Looking good Jim. Is the #2 piston all the way to the top of the cylinder? Is the piston cut flush with the deck or does the edge of the piston rise out of the bore to head gasket plus quench heighth? Was your 13cc dish taking into consideration the valve reliefs? No matter, it looks close. Keep it going.
Nope, I just did a basic porting job on it by smoothing out the transitions. I didn't enlarge the ports at all since I don't have a flow bench to work with.
It seemed half the intake ports transitioned smooth into the bowl, the other half had some pretty good ridges in areas. I just smothed those out and removed any casting turds.
In the exhaust side it's easy to see the ridges that can be removed, smoothed out and polished.
My shop has a flow bench that can do 20v 5 cyl heads, but at this point I don't feel like paying $60 to see how it does since the bottom end work was a couple $$$ more than expected. Maybe next time.
The piston does stick up a little, slightly less than stock. Probably again because they expect these to be ran at higher rpms than stock. If I had a head that was bone stock I may be a little concerned about the CR of this motor. I know for a fact the head has been surfaced at least twice, so it's a little down on cc's so I'm happy with it. Hell, my goal is to boost the living crap out of it. :-D
For more comparison, here's a pic of Marc's NG block. Thanks Marc :wink:
dets
Hey Jim, this may seem a bit noobish, but can you tell me a bit more about that electric ps pump? First time i've seen one on this site and i'm curious to know if it performs the same as the stock one?
I'd love to get rid of more rotating mass off the crank if i could, i losing the ps pump would be a good way to do it.
TIA
Btw, its looks awesome. Just the short block alone looks
TIA
dets wrote:Hey Jim, this may seem a bit noobish, but can you tell me a bit more about that electric ps pump? First time i've seen one on this site and i'm curious to know if it performs the same as the stock one?
You need to reread Javad's project thread. He had used an electric pump as well. He comments on it's performance too.
olsonjus
Don't forget to add a breather to the 7A cam cover!
Done!
Where did you get that banjo fitting for the water manifold? That would be a nice on my 20v
Javad of course!
I finished all the turbo lines tonight. They all kick ass except for the WG signal. I have another one of those banjio fittings I'll probably use there, but I need to figure out where I'm headed with boost control first.
