Hersh Performance and Racing Products - Epic Motor Mounts
For Personal Contact, please feel free to Text or Call my cellphone: 208-946-7872 (Jared)
Please leave a message if no answer. I'm still currently working my 50+ hour day job. I will return it as soon as possible. Feel free to comment or PM me here on the forums as well.
Please Visit my website at http://www.hershperformance.com
It is still being developed so have patient please!
"Epic Motor Mounts" : In full Production. Durameters in stock include 60A, 90A, and due to a mixup 95A for a limited time. Later T44 models may require minor modification to the turbo heat shield. Durameters available with a 2 week wait include 70A and 80A.
Warranty: All metal parts come with a 3-year replacement warranty. The polyurethane material comes with a 2-year replacement warranty. The polyurethane warranty does not cover damage due to excessive heat, improper installation, or shear stupidity. Powdercoating has no warranty and is not covered.
A kit will include the following:
1 mounting plate, 1 polyurethane (durameter of your choice) mount, and hardware.
Projected Retail Cost: $75
Steel Mounting Plates: $35
Aluminum Mounting Plates: TBD
Polyurethane Mount: $32.50 per mount (10% discount given when ordered with a kit)
Replacement Hardware: $7.50
Delrin Mount: TBA
Powdercoating is standard on all mounts to your choice of color.
A shield for the passenger side mount will also be available in time. This is to protect it from the heat generated by the turbo. Ceramic Coating of the shield will be available for an extra cost.
Vehicle Fitment:
All 5-cylinder Audis and VW including the 200 20v and "urS" cars
Will fit all model = "Audi V8" both 3.6L and 4.2L engines
WILL NOT INTERCHANGE WITH V6 MODELS
Cylinder Head service for all makes and models
Audi 5-bangers 20v: $1050
Includes full big valve kit, springs, retainers, guides, seats, etc. Professionally machined head, full porting, cleaning, and return shipping.
Other Models: Please inquire. Every make and model is different
Prices vary per customer specifications and desires.
Upper Strut Mounts
Under Developement
Description: These are being designed as a direct replacement for OEM upper strut mounts. They will be offered in high durameter Rubber and Polyurethane.
20VAvant
Re: Hersh Performance and Racing Products
Post by 20VAvant »
Few questions:
Will you manufacture engine mounts for the 91' 200 with the 20V 3B? (I'd be willing to test)
Rear subframe bushings for the 200? I can supply dimensions that will fit both the 200 and the UrS4 and UrS6.
How do you design your products? 3D modeling? Structural analysis? Just for curiosities sake.
Also, I have a hard time buying Audi performance parts from a guy with a username like 'AngryTaco' :P
-2014 Lexus IS350 - SOLD
-2015 Yamaha FZ-07 - SOLD
-2005 Honda CRF230F - SOLD
In regards to the username, Id have to agree lol. Im going to create an alternate profile tonight.
Do I plan to design a mount for the 200 3b? Yes I do. I need to get my hands on a factory mount or the dimensions so I can design the mounting. Theoretically all I should have to do is design the mounting plate for your car and use the same rubber/poly mount. But before I can conclude that, I need dimensions.
I use Autocad to draw up the dimensions. Structural analysis at this point is basically throwing them in the highest HP car I can find and telling the owner "Break it". If it breaks, I redesign it for more strenght.
Get me those dimensions for the sub-frame mounts and we can work something out.
I can't wait to see if I can break them. :P
20VAvant
Post by 20VAvant »
If you autoCad drawings, I can model them in 3D Solidworks and run structural analysis on them if you give forces. This should help during machine of parts as well, looks pretty too when trying to market. I enjoy modeling stuff up and if it will help you, I will do it completely free of charge and expect no comission.
I can also send you an old motor mount when the time comes.
PM for additional info and shoot me an email address and I'll try and get you bushing models/autoCad drawings by this weekend.
20VAvant
Post by 20VAvant »
If you look real hard, it says Hersh Performance on the top.
Thats really cool. I think we can work something out. PM incoming.
Nice, guys!
Just be careful about copying others' designs ;) There are only so many ways to design a bushing though, so I don't think that can be helped lol.
By the way, you should be able to design the engine mounts such that they work with every oldschool 5-cyl ever. They should essentially all be the same dimensionally if I'm not mistaken.
20VAvant
Post by 20VAvant »
I know it's not good to copy other peoples designs, but like you said, how else can you make a bushing? :) It is, however, adjusted to work for the 200 so everyone won't have to remake in the inner aluminum bushings to fit a 10mm instead of a 14mm that I assume the UrS4/S6 have where the subframe mounts.
General consensus whether to make the bushing with more polyurethane, or to make the same bushings for both with an adjusted inner sleeve?
True that. I'll buy some for sure if/when you get it right. It should be more cost effective to have the sleeve be the adjustable part in my opinion.
I know how I can make them adjustable. Not too hard at all.
Here is my question to you, the community, regarding the sub-frame bushings.
1. Aluminum, Poly, or the option of both
2. Do you want a 1-piece press in bushing or a "split" bushing like other aftermarket aluminum ones?
20VAvant
Post by 20VAvant »
I personally liked split bushings, much easier to install. In regards to material, I feel like poly works best for my needs-you can make some for street density and track density. Aluminum solid mounts wouldn't be too hard to manufacture either-but personally they scare me.
I like what Chris said that dual use bushings save on manufacturing cost. Universal poly piece and depending on the car you should be able to use a different aluminum sleeve. This is purely based on the 200, however, which I have a slight bias toward. ;)
Another suggestion - I really would have a hard time not spending money on a front strut brace for my 200, juss sayin'
40v4kq
Post by 40v4kq »
Dont forget about Delrin ;)
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
20VAvant
Post by 20VAvant »
40v4kq wrote:Dont forget about Delrin ;)
If I'm not mistaken, Delrin is considerably easier to machine than polyurethane 85 durometer.
How does delrin compare to poly for noise and vibration dampening? I know it's a much harder and stiffer material, but doesn't that translate into a slightly harsher ride?
Website currently under development guys!
The link will be www.hershperformance.com when all said and done! Might be a week or two but it'll be awesome!
I definitely vote for split bushings. It makes install and removal oh so much easier.
Delrin will be your middle ground between poly and aluminum as far as NVH is concerned. I personally think it is the best choice in this kind of situation as long as it is designed properly to last.
I like poly, but also don't like it because of how it deteriorates over time. That said, with two-piece bushings, the install could be easy enough to justify it. I definitely like poly for its other characteristics as long as it is easy enough to change out.
All_Euro
Post by All_Euro »
I don't have the right platform to be able to order anything from you but awesome to see you went ahead with this :thumbsup:
Work - Houzz / linkedin
Play - Haldex Swap
What vehicle are you running again? Believe me, I have huge plans. The hard part is I dont want to compete with Hank and his or Marc's awesome products.
Im always looking to fill in the gaps for people needing certain things
Looks like you have a good hype going here! We will have to talk.
All_Euro
Post by All_Euro »
AngryTaco wrote:What vehicle are you running again? Believe me, I have huge plans. The hard part is I dont want to compete with Hank and his or Marc's awesome products.
No worries there - I think I'm the only one on this forum with a MKIV… Volkswagen… 1.8T… :nuts:
http://www.theprojectpad.com/viewtopic.php?f=11&t=202
Either way - stoked to see what you're up to :beer:
Play - Haldex Swap
Ok guys I need your feedback. And SERIOUS feedback. I have recieved my cost prices as far as the motor mounts are concerned.
I will have to sell them for $70-75 retail to make any kind of a profit. Comes with all hardware and 1 polyurethane mount in 80 durameter. A run in Rubber will most likely be cheaper after my first order or I will offer a kit for about $90 or somewhere in that area. The more orders I get, the cheaper it will be. I'm including a 2 year warranty on the mount and a 3 year on the mounting plate. These will blow any other mount out there out of the water.
I'm still waiting on a few other companies to get back with a different design as it may be cheaper but less reliable.
This design is "theoretically" indestructable.
20VAvant
Re: Hersh Performance and Racing Products -- Need FEEDBACK
Post by 20VAvant »
How much stiffer than stock should they theoretically be?
Any pictures? As i recall you said they were steel and not aluminum correct?
The 80 durameter poly mounts will be much stiffer over stock. I think stock is about a 50 if I'm correct. 034's street density is a 60 and I think their track is 80. However, I dont see their track on the website anymore.
20vAvant, I'm sending you a PM
