FS: 1990 20vt CQ - built AAN running Motronic + Volvo k24
Posted: Thu Aug 27, 2015 8:43 pm
So I know I have played around with a lot of 'feelers' but the time has officially come to put this on the market. I would love to keep the car and continue to refine it over time, but it is one of the things is standing in my way of paying off those nagging student loans and launching my own company.
I picked up the car in the spring of 2011 and swapped in an AAN that I had been building. Over the course of a year I worked on massaging out the kinks while running on an MTM stage 1+ AAN ECU and stock turbo until the timing belt slipped due to an under-torqued crank bolt. I then pulled the head off and had it rebuilt with new and upgraded components, and got it running on VEMS and a holset turbo.
I ran this setup for <100 miles while working on the tune until my girlfriend and I moved out to pittsburgh where I lost my time, space, and motivation to build it into the wheel spinning, fire breathing beast that it was meant to become. So, over the last few months I have worked on getting it running on a Volvo k24 (RS2) and AAN motronic ECU with a EFI Express tune. It's almost done, all it needs is the crankcase breather system finished!
Here are the juicy details
Engine:
-AAN with ~9k on the rebuilt and balanced bottom end
-Rebuilt cylinder head has ~1k miles
-RHD ABY S2 engine harness
-AAN ECU with EFI Express tune with launch control for Volvo k24 and 60lb injectors
-60lb injectors
-Scat rods
-ARP hardware
-Coated bearings
-New intake valves
-Stainless Steel exhaust valves
-Supertech springs and retainers
-Lightweight lifters
-7A cams
-New CPS
-Apikol ignition coil conversion with updated coilpacks
-STR 'RS2' turbo manifold
-AAN Wasetgate
-Volvo K24 (similar to RS2) turbo with no shaft play
-Iroz 3" SS downpipe
-ABY airbox modified with velocity stack
-Iroz modified AAN intake manifold
-Big ebay intercooler with 2.5" inlets
-Custom 2.5" intercooler piping powdercoated to match valve cover
-URS6 snub mount bracket with Apikol mount (provides better IC clearance)
-New radiator
-034 vortex catch can
-AAN serp. belt setup with A/C deleted. This uses a 1300mm belt.
-New engine mounts
-3" turbo-back exhaust with magnaflow high flow cat.
-Partially rebuilt P/S pump
Drivetrain
-Lightened 7A flywheel
-Spec stg3+ clutch
-01E 5spd from a 95 S6 with custom mounts
-4:1 center diff
-Refurbished 4k driveshaft
-034 track 'density' trans and rear diff mounts
Suspension/Wheels:
-2b coilover setup with newer used front Koni Struts
-Shortened steering arms for quicker response/more steering angle
-Summit racing front springs... can't remember if 400lb or 450lb.
-034 track density strut mounts
-Sandblasted, seam welded, and POR15'd subframes
-Rear swaybar brackets added
-034 Alum. subframe bushings
-New OEM subframe bolts
-New OEM control arm bushings
-New OEM ball joints
-New OEM rear tie rods
-New OEM front tie rods
-17x10 et25 10th Anniversary Mustang replica wheels (4x108)
-245/40/17 Bridgestone Potenza RE01Rs
Exterior:
-S2 front bumper with fresh paint
-RS2 headlights with blacked out housings and yellow lamin-x over the highbeams
-4500k HID lowbeams
-S2 Front corner lights and fog lights with blacked out housings (these are off Ebay from Latvia but I've retrofitted OEM projectors into the fog light housings).
-S2 Rear bumper in pearl white
-B4 hood and locking pieces
-URS6 headlight washer retrofit (more discrete than the S2 ones).
-B5 paper cabin filter retrofit. (some mice chewed their way past this over the winter
-Euro rear license plate surround
Interior:
-Very clean black interior. No rips or buckled seams!
-Cabriolet cluster with autocheck and retrofitted LED bulbs -shows 98k
-Podi boost and AFR gauges
-Early B5 sport steering wheel (same as late URS6)
-Stock seats with no rips or worn areas
-MK1 short shifter mod
-JHM shifter extender
-B5 sport shift knob
-DIY real carbon fiber trim
-Uninstalled Black headliner bits -other than sunvisors...
Issues:
-Interior needs some assembly. I pulled the headliner to recover it in black suede and the A,B and C pillar covers are still off - I intended on recovering or plastidipping these.
-It needs a VDO cluster. It currently had a UN4 cluster which does not exactly work right - RPM and temp are off.
-The crankcase breather is currently vented to atmosphere which produces noticeable fumes when driving. This would be solved with a better catch can and venting it into the intake.
-The clutch master sometimes looses pressure over time requiring you pull the pedal up with your foot. Otherwise, it works fine.
-Fog lights do not currently work
-Dome light wiring was removed. I intended on rewiring this but did not get around to it.
-I traded design services for a 'friend' to redo my door panels. He got the better end of the deal (see photos below).
Looking for $7500 obo
Email me at: hans dot nielsen dot design at gmail dot com for the fastest response.
Engine:
-60lb injectors
-Scat rods
-ARP hardware
-Coated bearings
-New intake valves
-7A cams
-New CPS
-AAN Wasetgate
-New radiator
-New engine mounts
Drivetrain
-Spec stg3+ clutch
-4:1 center diff
Suspension/Wheels:
Exterior:
-4500k HID lowbeams
Interior:
Issues:
