oil pressure switch ?
Posted: Tue Sep 24, 2013 3:30 pm
by morris400
im looking to replace things on my 94 s4 before winter, im looking to replace this switch on the Dvr side of the block. i do have a oil leak now but im not 100% sure where its from. ive tightened all oil pan bolts to 10nm. the leak is coming from above the oil pan on the dvr side. im thinking its either this switch or the PCV system.
Can i change this switch with oil in the block? or will it piss out as soon as i pull it out?
Thanks guys,
Kenny
Re: oil pressure switch ?
Posted: Wed Sep 25, 2013 8:14 am
by EDIGREG
yes you wont lose oil as long as the motor is not running... if it's running it will spray the entire oil volume out of there in a matter of seconds :)
Posted: Wed Sep 25, 2013 12:36 pm
by WOMBAT
It'll drop a minor amount out - just the volume between the check valve (if it's still there) and the head
Posted: Wed Sep 25, 2013 8:33 pm
by morris400
Awesome guys, ill be getting a new one and installing this weekend. I took a closer look tonight and I'm 97.4% it's leaking all over the place.
Posted: Thu Sep 26, 2013 6:18 pm
by morris400
Picked one up today, as well as diff fluid and new diff plugs. I'll be doing that on Sunday and maybe tranny mounts.
