com/Grainger/wwg/it ... 1612667346
A little bigger one
Twin Staged wrote:[/quote]
A little bigger one[/quote]
yah, I figured there might be an industrial application.
That one is a 4 port, so I think your first link is probably the closest match.
I hate it when working on my car doesn't result in it going any faster :-P
Had to R&R the front CV on the driveshaft as it has been making a hell of a racket for the past few months.. poor thing was pretty cooked
I tried hammering the old CV off and it was a no-go. A 20 ton press is one of those tools you very rarely use, but when you need it, very nice to have ;)
I had to raise it up a bit in order to get enough clearance to press off the CV, but it worked like a champ
new bearing installed
I also happened to have a few of those cork style CV seals that have been sitting in a box for the last 3 years, figured I might as well actually use them :-o
back from dynoing at EPL, results for the S6 w/3071
all numbers on a mustang dyno, NO correction factors:
331 hp
336 ft/lbs torque
all this at only 25 psi of peak boost, which stays all the way to redline.
With the aid of Tony's dyno tuning expertise I gained 30hp and as much torque from the torque peak all the way to redline from my tuning settings when I pulled in to the last run of the day. Not too shabby ;)
pics/vid/etc tomorrow.
JShadzi
Post by JShadzi »
Nice Marc, very respectable! Now push that turbo to 35psi, she'll do it :D
Derracuda
Post by Derracuda »
nice! 8)
JShadzi
Post by JShadzi »
Oh yea, looking forward to seeing the dyno sheet :thumbsup:
ok, time for the full writeup on my first dyno tuning session with the S6 at EPL yesterday.
I'll jump right to 'the good stuff'.
Here's the final dyno chart from my car:
details:
331 uncorrected whp
336 uncorrected lb/ft tq
The funny thing about the location of Tony's dyno (4 feet above sea level!) is that it actually gave us a correction factor LESS than 1, EG the corrected numbers are LOWER than the uncorrected numbers :-D (4.4 ft above sea level, 69.8 degrees F, 29.7 in/hg, 54.3% humidity = ~.987 correction factor)
and to add to the uber geek data in this post, the dyno graphs produced are using a 30 smoothness setting (out of a range of 1 to 100)
Here's a graphical output of the logging data from the ECU. Click the pic for multiple separated graphs
I like this one better, shows just how much you can gain by dialing in ignition timing (without the feedback from the dyno this is tough to do on the street). Note the decent gain in power ALL the way across the powerband :woowoo:
:vids: of the final pull
http://www.theswansonfamily.us/modules/ ... l.wmv.html
:vids: showing engine movement during pull. Not bad, but it might be time for some stiffer drivetrain mounts
http://www.theswansonfamily.us/modules/ ... p.wmv.html
:vids: of the whole day (dialup = teh no, ~19 minutes of video, 76MB)
http://www.theswansonfamily.us/modules/ ... y.wmv.html
:pics: from the day
arriving on the scene, I even beat tony to the shop 8-)
sam's car rolling on
regapping teh plugs
Adam arrived next with his new whip. Its not green :-o
it rained a bit and it seems he's got a few leaks...
Nick joining the festivities
My rig on teh rollers
because you never CAN have too many laptops :-P
Tony gathering up the data I knew I'd be hounded for later ;)
Nick, face it, you dont stand a chance at a mustang dyno log rolling contest against 'the man'. He's got far more experience ;)
I got a good laugh when I made a pit stop in the restroom, gotta love Tony's taste in reading material
in case you're wondering what the hell that beeping is in the video, seems we were running a little high on CO. Definitely some good stuff floating in the air with open crankcase breathers on sams car. Pretty sure I caught a buzz for a while :tard:
Oh, and I bought another //S car (because one is just never enough :tard:). Seller brought it up to the dyno day for my Pop to drive home on the way back. I'm pretty psyched, its nicer than I expected 8-)
rest' of the photos are here: http://www.theswansonfamily.us/modules/ ... yno_1_5_07
Big :thanks: to Tony at EPL for his dyno tuning expertize and Adam and Nick for coming along for the festivites. Stay tuned for the next session, Brian is planning on tuning his S6 in the next few weeks.
***EDIT by Tox***
Toxcheap
Post by Toxcheap »
Video links work now :wink:
your welcome Marc :P
