Coilover springs
Posted: Thu Mar 30, 2017 7:20 pm
Had one of the front lower spring perches let go in the s6, planning on going the a1 coilover route but not because I want to go low. I have read through the DIY threads here and on MG and see that most people are saying to go with a 6" spring, would you still go with a 6" spring for a daily driver that sees snow? I honestly have no desire to lower the car from stock height and was wondering if a taller spring would be better for "stockish" height seeing how the OEM spring is like 15 inches.
Secondly, I was seeing that some people were saying that there is some clearance issues with the retaining nut for the strut and the 2.5" springs. Can this be cleared up by grinding the nut a bit or should I be looking for a barrel style spring to make some more room?
Lastly, what spring rates would everyone recommend for a comfortable ride. This is a land barge that needs to get me to work no matter the conditions so my biggest concern is keeping the subframe off the ground
Thinking 275-300 lbs/inch for a heavy car like the s6 would be ok?
