Audi 90 quattro with 2.5 TDI and 6-speed, plan B
steftn
Re: B4 90 quattro with 2.5 TDI running better and better!!
Post by steftn »
ralleyquattro wrote:I still have the electrical pump, but I have an H connection just before the main filter to reduce the pressure.
Do you use the original petrol pump? Or a diesel-pump?
PRA4WX
Post by PRA4WX »
I was going to ask for pictures of how and what you did for this. I've planned on using the intank and stepping down pressure, the H option sure would be cheaper than a pressure regulator. So, Martin, got any pics/advise/info? :D
steftn
Re: B4 90 quattro with 2.5 TDI = 1200km (745mi) to a tank!
Post by steftn »
I think, the H-option is one of the best solutions if you use an b4quattro tank.
I think, a pressure regulator wouldn't be a good idea, because you shouldn't have excess pressure on your diesel pump.
If you have excess pressure on your diesel pump, the injection timing wouldn't be correct (because the injection-timing of the diesel-pump is pressure-controlled)
see also:
http://www.dieselbookmarks.com/bombers/VEPump.pdf" onclick="window.open(this.href);return false;
Lord_Verminaard
Post by Lord_Verminaard »
Shouldn't need to worry about that, the timing is controlled by internal pump pressure- that is fuel pressure after the high-pressure internal vane pump. Pressure on the front side of the high pressure pump will not hurt anything other than increasing the chance of leaks. Only in situations where fuel delivery has been highly modified will internal pump pressure begin to decline, and in that instance, a lot of pressure and volume on the front side of the pump will help bring timing and therefore internal pressure back up.
Brendan
2005 New Beetle TDI
2002 Jetta Wagon 1.8t Tiptronic to manual swap (Wife's car and kid hauler)
1981 Scirocco S'...
1976 KZ400
ralleyquattro
Post by ralleyquattro »
Yep, running the stock gasoline pump, but removed the stock gasoline filter (PITA)
This is not mine but you get the idea, connection between supply and return, just before the diesel filter.
Drops the pressure and allows excess to return to the tank.
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
steftn
Post by steftn »
User "Toby" asked me something about the gear-linkage:
this is the gearbox i bought:
http://cgi.ebay.de/VW-Audi-a4-a6-Quattr ... 3923243234" onclick="window.open(this.href);return false; ... 3923243234
I paid 150 Euro for the gearbox, rear diff and gear-linkage (it was a good price).
i don't know if it was a6 or a4 quattro.
the owner said, that it was from a4 quattro.
Ok, i mounted this system in my audi 80 B4 Quattro, like you can see it in that picture (I only built own gearbox-holders or you can use RS2 things... / And I also used shorted front-flanges from my old CBR-gearbox (some 016 and 01A-gearbox-flanges also fits):
Attachment:[/quote]
[/quote]
And this things you have to do if you use A4/A6 switching-gate (klick for zoom):
Attachment:[/quote]
[/quote] (I searched this picture at google, because i haven't made pictures of my gearbox-project)
If you want to buy a A4/A6 switching-gate, please look for that, there are 2 different systems (klick for zoom):Attachment:[/quote]
Attention: Only 6-gear switching-gates fits (from 01E gearbox, like DQT, CYT, Audi RS2-Gearbox etc)!
like this one: http://www.ebay.de/itm/220867626147?ssP ... 1435.l2649" onclick="window.open(this.href);return false; ... 1435.l2649
http://www.ebay.de/itm/Audi-RS2-S2-Scha ... 0655837354" onclick="window.open(this.href);return false; ... 0655837354 <---- hahahahahhahaha :lol: :lol: :lol:
lagas
Post by lagas »
hello :) nice project done ;) my project only starts :) My audi b4 q stay in garage 1.5 year and now wen I have what i need to work start ;) i have 2.5 TDI AAT from 1996 audi A6. 6 gang gearbox CYT. In future plans i want put 1,9 tdi engine managment system and 3.0 bmw turbo with VNT.
One question can i use audi A6 1996 2.5 TDI AEL 6-gear-switching-gate to my B4 2.8?
steftn
Post by steftn »
lagas wrote:One question can i use audi A6 1996 2.5 TDI AEL 6-gear-switching-gate to my B4 2.8?
only when you use the 01E-gearbox, and see my last message, there are two different shift-linkages...
If you have 01A-gearbox, it wouldn't fit with the original 6-gear-shift-linkage...
The B4 2.8 has 01A-Gearbox
RS2/TDI-6-gear-gearbox are 01E-Gearbox
lagas wrote: In future plans i want put 1,9 tdi engine managment system and 3.0 bmw turbo with VNT.
if you use 1,9 tdi, you needn't weld engine-holders on your car.
You need only the 4-cylinder-quattro-subframe. So its much easier to put an 4-cylinder tdi in audi b2/b3/b4...
thats my cousin's Audi 80 B3 Quattro 1,9TDI:
lagas
Post by lagas »
i correct little bit i put 1,9 ECU to 2.5 TDI engine to control VNT turbo it is for future plans only ;)
I have CYT 6 gang gearbox taken from 1996 2.5 A6/c4 (if i not mistake CYT is 01E-gearbox) and this car (a6) have linkage i want buy it. If I correctly understand this linkage I can use to replace my old linkage from B4 01A-gerbox
Attachment:[/quote] File comment: CYT gear linkage 1996 2.5
[/quote]
ohh... now I see what i need gear linkage from never audi a6 or a4 ( 05.99 4B-X-130 001 > )
steftn
Post by steftn »
But you can also use the 5-gear-gearbox from Audi A4 1,9 TDI Quattro (or VW passat TDI....1996-2000), the code is DGW, it's a 01A-Type (the box is the same like the gasoline-gearbox) and fits plug&play in the Audi ! So you don't need special gearbox-holders, linkage etc.... It fits plug&play !!!! That would be the easiest thing! (but I think the drive flange are different, like the DQT/CYT, so you have to change that, but that would be no problem). And you also have to check that it fits with your rear-diff.
Here you can find gear-ratio-dates:
http://www.dieselschrauber.de/GKB.html" onclick="window.open(this.href);return false;
here a picture of the DGW-gearbox:
lagas
Post by lagas »
Good info my friend. But i have 6 gear CYT gearbox :) only left find linkage :) i found one from a6 allroud 2.5 v6. (~200$)
ralleyquattro
Not much of an update, however, happy to say the RS2 lights are here.
Couple of the tabs broke during shipping, but nothing some epoxy could not fix... here they are in all their glory.
I also got some bilstein shocks to install, front will be complemented with UrS HDs using Mance BBKs and Coupe Q springs.
Rear just a set of A4 Sport shocks. Will see if the weather holds up and I can do that before Christmas.
Martin Pajak
91 Coupe Quattro
blacksmith
Post by blacksmith »
Your car looks damn good
ralleyquattro
Thank you
Martin Pajak
91 Coupe Quattro
Acidburn
Post by Acidburn »
Just sat and read thru this from start to finish, i'm tempted to do this to a s2 avant i'm picking up soon, would make a good conversion so will see.
steftn
Post by steftn »
In Germany, someone put an 1T in an Audi V8 D11:
http://cgi.ebay.de/Audi-V8-D11-Quattro- ... dZViewItem" onclick="window.open(this.href);return false; ... dZViewItem
and this guy:
http://www.motor-talk.de/bilder/audi-v8 ... 95362.html" onclick="window.open(this.href);return false; ... 95362.html
ralleyquattro
Acidburn wrote:Just sat and read thru this from start to finish, i'm tempted to do this to a s2 avant i'm picking up soon, would make a good conversion so will see.
I am actually looking for S2 Avant already to do the same thing :D
My original idea was to find a nice A6 2.5 quattro avant to import, but I find those cars a bit too big for my liking.
S2 would be perfect.
I guess turning an RS2 into a diesel would be sacrilege. :slap:
Martin Pajak
91 Coupe Quattro
Acidburn
Post by Acidburn »
In the states or getting one from the uk and importing it (not sure if you can yet)
Getting cheap over here. Just gotta decide do I want to do this or carry on with other projects, my urq still needs finishing :(
ralleyquattro
Acidburn wrote:In the states or getting one from the uk and importing it (not sure if you can yet)
I'm in Canada so anything 15 years or older is game :wink:
Looking for LHD so mainland Europe.
Martin Pajak
91 Coupe Quattro
Acidburn
Post by Acidburn »
ah ok not too bad then. There is a lhd 2.8 cq on ebay currently in the uk I noticed it the other day, there was one 20v lhd avant quattro in the uk on s2forum but not sure what happened to that.
ralleyquattro
The B4 quattro avant with 2.3E motor is a rare beast in Europe, most are either 4 or 6 cylinders.
Martin Pajak
91 Coupe Quattro
Acidburn
Post by Acidburn »
Yeah i've not come across one in person before...
oliwer78
Post by oliwer78 »
swietny project Marcin!
LHD S2 Avant still keep their prices unless they're already in the shape not worthy to ship it overseas, let alone RS2.
2.3E is the way to go for you if TDI 5L is your desire. There are some nice 1.9TDI builds out there, did you consieder 4cyl?
I am still C4 chassis lover but everything Audi Avant always gets my attention, especially S2.
ralleyquattro
Sorry, I am not a 4 cyl kind of guy.. ;)
I have my "men on the ground" looking at this one..
http://otomoto.pl/audi-80-quattro-C22244698.html" onclick="window.open(this.href);return false;
Being a 5 cyl it will be a perfect car for the next swap.
Martin Pajak
91 Coupe Quattro
ktownboostn
Post by ktownboostn »
How much fun is the TDi in the snow !?!?!?!?!
