I would rather buy a new set of brake pads :wink:
Post by ChrisAudi80 »
audifreakjim wrote:I would rather buy a new set of brake pads :wink:
True, you have to prioritize. :-)
You are switching to 5x112 all round, right?
With the power you are generating now, you need a brake upgrade.
The big brake kits at 034 look real tempting, don't they?
What brake set up are you running now? G60s?
Derracuda
Post by Derracuda »
he already has big brakes ;) check the link to his site in his sig..
Eeh, yeah, why didn't I do that yet? :slap:
Say Derek, have you moved to Germany yet?
90quattrocoupe
Post by 90quattrocoupe »
so which track event? Sears Point in Oct. or Buttonwillow in Nov?
Greg W.[/b]
Buttonwillow, unless you have another spot on that trailer of yours ;)
a_CQ
Post by a_CQ »
Good work Jimmy! so how is that clutch special? I only notice the PP being much different.
My clutch slave rubber line look scary old too, I've been meaning to replace it for quite some time..maybe I'll do that this month.
-Billet PP, smaller diameter and very light
-Very high quality disk, I cannot explain it, it is like comparing a 20v head to a 20v head. The disk is also smaller diameter for quicker revs
-LW Steel FW, will not melt under load, and has the trigger built in.
I need to call Porterfield and see if they have adapters in stock. They are my new favorite local race shop.
Porterfield didn't have exactly what I needed, so I just happened to have a meeting down the street from http://www.anplumbing.com :drool: every Earls fitting made, in stock, and then some.
So here is what I came up with for the Master to Slave clutch line.
http://www.motorgeek.com/phpBB2/gallery ... G_3076.JPG
Here is the problem with the adapters I bought, they were not deep enough and the threads were bottoming out.
The plan quickly moved to using a crush washer to seal.
S2 axles with new CV boots
Went back to the old Setrab oil cooler. After comparing to the monster Mercedes cooler I had been running, this one has more surface area and rows. I also relocated it from in front of the radiator to a much better location
Today's project: Tweak the exhaust in order to clear the axles. I built everything around the 016 which has the output shafts about 1.5" further back from the 01E and 01A
Man, I need to clean the underside of this car some day!
Derracuda
Post by Derracuda »
looks good Yimmy!
Longitudinal
Post by Longitudinal »
Do I read 9919BFEERL on the package for the fitting? One of those and the chrome-looking crushy thing at each end and hose in the middle. Anything else? I need to make almost the same hose for mine.
RSCoupe
Post by RSCoupe »
I ordered 95% of my AN stuff from anplumbing.com. I would love to see their actual store!
Mark Siggelkow
'90 CQ-R - NASA GTS-4
'12 TT-RS (Wife's DD)
'00 A4 1.8TQ (My DD)
'62 356B (vintage racer)
It is a great place to have somewhat local, that's for sure.
9919BFEERL is correct, but if I were to do it again, I would take the factory line out and have AN fittings brazed on the end. Also check out speeding-g60's thread, he found some -3 steel adapters that might work better.
To do it my way you need
2 - 9919BFEERL
2 - 12mmish crush washers
2 - -4 Speed Seal Hose ends
2 ft of -4 teflon speed seal hose
So I have the downpipe tacked into it's new location, now I just need to mate it to the exhaust. Done for today, plus I need some new exhaust hangers to work with.
FINALLY had the car out today. First drive was 100 yards down the street. Car moved, no strange noises so pull a U turn and 25 miles up to Long Beach. I took it easy as I could feel the clutch bedding and the engagement changing each shift. Once it was consistent, back in the hood, and with some fresh gas in the tank, it was time to have some fun.
Boy was it fun, I freaken love having torsen again, the car has sooooo much more grip than before. I tried a couple of pretty hard launches in first and just ripped through first and second with very little drama, and 1.9 bar / 28 psi of boost on the logger. :drool:
I forgot how fast this car was. Nothing like going 70 in second gear between lights... :-)
turboskipper
Post by turboskipper »
:woowoo: about time that car got some life back in it!
WAUG0806
Post by WAUG0806 »
8) The legend rides again.... :woowoo:
death 4kqt
Post by death 4kqt »
yes! The ultimate inspiration for other audi 90 owners lives again!!! I sure hope we get to see some video of it sometime :-D
Darin Claims that he is getting a ride this weekend....
Looks good Jimmy! I am jealous
TheArchitect
Post by TheArchitect »
OH-OH-OH, I want a ride!
I'm going to be in SoCal this week if you happen to be driving the beast in the North L.A. area.
I think I'm going to make a documentary. I really can't wait!!
death 4kqt
Audilard wrote:I think I'm going to make a documentary. I really can't wait!!
please do! for the sake of us east-coasters who have little to no chance of seeing this monster in person. :D
SEStone
Post by SEStone »
audifreakjim wrote:FINALLY had the car out today. First drive was 100 yards down the street. Car moved, no strange noises so pull a U turn and 25 miles up to Long Beach. I took it easy as I could feel the clutch bedding and the engagement changing each shift. Once it was consistent, back in the hood, and with some fresh gas in the tank, it was time to have some fun.
:woowoo: :woowoo:
My other sister lives in HB now, maybe I should swing over sometime and get in line :bashtard:
Yes. El Architecto, I was in Orange today, maybe again on thurs or friday? Any way to make it down there?
TheArchitect
audifreakjim wrote:Yes. El Architecto, I was in Orange today, maybe again on thurs or friday? Any way to make it down there?
Are you not always in the OC?
I may make it down to North OC on one evening, workload is totally unknown at this time so impossible to schedule at present.
I'll be in Agoura Hills BTW, that is I will not be down in Santa Ana.
