Ben's Coupe GT
Grillage
Ben's Coupe GT
Post by Grillage »
I bought this yesterday from a friend of a friend in NW Ohio, a couple hours north of me.
Anyway, unbelievable story, 2 owner car. The folks I bought it from purchased it in January 1988 and kept every single receipt. It is SO clean I can hardly believe it. Soft red leather, no cracks or tears.
Car came with a new in the box unused digidash (with receipt from 1989). Their service folks thought it had a bad digidash but it turned out to be a bad temp sender so they put the old one back in and threw the new one back in the box and saved it.
She had it pinstriped apparently by someone at Peterbilt. Not sure how I feel about that part. Some of it is fine, other parts are pretty gaudy. I'm curious if I can remove it (or part of it)
Pics:
Car has some lifter tick and apparently a bad wheel bearing - plus the radio doesn't make any sound whatsoever - so there is a little to do. Unfortunately, I just put the AAN B4 on the lift for what will be an extended period while I rebuild the 6 speed 01E, redo the breather system (with a catch can this time) and run AC lines.
CURRENT
PAST
Re: Ben's Coupe GT
I'm not even surprised anymore, nice find.
What are your plans for this one? Swap? Restore and flip? Keep? These are going up in value quite a bit lately...
Grillage
Re: Ben's Coupe GT
Post by Grillage »
I'm not planning to do any swaps with this one.
Hoping to just get it running 100% and enjoy all 110 HP 8-)
CURRENT
PAST
Re: Ben's Coupe GT
I'll say it here too! SO CLEAN!
Re: Ben's Coupe GT
Awesome find! Looks great!
Re: Ben's Coupe GT
So glad it went to a good home! Glad it was too far away from me too.
Sent from my Pixel 4 XL using Tapatalk
Re: Ben's Coupe GT
Post by the german »
Badass! Glad you got this one!
pete82
Re: Ben's Coupe GT
Post by pete82 »
Was this the one that popped up a couple of times on facebook? Very nice car, pin striping is different but in a good way.
I miss my type 85's always good fun to drive and so much more nimble/lighter than the later coupe's.
Grillage
Re: Ben's Coupe GT
Post by Grillage »
It is the one from Facebook. The pinstriping is growing on me. I would change the “stars” next to the “Audi GT” part but the rest is good with me.
CURRENT
PAST
Grillage
Re: Ben's Coupe GT
Post by Grillage »
Got some work done on this during my holiday break.
The "Lifter Tick" that I though I was hearing was an alternator bearing. I took the car on about a 20 mile trip and what had started off sounding like a tick was a scream by the time I got home.
Rebuilt the Alternator today and its all better!
Also got the radio to make sound.
I'm really digging this thing. It's slow but really pretty fun to drive
CURRENT
PAST
Re: Ben's Coupe GT
Post by jbrentd »
Looks clean and well cared for. Nice find!
Grillage
Re: Ben's Coupe GT
Post by Grillage »
Some Fun data from Audi --
A total of 2,365 Audi Coupe GTs produced in the 1986 model year with the vehicle code 855424. 699 were produced with Graphite Metallic and 284 of those were also produced with the Red Leather interior.
CURRENT
PAST
Re: Ben's Coupe GT
Nice. I love details like that. Dealership, or from Audi corporate?
Grillage
Re: Ben's Coupe GT
Post by Grillage »
PRY4SNO wrote:Nice. I love details like that. Dealership, or from Audi corporate?
Audizine has a thread that they comment on
https://www.audizine.com/forum/showthre ... st13981434
CURRENT
PAST
Re: Ben's Coupe GT
^^^ Pro tip, thanks!!
I guess I should pop back over there every once in a while...
Grillage
Re: Ben's Coupe GT
Post by Grillage »
A few more developments with this car. New tires, went through the hydraulic system completely. New master and slave for the clutch, new rotors and pads in front. Bled the really awful black fluid out of the system
Today I tackled the digidash. It had a bleed in the left panel and I decided to just move that panel from the extra dash that came with the car over:
Worked like a charm but was a terrifying thing to do!
Apparently the spare is an Orange one, mine is red.
So anyway, it worked like a charm!
I also unplugged that damn shift light! My 924S has one too and they drive me crazy.
CURRENT
PAST
Re: Ben's Coupe GT
Post by jbrentd »
Nice job on the dash. I bet it feels good to have it fix.
Grillage
Re: Ben's Coupe GT
Post by Grillage »
I set out to do a timing belt job on this car and scope creep got me!
The problems started when I couldn't get the crankshaft seal (which was leaking really badly) out using the regular means. Eventually, I was pretty convinced I had screwed up the sealing surface of the Oil pump so I decided to pull the motor and deal with it that way.
Also, I was able to see a few decent oil leaks on the block (which was rusty AF) - including a bit from the Head Gasket. So anyway, I ended up doing the following:
Timing Belt
Water Pump
Thermostat
Rollers
Head Gasket
Valve Stem Seals
Oil Pan gasket
all the top end gaskets.
86'd the vacuum pump and made an aluminum block off plate that looks pretty OEM if I do say so myself
Front struts
Front strut mounts
Clutch, PP, TO Bearing etc.
Did the clutch Hydraulics a month or so ago too.
When I dropped the axles by lifting the car off of the axle/subframe assy, I forgot to disconnect the brake lines and I stretched them tight - which made me super uncomfortable, so I replaced them with stainless too.
Also, I cleaned up and painted everything.
Not done yet, but getting close. Motor is back in and I hope to be able to get it completed later today.
Some pics:
I think I may slow myself down a bit and paint the Brake booster while I have the hydraulic system open.
Top of the radiator too. It will look SO much better in there!
CURRENT
PAST
Re: Ben's Coupe GT
Post by jbrentd »
Yeah, that turned in to quite a list. But it'll feel nice having done all of that.
Re: Ben's Coupe GT
Post by AudiSport4000 »
It was either you or me getting this one, and I'm glad you ended up with it. The owners sure were awesome and truly are German car enthusiasts. I am still blown away that this thing was 40 minutes from me and I never knew it until Eric posted about it. I've only driven a handful of CGT's and this one was super nice. The interior and floormats alone are astounding. Cant wait to see this again after all the work you have put into it!!! Graphite CE brothers :D
Grillage
Re: Ben's Coupe GT
Post by Grillage »
AudiSport4000 wrote:It was either you or me getting this one, and I'm glad you ended up with it. The owners sure were awesome and truly are German car enthusiasts. I am still blown away that this thing was 40 minutes from me and I never knew it until Eric posted about it. I've only driven a handful of CGT's and this one was super nice. The interior and floormats alone are astounding. Cant wait to see this again after all the work you have put into it!!! Graphite CE brothers :D
I'm glad I ended up with it too! it's fun to drive even as slow as it is.
Im going to send the old owners pics once the engine bay is back together fully. Hopefully this weekend if a few parts show up!
and yes, GRAPHITE CE BROTHERS!
CURRENT
PAST
cuatrokoop
Re: Ben's Coupe GT
Post by cuatrokoop »
I was hoping you'd send her pictures of her old CGT, she'll be over the moon, Ben!
Grillage
Re: Ben's Coupe GT
Post by Grillage »
cuatrokoop wrote:I was hoping you'd send her pictures of her old CGT, she'll be over the moon, Ben!
I will for sure. Just one thing left to do
CURRENT
PAST
Grillage
Re: Ben's Coupe GT
Post by Grillage »
I just sent her a full rundown! hope she likes the results!
CURRENT
PAST
cuatrokoop
Re: Ben's Coupe GT
Nice! She should!!
