Page 38 of 49
Casey's 200 20v: Dyno Update 10/2/2012
Posted: Wed Oct 03, 2012 10:24 am
by WOMBAT
Haha I want to know too! Unfortunately it would probably be more along the lines of a 255 on a 10" for a little stretch.. Please don't kill me!
I swear I won't run a 225 on a 10.5" with et20 like I had before with the Speedlines
I did not have any rubbing issues with those though.
Re: Casey's 200 20v: Dyno Update 10/2/2012
Posted: Wed Oct 03, 2012 10:44 am
I had 18x10 also with no rubbing issues. Its all about the offset
Posted: Wed Oct 03, 2012 10:56 am
by WOMBAT
Yes sir - BTW what were the specs of those wheels?
Posted: Wed Oct 03, 2012 10:59 am
I kinda forget but they were et 55 ish out back I think and 32 mm-ish adapters. I have to go dig through some old posts to get exact numbers.
255 on a 10" wheel will look like this on this car:
it was a tight fit, but I liked it that way. I swear they didn't rub, even at full compression!
Posted: Wed Oct 03, 2012 11:14 am
by 123quattro
I guess your suspension never compressed more than 10mm...
Posted: Wed Oct 03, 2012 11:18 am
by WOMBAT
Wow - welcome to the limit! Awesome
I believe that they didn't rub - my 10.5" et20 cleared everything with only a couple mm's to spare
Posted: Wed Oct 03, 2012 11:26 am
by Hank
123quattro wrote:I guess your suspension never compressed more than 10mm...
:stupid:
It looks like it is touching static!
Posted: Wed Oct 03, 2012 11:41 am
by busmn280
I'm running a 18 x 8.5 wheel square setup without any rubbing in the front or rear. But 18 x 10 is a completely different story-at least in the front. Nick just posted some pictures of his 200 with BBS RS-GT's with 18 x 8.5 (F) and 18 x 9.5 (R). Wide wheels can fit on T-44's. It's all about the proper offset. I do prefer a square setup like most people.
Posted: Wed Oct 03, 2012 11:45 am
by WOMBAT
busmn280 wrote:I'm running a 18 x 8.5 wheel square setup without any rubbing in the front or rear. But 18 x 10 is a completely different story-at least in the front. Nick just posted some pictures of his 200 with BBS RS-GT's with 18 x 8.5 (F) and 18 x 9.5 (R). Wide wheels can fit on T-44's. It's all about the proper offset. I do prefer a square setup like most people.
Yep square is definitely preferred in my taste. I think I may create a jig to measure the capability of the 200. Something simple to simulate various wheel width and offset.
Posted: Wed Oct 03, 2012 12:13 pm
by pkw
more trouble than it is worth - you can just fully compress susp by jacking opposite corner (usually) and if front wheel turn lock to lock while taking measurements of what you have and do simple math. even easier for rear because of no turning. my simple math says that 10" wide with 255s rubs at least somewhere if not everywhere on a t44. sure it is all about offset, i am not disagreeing but there is still a point that you can not go any wider with any offset.
Posted: Wed Oct 03, 2012 12:16 pm
by pkw
...but that car does look fannnnnnnnnnnnnntastic!
Posted: Wed Oct 03, 2012 1:34 pm
by JonathanL
Would you blast down a bumpy road with that setup? No, there aren't any bumpy roads in florida. Carry on
Posted: Wed Oct 03, 2012 2:49 pm
lol I swear it never rubbed and I hit plenty of bumps on a daily basis. The suspension geometry is such that it tucks right up in there. Also, there was at least another 12-25 mm of space left to go inward... I just liked the flush look.
Posted: Wed Oct 03, 2012 3:57 pm
by WOMBAT
Yes, what he said! Me too.
This current wheel and tire set are my first that rub, but that's because the diameter is too big - 245/40/R18
Posted: Wed Oct 03, 2012 6:38 pm
by pkw
you guys removing liners? I think cornering load is more likely to uncover a rubbing issue than hitting a bump.
Posted: Wed Oct 03, 2012 7:26 pm
by EDIGREG
The wheels naturally camber out on compression so they tuck into the fender nicely.
It looks great but why run 255's on a 10" wide wheel when you can fit them on an 8.5" wheel? After modding my front struts I will run 265/35/18 on 18x9" (C4)...that is the most tire I can fit under stock fenders.
Posted: Wed Oct 03, 2012 8:35 pm
You are right Ed, there is no point if you are running the same tire. I could have put 275 on there with no problem with a different offset though.
Posted: Wed Oct 03, 2012 11:41 pm
by busmn280
Ed,
What are you doing to your strut housings to mod them to fit your future wheel and tire setup? What wheels and what offset will you use?
Posted: Thu Oct 04, 2012 5:42 am
by groff
BFH should do the trick
Posted: Thu Oct 04, 2012 6:04 pm
by EDIGREG
loxxrider wrote:You are right Ed, there is no point if you are running the same tire. I could have put 275 on there with no problem with a different offset though.
I'll believe it when I see it! T44 suffers from the same issue as the C4, interference with the steering arm. Unless of course you are talking about some mexican wheel offset
busmn280 wrote:Ed,
The steering arms will be lowered about 3" on the strut tube, clearanced on the outside, and potentially clocked slightly inwards. I'd like to avoid re-clocking as I don't want to upset Ackerman geometry, but a slight adjustment may be necessary and wouldn't have much effect. Wheels will be 18x9 or 18x9.5, around et40.
Posted: Thu Oct 04, 2012 6:54 pm
by ringbearer
Send me those worthless SSRs then, they will be in your way...
Posted: Thu Oct 04, 2012 7:38 pm
I was talking about in the rear Ed. Not sure what could fit in the front.
Posted: Thu Oct 04, 2012 9:10 pm
by EDIGREG
loxxrider wrote:I was talking about in the rear Ed. Not sure what could fit in the front.
Ah, well yeah there is a lot of room in the rear...but staggered FTL
Posted: Thu Oct 04, 2012 9:34 pm
Agreed from a performance standpoint. I don't mind the idea of staggered offsets, lips, but square widths all around though. That is my plan if I can ever get a new center for one of my speedlines.
Re: Casey's 200 20v: What do I lose with VEMS vs Stock ECU?
Posted: Fri Jan 25, 2013 10:01 am
by WOMBAT
WOMBAT wrote:And I think I found my instrument cluster problem...
Anyone have a cluster I can scavenge for parts?
Does anyone have a cluster I can cannabalize for parts?
