Re: Jim Green's 90q 20vt - The quest for 275's
I knew you had it in you, Jimmer. Ready to start an auto collision center?! ;-)
Jim, you'll have to teach Hank how to weld body panels.
I'd like to get some b4 rears and run 245s on the 17x8s I have. That's enough for me.
I have a set of b4 rears
for you if you want
uh oh. You might have to bring those along with Hank's fender roller.audifreakjim wrote:I have a set of b4 rearsfor you if you want
84urq20v
looks awesome Jim - very nice. Really like those wheels, too (double six spokers - whatever they are)
Quattro v1.0
Way to go Jimmy. I can't wait to see it!
Ok geekers, do I finish this in steel or epoxy fiberglass? Leaning heavily towards glass..
Attachment ( 27607 ) : ImageUploadedByTapatalk1315159637.332318.jpg
red90q
my vote for glass. My rear inner had rotted out. Used fiberglass to fix it. Did small areas at a time allowing to dry in between.
HT Motorsport
steel with seam sealer
bimmerboy
Is the quarter panel still welded to the wheel well?
- ringbearer
Steel. Are you doing this with MIG or TIG?
pkw
that is tits. i prefer steel and seam sealer but considering where you live glass may work okay.
Looking really great Jim!!!!
Mig in spot welds, or really small sections at once.
I am going to do it metal, just made some patterns and test fit the first piece and I can do each side in two pieces. I was concerned about taking the time to weld it and seal it, but sufficient tacks, seam sealer then undercoating will get the job done.
VWAudi4Life
It's going to be beautiful! Nice work, Jim
- ringbearer
Metal should help you sleep at night, keep it cool like you did on the outside and it should look great.
3M panel bond may be another good sealer/reinforcement.
Damn, this looks unbelievable!! Great job Jim...that will be fantastic when finished.
The good news is the power is back on, the bad news is it completely foiled my plan tonight! Must have power for welders and air compressors..
Just when I thought I'd heard all the excuses....audifreakjim wrote:The good news is the power is back on, the bad news is it completely foiled my plan tonight! Must have power for welders and air compressors..
Quattro v1.0
I would tack it and then seam seal it rather than 'glass - that is - unless you already did 'glass ;o]audifreakjim wrote:Ok geekers, do I finish this in steel or epoxy fiberglass? Leaning heavily towards glass..
The rear fender liner is all patched in with more parts from the front urs fender and ready for 2k primer, then seam sealer. I was going to shoot the primer tonight, but the can needs to be tossed in a shaker. I spent 20 min stirring it then called it a night.
cuatrokoop
You don't need power lines when you have a big gen set. Just sayin'.
Your generator is probably bigger than my house
A generator in southern California?
cuatrokoop
Mine is only a 4kW, and it's got a cali engine on it
Not big enough to run a large compressor or welder, unfortunately. I do have plans on getting a 7-8kW and using my smaller set for the trailer.
