Nobody NEEDS another Audi, but....
Posted: Wed Nov 13, 2013 2:35 am
I wanted one! Needed something more fun to drive that's not my Touareg or in pieces like all of my other projects. So what makes a better winter beater/fun car than a 20vt quattro!
Introducing my new 87 5000CS Turbo Quattro in sapphire!
Has a few problems, mainly a hot start issue. Car starts up and idles perfectly when it's completely cooled and continues until it's turned off. Once it warms up, it will not restart until it's sat for 6+ hours (even immediately after you shut it down). Ran the codes and it came back with 2312 - engine coolant temp sensor. I'm guessing this is the single-wire temp sensor and not the multifunction 4 or 3 pin sensor? I'll probably just replace both. I swapped around crank sensors (came with a few extras) but that didn't change anything nor did an icepack on the sensor so I'm guessing it's not that. Car also seems to have low boost, I can get a max of 1.3 bar in 3rd gear at 4k+rpm. Most of the time it's around 1.1-1.2 and very slow. SJM reading makes me think that some of this could be related to the bad temp sensor. I'll pressure check the intake anyways.
A few "odd" things have been done. It has two batteries, one in the OEM location under the rear seat and one in the trunk. Not sure the reasoning, but I've read mixed thoughts on running dual batteries. There's also been quite a bit of wiring splicing with lots I don't understand. It does look like they added in the modified after-run fan circuit described in the Bentley. It adds an engine bay temp sensor near the front of the motor.
Other than that, it's in great condition. It was definitely owned by an Audi person before the PO I bought it from (she said she bought it in 2011). Timing belt, headgasket, alternator, and a few other things were done recently. PO also included a bunch of parts including a brand new clutch/pp/tob, clutch master/slave, couple sensors and relays, and a few more bits and pieces. Had the original owners manual (purchased in Yakima, WA and dealer serviced for much of it's life). Also included a Bentley and "The Audi Quattro Book"! Included a TAP chipped ECU, but it doesn't sound like I want to use it. Time to find a Ben Swann or natrix chip!
Has the option Fuchs in good condition. I also picked up a set of B5 S4 Avus with winter tires that I'll be putting on this shortly. From what I've read they'll fit, but I probably want spacers in the front.
Not much planned for it, just get it running reliably and up the boost to 1.9bar
Wheels look good!
