dets
cuatrokoop
JShadzi
Huh? Capped off on 20vt? You sure about that?cuatrokoop wrote:I just noticed that you are using the valve cover breather port. On the factory 20v/20vt that is actually just capped off, you using it since you deleted several of the other breather lines?
As you can see, I've found a need for lots of breathing out of the valve cover, a dash 6 and -10, -6 goes down to the block outlet, -10 straight to the breather can:
Attachment ( 3136 ) : 80tq_BreatherLines.jpg
WAUG0806
I think we determined that running 4KTQ20V without a breather at the top marked the beginning of the end for the turbo seals/bearings b/c oil flow stopped (reversed) when there was lots of boost and blowby causing pressure buildup in the sump and backing up the turbo oil return line to the sump.JShadzi wrote:Huh? Capped off on 20vt? You sure about that?cuatrokoop wrote:I just noticed that you are using the valve cover breather port. On the factory 20v/20vt that is actually just capped off, you using it since you deleted several of the other breather lines?
Interesting that you made doubly sure Javad... mine just goes from similar spot on camcover to the block outlet... or a tee between it and the 034 Vortex Seperator... was thinking you might locate a vent where the distributor used to be??
Wizard-of-OD
Speaking of this.Bill Davis (AuditunerB5) had just finished his 2.0 20V and was getting serious blow by.Fulled up his catch can with a quart of oil on the first roll.WAUG0806 wrote:I think we determined that running 4KTQ20V without a breather at the top marked the beginning of the end for the turbo seals/bearings b/c oil flow stopped (reversed) when there was lots of boost and blowby causing pressure buildup in the sump and backing up the turbo oil return line to the sump
10-AN from both the block & the valve cover >> vortex/swirl pot >> catch cun.
WAUG0806
I'd love to see what underhood temps run (say between AX runs) right up top, 12" down and as far down as possible in the engine compartment. parked after a hard run...
Can't help but think that the further down and forward you get your intake air the further you will be from heat soaking your IC on the next angry cycle.
If you've seen those goofy ricer air intakes that kind of look like an intercooler and mount below the bumper.... maybe not so stoopid on a real High boost hot-rod... looks dorky on a ratty civic but might be the "coolest" way to go...
Ginstercoupe
cuatrokoop
The 7A isn't even supposed to have the nipple, but some of the heads do, and it's capped. I had to go under the 3B slides to even find the part number for the rubber cap when it started leaking and caused a major warm/hot idle problem (car would stall). The AAN slide doesn't list even the nipple (on the 3B and 7A, it is actually removable) or a cap that I could see. Also looked at the vacuum system slides for the 3B, doesn't show anything connecting to the nipple on the valve cover.JShadzi wrote:Huh? Capped off on 20vt? You sure about that?
So.....?
