Darin's 80q…Alive...
Re: Darin's 80tq...slowly...
Looks great Darin
quattro87
Post by quattro87 »
:woowoo: Looks way good Darin!
Hot dog that looks great. Keep up the momentum Darin. Did the exhaust hook up? What's the hangup with the linkage ?
ShavedQuattro wrote:Hot dog that looks great. Keep up the momentum Darin. Did the exhaust hook up? What's the hangup with the linkage ?
The exhaust matched up nicely. I still want to add a brace to it. The linkage is now too far turned the other way, which is my fault since I marked it when the tranny mount was bent.
Dave
Post by Dave »
keep up the progress!
savagerocco
Post by savagerocco »
You're making progress Darin, the bolts and brackets will come to you..... if not, us crazy utahn's are only a phone call away... I won't be touching my coupe until I finish an LS2 swap into a miata for a customer, which reminds me, I should be working on wiring not surfing the web....
Re: Darin's 80tq...Wednesday 8/1...
I have a floating holiday and am taking this Wednesday 8/1 off. Dave (Hatch) is arriving at about 12:30. Anyone else is welcome to come lend a hand! I need the crank locking tool that I hear Nick or Chris has and will be happy to come get it. The plan is to get it all done.
Must get motivated and get this done!!
Good luck man!!! :) Your going to beat me! Grrr
GOod luck Darin!! Keep progress coming. Projects suck at time, but they are awesome once completed!! 30psi on that turbo will be a blast!!
Looks great Darin. I am on the Dave Hord 1hr per night routine trying to get it back together. It's painfully slow, but will be worth it.
nsimps
Post by nsimps »
Keep going Darin! Wish I could come help :) are we caravanning again this year to BBQ?
Wheeljack
Post by Wheeljack »
You're welcome to borrow the crank pulley tools. Pm me.
http://brydon-eng.com
Dave
Post by Dave »
I hope you have a plan and a direction, I'll be there to help not babysit :P
Hybrid_Hatch wrote:I hope you have a plan and a direction, I'll be there to help not babysit :P
I plan on working you to death. :D
quattro87
Post by quattro87 »
Good work Darin! Couple of days and be done sounds great. Sounds like you might as well come up to pikes peak then.
80qtdi
Post by 80qtdi »
I'm pretty useless right now, but it would be fun to meet up with some of the locals.
Re: Darin's 80tq...MOTIVATED...
Took the day off today and with Dave's help, a lot of progress was made. Thanks Dave for spending half your day with me in my garage. Too bad you aren't very good at finding bolts. :wink:
We actually might have made more progress if all my bolts I've ever accumulated from 4 different cars wasn't spread all over my garage floor. Oh, and if I had taken some pictures of how the A/C compressor went back on. We solved the puzzle, but it took us a little bit of trial and error...and time.
The "To Do"
Engine ground
Wiring the two transmission sensors
Getting all the turbo lines sorted
One or two more hoses for the radiator and firewall
Intercooler and plumbing
double and triple check everything
add fluids
bleed brakes
...and solve the 01E puzzle.
AC, lol
savagerocco
audifreakjim wrote:AC, lol
It gets hot up here mister..... I'll be cool in my car while you are baking in yours at battle born....... Death valley is way wicked hot....
quattro87
Post by quattro87 »
:stupid: Why do you think they call it "Death Valley" ? I wish the air in the Urq was a bit better, but on the road it definetly helps. I'm with you Darin, on keeping A/C.
jsimps
Post by jsimps »
I believe it is time for me to rise up and keep track of bolts during these builds.
pkw
Post by pkw »
Darin,
what intake runners were used to make that intake?
what ps pump is that?
did you reroute ps lines?
car looks great
I live in Michigan and refuse to give up AC :D
savagerocco
Think it was an aan cut and tanked by hank that is a 20v pump like off a 4k motor with some spacer bars to move it out farther
That is actually a 3b. I have 6 more on the shelf waiting to be cut up :) The AAN runners move too far out to put a plenum on and get the radiator to fit.
Dave
Post by Dave »
savagerocco wrote:Think it was an aan cut and tanked by hank that is a 20v pump like off a 4k motor with some spacer bars to move it out farther
i believe the pump is "original" to the car meaning from the 20v that the 80 had from the factory, and yes it has custom spacer brackets to put it in the right position.
