Page 1 of 3
UrS4/UrS6 camber/caster plates for coilover setups...
Posted: Wed Mar 20, 2013 9:26 pm
by EDIGREG
Probably the biggest hurdle in building a custom coilover setup for my s4 was a solution for the top mount. I have been rather unhappy with the 2Bennett plates currently on my car... they are a decent solution for cars running lowering springs in a factory configuration requiring additional camber adjustment, however they are very poorly designed for a coilover setup where the entire corner weight and suspension force acts directly on the spherical bearing and therefore the plate itself. The only thing preventing these from blowing out completely are three nuts at the top, which only grab a couple threads each, and about 1/4" of aluminum. I certainly don't trust the 2B product for track/high speed driving, and there is very little available as far as other fully adjustable options, so I designed my own.
My plates utilize the factory steel lower plate, reinforced with six grade 10.9 M10 bolts, zinc-plated hardened steel ring, and locking nuts with 6061-T6 adjustable centers and race quality teflon-lined NHBB spherical bearings.
These are designed to bolt directly into any C4, however there is a bit of trimming required at the top to make room for the slightly wider plate base. They are designed for use exclusively with coilover setups, and they will not work with factory springs/strut bearings. They may also work in other chassis with similar suspension setups, such as T44, but I can only guarantee fitment in a C4.
I am currently in the process of building the first set/prototype, which will be tested on my car. After testing and potential revisions/improvements, they should be available to you all at a very reasonable price. Stay tuned!
Re: UrS4/UrS6 camber/caster plates for coilover setups...
Posted: Wed Mar 20, 2013 10:09 pm
by ringbearer
Very nice Ed!
Been wanting to see these for a while. I spent my car funds on a TIG so I'm not in a rush but I'll be wanting a set once you are happy with them.
Posted: Wed Mar 20, 2013 10:21 pm
by amd is the best
Sub'd.
Posted: Thu Mar 21, 2013 12:16 pm
by mushasho
I'm In For The WIN!!!
Posted: Thu Mar 21, 2013 8:00 pm
by pilihp2
Wow. I want.
Posted: Mon Apr 01, 2013 8:54 am
by themagellan
+1, this may change my mind about just going Shocks/Springs and go for the coils.
Posted: Fri Apr 12, 2013 12:11 am
by Hank
You found a machine hsop for these yet? I might be interested in doing the machine work.
Posted: Fri Apr 12, 2013 1:07 am
by pilihp2
My top mounts are lookin purdy haggard. These sure would like nice replacing them...
Posted: Fri May 03, 2013 11:25 am
by quattro
Ill be keen for a pair
Posted: Fri May 03, 2013 1:11 pm
by EDIGREG
I have most of the parts done, received the spherical bearings yesterday. Need to make some tweaks, then should have the first set on my car for testing in a week or so.
Posted: Wed Jun 05, 2013 7:45 am
by urS6Tom
Any progress on these? I'm keen for a set!
One question on the coilovers, has anyone managed to get a fully adjustable coilover setup working on the S6?
I know that KW supply their V1 kit, but if I go to coilovers I'll be looking for full rebound/damping adjustment + the ability to set it at stock height and then lower it for the track.
Any thoughts would be most welcome!
Cheers,
Tom
Posted: Wed Jun 05, 2013 8:17 am
by EDIGREG
Not quite yet Tom - still waiting on one part from the machine shop unfortunately. They missed a dimension so the parts needed to be sent back.
If you're looking to have adjustable dampers then you'll need to use Konis...Bilstein does not offer this option. However, even at their stiffest settings, off-the-shelf Konis cannot keep up with spring rates over 400#/in, not for very long. They will blow out quickly at those rates. I have had the best success using revalved Bilsteins to match my spring rates. Maybe you can have them revalved by Koni and still have adjustability - I have never investigated this option.
Posted: Mon Jun 10, 2013 10:33 am
by urS6Tom
Thanks for the reply. I've still got some thinking to do on the dampers...
Do you have any idea what your top mounts will cost?
Posted: Tue Jun 25, 2013 12:38 am
by AngryTaco
Do you have a price in mind yet? Im currently building and designing a set of coilovers for my friends 5000tq and he has expressed a TON of interest in combining my coil overs with your camber/caster setup. He has a budget and I'm trying to stay within it while utilizing your setup.
Posted: Tue Jun 25, 2013 7:51 am
by EDIGREG
Not quite yet... I'll try to put something together ASAP, however I'm going to switch machine shops for the next run as this one was just a bit too slow.
I have all the parts, however I was sent the wrong bearings, so I need to investigate wtf happened there.
Too many projects, too little time... :/
Posted: Sat Jun 29, 2013 11:47 am
by glibobbo21
HANK, no! You have oilpans to weld!
Posted: Sat Jun 29, 2013 2:14 pm
by EDIGREG
Someone get this man an oil pan!
Posted: Mon Jul 01, 2013 6:46 pm
by v8coupe
I'm more then interested in these I'm also unhappy with the 2B solution as I'm on my second set of centers for mine. If you need any help or want an addtional tester for the 200 chassis let me know.
I'm working on an upgraded rear mount as I am sick of them failing when you drive a t44 hard with stiff springs.
Posted: Tue Aug 13, 2013 12:56 am
by quattro
How are you getting on with these?
Posted: Tue Oct 15, 2013 10:23 pm
by A20V200
Any updates on these Ed?
Posted: Wed Oct 16, 2013 7:41 am
by EDIGREG
haven't touched them recently, they're sitting in a box! I'll post some pics at least. Will definitely be finishing them up this winter when my s4 is off the road.
Posted: Fri Feb 28, 2014 9:54 pm
by k2exoman
Sub'd
Posted: Fri Feb 28, 2014 11:12 pm
by pilihp2
Winters almost overrr.....
Posted: Sat Mar 01, 2014 1:02 am
by AngryTaco
yeah I have a feeling a v8q is going to want a set of these from you Ed.......sooooon
or are the T44 pretty different vs the urS cars?
Posted: Mon Mar 03, 2014 9:21 am
by 20VAvant
^^ I know of a 200 that will need a set soon....
