Short deck 2.6L love!!
Posted: Wed Jul 20, 2016 9:12 pm
So I've been running a "Eurospec" 2.6L shortdeck (and probably short rod) 2.6L for several years with a tweeked/ported/big valve 20v head and a 276deg. Schrick, 034 eFI e85 blah, blah....
See here for more info: http://www.theprojectpad.com/viewtopic.php?f=10&t=1738
I've verified that it's definitely a shortdeck, but not a 2.3L block, someone suggested it came from South Africa? "Audi-engine AAY, 2480 ccm, 100 kw Petrol only made in SA": http://www.s2forum.com/forum/showthread.php?t=72559
It has brutal midrange torque, but runs out of breath at 5,750. It's in a 2300lb fwd. car that I rarely drive on the street, mostly track (as you probably figured from the pics).
Anyways, I wanna put a 20V head on it, I know that means I'll have to change the pistons.
Also, before anybody says anything: NO TURBO!!
More importantly, what kind of work should I do to the head? If I dropped it off at big Hanks shop and got the CNC porting done... what else?
I know that having a long stroke engine with a ton of rod angle affects tuning, I figured the 20v will let that bottom end breathe way it wants to!
