DIY Large Chassis Coilovers
Posted: Tue Aug 06, 2013 10:23 pm
I'm just putting this here temporarily because I'm afraid it will get deleted over on MG if I don't do it soon!
I intend to clean this up a bit with some more info and pics from various members who have done this setup and helped make improvements. I will be doing this same process on my 635 this weekend, so I think I should be able to take pictures of that to help here (all of the same stuff applies).
The DIY Coilover page for T44's
So after much frustration with figuring out the coilover setup for my 200 20v, I have decided to make a thread to make it easier for others to follow suit. There is of course more than one way to do this, but here is the way I chose to go. This setup should be pretty nice for anyone...you just have to pick spring rates that suit your style.
Parts you will need:
-Bilstein sport (or Koni adjustable) struts front and rear...on 200 20v's the thread is 12mm for the rears. Bilsteins will have to be re-valved for the best ride and strut life. They die rather quickly and aren't valved well for anything above about 350 lb/in spring rate.
http://www.Shox.com has them for $500 for all four.
-Your choice of springs...they have to be 2.5" ID and 6"-7" tall however. Any bigger wont let you go low enough. Ther rear can do just fine with 7-8" I believe. I went with 450= k front and 550= k rear Eibachs. Many find it beneficial to stagger the spring rates front to rear like I have to help make these nose-heavy pigs be less "understeery." If you race a lot, you might want more rate... if you like your ride like a Cadillac, you might want a bit less rate. I found 450 and 550 to be rather nice for street and occasional track use.
Then you need the coilover parts from http://www.A1racing.com
-2x front sleeves COK12452H (fits strut housings...just over 2" ID)
-2x rear sleeves COK12451 (fits the rear struts...just under 2" ID)
-4x perches COK12460
-4x upper perch COK12470
Bicknell Racing BRP-603 can be used as an alternative to the COK12470 for more suspension travel. These hats can be ordered at 716-285-7502
For the front hats I had to widen the hole in the ones that came from A1 in order to get it to slide all the way down onto the strut the way I wanted it. That way I could put the stock perch above it along with the top plate so that the strut bearing could sit in there properly.
http://shop.a1racing.com/coiloverkits.aspx
Should end up costing you about $170.
-larger snap rings Thanks to Nuugen, you can get these large snap rings to sit the sleeves on top of for the rear struts
part# 3100-0200, from: http://www.akronbearing.com
Finally, these might help with spring binding issues:
Coilover thrust bearings
http://www.speedwaymotors.com/QA1-Coil- ... ,6001.html
-Helper springs recommended to keep these seated and to perfect the setup!
HYPCS100 is the part number for helper springs from A1racing.com
Installation
Basically for the rears you just slide the sleeves over the body and put it all together. Nothing really interesting here.
In this picture, the assembled rear Audi Bilstein is on the right.
For the fronts, you have to cut the perches off and then weld a ring onto the strut housing for the sleeve to sit on. They should be roughly 3" OD and roughly 2.170 ID and made out of 1/4 inch steel.
The rings are made from 1/4" plate steel that can be had from Lowes. I turned it on a mill, but you could get away with a drill. Its just going to suck while you are doing it and it might not be perfect...but that's more than fine.
You'd need a 2 1/8" hole saw and a 3" one.
The ring is welded on the front strut housing as far down as you can get it and as level as possible.
Before you can slide the ring onto the strut housing, you'll need to cut off the stock spring perch. Just go at it with a grinder. There is no easy way about it. Just attack the factory weld all the way around it and it will eventually just crack off or break off when you hit it with a hammer. Then you have to make it completely smooth with more grinder work or a flap wheel and also take off the rest of the paint on the strut housing. Thats the only way you'll be able to fit the ring and the coilover sleeve. You may also have to take a little more material off of the inside diameter of the ring as the strut housing OD is not actually 2 1/8" its a little bigger.
Then you basically just assemble. I put some grease between the strut housing and the coilover sleeve to stop rust and assist in removal if its ever necessary.
The easy solution for spring binding is the needle thrust bearings I've added into the parts list above. Then you don't need a spherical bearing to facilitate spring turning.
Some pictures
Sorry they are so dirty, this was from after quite a bit of use and abuse
this is top of the rear
bottom of the rear...you can see the nice c-clips
This was one of the first pics taken after the install... that is about as low as you can go on the stock strut housings. More discussion on that later.
Strut Mounts
Old design I had made. They had some issues, so I went for a re-design.
New upper strut mount I was working on and hopefully will be able to work on again.
Installation
Some pictures
Strut Mounts
