What should I use to fill in rubber?
Posted: Sun Dec 22, 2013 8:23 am
by DE80q
So I have a new drive shaft carrier bearing for my B3. I would like to use something to fill in the void in the rubber. I have heard people mention windshield urothane to fill up engine and trans mounts, but dont know which to use. Obviously I want somthing that isnt going to become hard when it cures. I would need somthing that would become stiff, yet stay plyable. Anyone BTDT and can tell me what they used?
Re: What should I use to fill in rubber?
Posted: Sun Dec 22, 2013 1:40 pm
by ringbearer
I've done 3 UrSpig center support bearings with 3M window weld, no issues with any so far.
IMG_7547 by ringbearer93, on Flickr
IMG_7548 by ringbearer93, on Flickr
Posted: Mon Dec 23, 2013 2:19 am
by DE80q
That's exactly what I needed to know. Any idea how long it took for it to cure? That is quite the void to fill. Thanks
Posted: Mon Dec 23, 2013 5:38 pm
by ringbearer
http://solutions.3m.com/wps/portal/3M/e ... RC9RGN5Fbl
Quick!
Wear gloves, it won't come off anything.
You're welcome, good luck and post some pics when finished.
Posted: Wed Dec 25, 2013 10:22 am
by DE80q
Thanks, will do.
Posted: Thu Dec 26, 2013 12:32 am
by scubadave
you know, that title is a bit suggestive. you just have to plunge in and see what's the reference.
Posted: Thu Dec 26, 2013 8:45 am
by DE80q
scubadave wrote:you know, that title is a bit suggestive. you just have to plunge in and see what's the reference.
I thought about that after I posted it. ;) Then I figured I should let it go and see what came of it. Low and behold, I go the answer I was looking for first :D
Posted: Thu Dec 26, 2013 10:08 am
by Justin517
Any major issues doing this to an older but still intact bearing? Maybe even while still installed in the car?
I would think that as long as you support the shaft a bit so it isnt "sagging" while it dries, it might work out?
I know.. I'm being lazy...
Posted: Thu Dec 26, 2013 10:46 am
by Toph
I did mine on my coupe with RTV. I'll have to check it out while she's in storage to see how it is holding up.
Posted: Thu Dec 26, 2013 1:32 pm
by DE80q
Justin517 wrote:Any major issues doing this to an older but still intact bearing? Maybe even while still installed in the car?
I would imagine that would work fine. I had thought about doing it with mine. I would say as long as it is centered in the housing like it should be, it would be fine.
Toph wrote:I did mine on my coupe with RTV. I'll have to check it out while she's in storage to see how it is holding up.
RTV was mentioned by Elaw over on MG. I was thinking that RTV might be a little too soft though. Would be nice to see how one that has been done with it is holdign up though.
