Anybody see this from running E85?
Posted: Sat Mar 11, 2017 6:52 pm
I get a frothy yellow goo, it looks like it eventually settles back down to oil (the goo is pre filter, the top of the separator is the intake).
What you see is from idling the engine and going on short drives, oil may have not reached operating temp.
I also often see a surprising amount of water in the separator, I wonder if E85 produces more water than gasoline
The Mann provent oil separator is working well, I have it under hi vacuum, feeding the intake manifold directly, I'm hoping keeping the crankcase under vacuum will make the rings seal better!
