FS: Fidanza Aluminum Flywheel for 32v 10-bolt Audi V8
Posted: Tue Jun 28, 2016 6:29 pm
by alxdgr8
Rare, no longer available Fidanza aluminum flywheel for Audi 32v V8 10-bolt cranks (PT, ABH, ABZ, etc...does not fit 40v or timing chain motors). Perfect for a manual swap! Does not have a trigger wheel so it won't work with OEM ABZ ECU. Includes the optional pilot bearing adapter to run with 01A/01E transmissions or remove it to run it with an 016. Uses the standard Audi 240mm clutch. Flywheel has a max of 3k miles on it (probably closer to 1500 miles, the car hasn't been driven much since it was built). Friction plate has a little wear and some small streaks of surface rust (car has been sitting a while). The steel friction surface is still available new and is only $60 to replace.
$400 picked up.
$420 shipped to USA only.
Cash pickup or Paypal for delivery.
ImageIMG_20160628_153119 by Vex Art, on Flickr
Re: FS: Fidanza Aluminum Flywheel for 32v 10-bolt Audi V8
Posted: Thu Jun 30, 2016 11:59 am
by alxdgr8
Sold!
