Just killed 016#3 in a second gear drift around the on ramp with the diff locked. Bummer, I was having so much fun!
It failed in pretty spectacular fashion, second gear is completely gone, put it in gear and the engine just revs, lol. All other gears still work for now so I could drive it home albeit a bit noisy...
We are having a bunch of people over tomorrow night and I have promised some joy rides. I will probably still do it and just make sure there is a tow car ready
death 4kqt
No lessons today, this is how all three transmissions have died, it is only a matter of time.
Hank, my ass could tell you the exact amount of power it takes to break it. I have been babying it for the last ~2.5 years at only 25 psi or so and it has been fine. It seems 28-29 psi is death to 016. Same exact boost as last time.
The axles are next, it is hard to break them when the wheels are spinning from open diffs!
- speeding-g60
Jimbob spent most of the weekend in the garage. It turns out the 016 linkage was really easy to use. I had to tweak it a few times in the vice, but it all works with my custom 016 style shifter.
Complete gallery here
http://www.motorgeek.com/phpBB2/gallery ... emId=86020 ... emId=86020
Here is a pic of the 016 on top and the 01E on the bottom. Notice the front linkage is almost the same length. The 01E linkage is a short shift setup I borrowed from Apikol for test fitting.
Fits perfectly
Here is the almost final version, I am going to replace the small ball joints with quality heim joints.
I welded a little wedge in the shifter arm so it fits nice and tight
This pic shows why the urs4 01E linkage will not work on the small cars. the pivot is on the wrong side and hits the tunnel.
I also ordered a few other necessities from 034.
http://www.034motorsport.com/product_in ... s_id=19071 ... s_id=19071
http://www.034motorsport.com/product_in ... cts_id=331 ... cts_id=331
Fits perfectly
- ralleyquattro
You can also mod the UrS shift linkage to mimic the 016 like Zlobo did.
This way you get to keep the matching selector lever.
Hope this helps.
Hope this helps.
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
91 Coupe Quattro
haha, I recognize that tranny jack. Works GREAT for installing a tranny on jack stands
