Pops' 1997 S6 - 07k BLK WDW
Re: Pops' 1997 S6 2.5L Stroker - 465whp/430wtq
Post by ChrisAudi80 »
Was that on Vortex, by chance?
Mushasho!
Post by Mushasho! »
ChrisAudi80 wrote:Was that on Vortex, by chance?
wouldn't surprise me if it was...
I think probably more like s2forum. Drama is taking a hold of that place from what I can tell.
Just found an interesting little clip on teh interwebs:
Link to video
2.5L stroker with CT4-64 turbo. Not sure if billet or not. But by the looks of it making 620whp on 26psi! Also note that it hits 26psi by about 5000rpm, not ~4000.
Well, YEAH, your car is capable of a lot more... tell us something we didn't know? 8)
LOL
I think when we hit the dyno again we should be shooting for 30+ psi and 500+whp. Looks like his car is using a stock intake with the guides still in it too.
Mushasho!
Post by Mushasho! »
Is he on solid lifters?(aka...mechanical) if soo he only pushed it to 7k on the dyno...
Mushasho! wrote:Is he on solid lifters?(aka...mechanical) if soo he only pushed it to 7k on the dyno...
Why would he be on solid lifters? Would be pointless on a stroker that shouldn't rev much past 7,500 anyways.
chaloux wrote:LOL
Nice...too bad you can't make it to Carlisle, there may be a dyno sesh if Marc can bring the dyno down. You guys getting back on the rollers before that?
Mushasho!
Post by Mushasho! »
I was asking in case "mechanical" meant something else... here's his specs
"It was dynod on the wheels so bhp is almost 760hp and 900nm on 1.8bars. Autronic SM4 1.09 Engine management The engine is a Diesel block + stroked bored up to 81.5mm JP pistons thermal barrier crown coating H rods 158mm, cp-service exhaust old/ new KRB exhaust on the way. 034 Billet Motorsport Clutch Package Specially maid cams mechanical lifters titanium retainers bigger valves ported head ARP studs all around in the block Synapse waistgate"
Would be weird to have a stock intake mani with a ported head... something doesn't add up.
bradyzq
Post by bradyzq »
Nah, none of the above.
It was actually on the usually very good hybridz.org!
Mushasho!
Post by Mushasho! »
EDIGREG wrote:Why would he be on solid lifters? Would be pointless on a stroker that shouldn't rev much past 7,500 anyways.
loxxrider wrote:Would be weird to have a stock intake mani with a ported head... something doesn't add up.
I agree, many things aren't adding up
Mushasho! wrote:I was asking in case "mechanical" meant something else... here's his specs
Oh, didn't see those specs... in THAT case it's even more bad ass. Tall block stroker (AAT diesel block) can still rev...mmm. Yes mechanical lifters = solid lifters.
bradyzq
Post by bradyzq »
At 100% perfect world efficiencies everywhere, a 2.5L engine making 26psi at 6800RPM at 0.50 BSFC and 12.5:1 AFR will make somewhere in the neighbourhood of 600HP AT THE CRANK!
We're missing some info here....
bradyzq
Post by bradyzq »
In the lower left of the screen during the dyno pull, there is a 100.4C temperature. If that is used as ambient temperature for SAE or DIN correction, numbers could go through the roof!
It might be being used to measure some temp other than ambient, in which case hopefully the dyno knows that and does not try to use that number in its correction factor.
bradyzq wrote:At 100% perfect world efficiencies everywhere, a 2.5L engine making 26psi at 6800RPM at 0.50 BSFC and 12.5:1 AFR will make somewhere in the neighbourhood of 600HP AT THE CRANK!
Is'tn that close to what dad's is making - around 550-600 depending on conversion factor?
bradyzq
Post by bradyzq »
Yup!
Audi_CQ
Post by Audi_CQ »
Why would it be pointless? There's more to it then just rpm's. You can run much more agressive profiles with solid lifters and that helps.
Audi_CQ wrote:Why would it be pointless? There's more to it then just rpm's. You can run much more agressive profiles with solid lifters and that helps.
True, the ramp rate of the lobe can be more aggressive with solid lifters, but you don't often see solid lifters in an AAN for any other purpose than to support higher RPMs. That is probably at least partially due to the potential for increased stress/maintenance in addition to negligible performance gains for the cost.
Jamo
Post by Jamo »
chaloux wrote:Just found an interesting little clip on teh interwebs:
Link to video
Thats on the KRB dyno aka comp europe. Kai says on his dyno that that spool you see on the graph is not the same as road spool as it's not resistance loading so they don't match.
I would send an email to Kai at krb over your turbo and setup and ask for advice as he knows his stuff, maps cars, and has a 1000 whp Audi running a comp turbo
Certainly helped me with my comp turbo choice and other tips
bradyzq
Post by bradyzq »
That's a Dynapack, and it is DEFINITELY a loading dyno.
Of course it won't match evrerywhere on the road. 1st, 2nd, 3rd, 4th, 5th, 6th gear? Uphill, downhill? Headwind, tailwind? Full car, or driver only?
If you load it hard enough on the dyno, and have enough airflow, you _should_ approximate road spool in the upper gears.
Urs4 up north
Post by Urs4 up north »
Hi there :) My Name is Patric and after reading all the interest and misconception surrounding my engine I want to clear up a few things.
Attachment:[/quote]
[/quote]
Link to video
A video of the car driving with 1.5bars of boost. My friend laughing.
X) When the video was shoot we were running it on E85 so "0.50 BSFC and 12.5:1 AFR will make somewhere in the neighbourhood of 600HP AT THE CRANK!" is not quite accurate.
X) The engine is maid to handle 1000hp, and several of my friends haw a lot more the me. The only difference is the turbo size on the same setup.
x) 100.4c Thats the water temp down to the left if I`m not mistaking.
x) I just to have a race intake from Furans (http://furans.se/intake_swe.htm" onclick="window.open(this.href);return false;) but to satisfy the Norwegian government I fitted a original. It will also be match ported to the head.
x) The engine is maid to rev to past 8000rpm even thou I`m not doing it on the video. Every thing in this engine has bed balanced for high rpm`s. The turbo didnt have anything more to give at that boost so dropt it at 7000.
x) The cams has a 280' duration 11mm lift and 112 LSA
x) Her is a list of similar engines and friends from Norway.
1100hp s4
http://www.finn.no/finn/car/used/object ... e=33068655" onclick="window.open(this.href);return false; ... e=33068655
http://forum.vwaudi-club.no/showthread.php?t=221349" onclick="window.open(this.href);return false;
http://forum.vwaudi-club.no/showthread.php?t=95645" onclick="window.open(this.href);return false;
I hope that clears up some of the questions regarding my ride and I do like what you guys have don to your cars. Keep up the god work.
BTW, that quick spool vale was interesting, hows the restriction at the top end? And can it handle launch control starts?
Jamo
Post by Jamo »
Text translation is a bit rubbish but does it say that you get spool between 4000-4500 in that thread?
Urs4 up north
It starts to spool at +4000 and takes of after 4500.
Ps, The compression ratio is 9.1:1 for more drive ability and torque.
