UrS4 - misfire
UrS4 - misfire
Car misfires at idle & under throttle. Improves when warm. Pulled 2312, and replaced the G62 sensor.
Then I soldered a new 2-pin plug onto the engine harness because the old one broke apart when I touched it.
Still misfires.
Where should I look next?
Re: UrS4 - misfire
If OE coils, look to the power output stages. You can swap them from a handful of other Audi/VW motors
Re: UrS4 - misfire
Yep, only time I've had misfire at idle it's been because of coils.
Re: UrS4 - misfire
Good tip guys, thanks. I'll hit up a buddy for spares.
Re: UrS4 - misfire
That being said, usually I've experienced coils getting worse with heat... Could be vac leak if the car is still on MAF.
Re: UrS4 - misfire
I too have a weird misfire but mine is only at low throttle after hard cornering… I think it may be related to blow by… (thread jack)
Re: UrS4 - misfire
Dave K. on QW recommended to pull the red ECU power fuse to clear the codes... so I'll try that first then look into the POS & coils or injectors. Thanks guys!
themagellan wrote:I too have a weird misfire but mine is only at low throttle after hard cornering… I think it may be related to blow by… (thread jack)
No worries! Nice to keeps solutions to a common issue handy in one tidy location.
Re: UrS4 - misfire
Reset the ECU, ran perfect first time I ran the car. Misfires again as soon as I cranked her over the next time tho.
Will try the injectors and POS tonight when I meet up with a buddy who has a urs6.
morris400
Re: UrS4 - misfire
Post by morris400 »
I'll try to get my POS off the fire wall tomorrow. If I can you can swap to see if it helps. They did not want to budge last time I tried lol
2016 VW GTI DSG Daily Driver
2001 B5 S4 Stg 3- (Gone)
