Page 37 of 49
Re: Casey's 200 20v: What do I lose with VEMS vs Stock ECU?
Posted: Sun Sep 09, 2012 3:39 pm
by WOMBAT
I bought it online through Autozone - It was the cheapest quantity with a decent heat rating. I had to put down $23 for some good 3M spray adhesive made for this application though.
I need some VEMS been there done that insight. Since removing my stock ecu, I have a few changes in my dash and I want to know if its because the stock ECU isn't there to control them or if I really do have problems (possibly my ignition switch being faulty).
My brake, ABS, and batt light stay on constantly, almost as though my dash doesn't realize my engine is running (displaying all warning lights as though the ign is on but engine isn't running) Is this related to the change in ECU?
Also, my multi function display for MPG is out but I know that was factory ecu territory so I'm not worried.
Lastly, my neat screen that displays "OK" when starting or whatever warning message doesn't do anything anymore - was that a stock ecu item?
Thanks in advance!
Re: Casey's 200 20v: Inconsistent starter... wtf
Posted: Sun Sep 09, 2012 3:44 pm
by WOMBAT
loxxrider wrote:Nice job on the hood, I want to do that.
Making the templates was way too tedious.... I saved them in case I have to do it again
Posted: Sun Sep 09, 2012 6:45 pm
Those lights should not be coming on because of VEMS. The ONLY time I have ever seen all of them come on at once was when my alt. belt snapped. You sure your alternator (and battery) is in good shape? What does your Voltage look like? I guess the ign switch might be able to cause that too... you definitely have some electrical gremlin going on and I think the dash lights and your no-start are linked.
Posted: Sun Sep 09, 2012 7:22 pm
by EDIGREG
Yeah, like Chris said those lights should not be on.
Your trip computer will no longer work, but the autocheck should work the same as it did before.
Posted: Mon Sep 10, 2012 4:20 am
by WOMBAT
Ok, that doesn't read "OK" or anything when I start the car. The battery has been perfect, the car starts strong everytime, slowly over time my analog battery gauge has crept over 12v, VEMS reads over 13V when running (something like 13.6V) and always has even when the analog batt gauge read low.
The first time I attempted to start the car, there was some smoke from under the driver's side kick panel so I pulled it but couldn't find the source and it didn't do it again.... Hopefully that was my ign switch giving up?
In any event, sounds like the ign switch is the right place to start. Is it a complete unit with key and tumbler or is it detached from that?
Posted: Mon Sep 10, 2012 4:28 am
by death 4kqt
the ign switch is just a little plastic thing that slides in the back of the tumbler assembly. Look at autohausaz.com and find it, should be a picture of the exact part.
Posted: Mon Sep 10, 2012 6:02 am
by WOMBAT
Win, thanks! Ordered a switch and a coolant expansion tank so that Nick would stop giving me a hard time about my engine bay being ruined by my yellowish cloudy one.
Posted: Mon Sep 10, 2012 6:52 am
hahaha good purchase
Posted: Fri Sep 21, 2012 10:07 am
by WOMBAT
Ign switch didn't help... Oh well.
Does this mean my injector o-rings are bad? Me thinks so.
Posted: Fri Sep 21, 2012 1:37 pm
by WOMBAT
And I think I found my instrument cluster problem...
Anyone have a cluster I can scavenge for parts?
Posted: Fri Sep 21, 2012 1:45 pm
by amd is the best
I do I believe.
Posted: Fri Sep 21, 2012 8:25 pm
by EDIGREG
lol yep that would be it. Looks like you found the source of your mystery smoke.
Hey BTW where did you buy the material you used on the underside of the hood?
Posted: Sun Sep 23, 2012 4:49 am
by WOMBAT
WOMBAT wrote:I bought it online through Autozone - It was the cheapest quantity with a decent heat rating. I had to put down $23 for some good 3M spray adhesive made for this application though.
Here's the hood insulation info!
Posted: Sun Sep 23, 2012 4:52 am
by WOMBAT
amd is the best wrote:[/quote]I do I believe.[/quote]
Ooo - bring to H2O?
Posted: Sun Sep 23, 2012 5:24 am
by VWAP Swap
I had one too... I'll see if its kicking around at the shop, or if it got tossed...
Posted: Sun Sep 23, 2012 5:26 pm
by WOMBAT
VWAP Swap wrote:[/quote]I had one too... I'll see if its kicking around at the shop, or if it got tossed...[/quote]
Awesome, let me know! Finally finishe clay bar and wax today.. So worth it! Also made a trip to NH and back without a problem. 1000 miles done! Time for oil change!
I have a Dyno appointment on Wednesday 8)
Re: Casey's 200 20v: Dyno set for Wednesday - I promise Vids
Posted: Mon Oct 01, 2012 3:50 pm
by death 4kqt
dude.........umm...update?
Posted: Mon Oct 01, 2012 5:39 pm
by 85oceanic
Ya what the heck? Where are the promised vids????
Casey's 200 20v: Dyno set for Wednesday - I promise Vids!
Posted: Tue Oct 02, 2012 3:16 am
by WOMBAT
I know! I'm sorry.... Been spending every waking free moment with the car to have it ready for this past weekend. I'll have an update after work today! In the meantime, some photos from Joel Boucher!
The ride down
Re: Casey's 200 20v: Dyno Update 10/2/2012
Posted: Tue Oct 02, 2012 3:46 pm
by WOMBAT
Long overdue update
The 200 now has nearly 2,000mi on the new engine and it has been trouble free! I do have a leaky cam seal though and my steering rack is starting to drip so I'll have to grab a new one soon. I'll need to rethink my catch can as it currently gets pummeled with rain which makes for gross oily streaks on everything behind it.
Took the car to the dyno (VEMS Colchester, VT with Jason Russel - Highly recommended!) last Thursday to get it tuned before the long trip to Ocean City, MD for H2Oi. It performed perfectly and the only problem was that I neglected to check my wastegate spring, which resulted in us finding out it was still stock :slap: so I could not build more than 18PSI on open loop boost control, tapering to 15 or so by redline. Due to this, peak power was at 5,750RPM with 16psi netting me 265WHP and around 280WTQ. Sadly far less than I was expecting, but I have a 2.2Bar spring on the way and will try again 8)
Was only 1 of 2 T44 Audis at the show, the other being Nick! He took home 3rd in the Mild Audi category, congrats to him! And now some pics and vids....
This one's for you Nick!
On the Dyno
Results
Videos - Go eBay header!!
https://www.youtube.com/watch?v=4iCot-P ... ature=plcp" onclick="window.open(this.href);return false; ... ature=plcp" onclick="window.open(this.href);return false;
https://www.youtube.com/watch?v=arFDXa3 ... el&list=UL" onclick="window.open(this.href);return false; ... el&list=UL" onclick="window.open(this.href);return false;
At H20 with Nick
Cleaned up for the show
Posted: Tue Oct 02, 2012 10:14 pm
by busmn280
Wow Casey!
That is one CLEAN and very tastefully modded T-44! I really like your car's stance and the V8 bumper looks like it belongs on there. I can only hope that I can get my 200 as well-sorted and looking as sweet as yours. You have definitely set the bar very high for old school Audi owners!
Posted: Wed Oct 03, 2012 6:38 am
I agree, we should start a T44 mafia here. Your 200 is gangsta right now! To think you were so down on it only a few months back. All you have to do is drive one of these cars and you fall right back in love :) Looking forward to seeing results with more boost!
Posted: Wed Oct 03, 2012 7:12 am
by WOMBAT
Haha thanks guys! Yea it will probably have to wait until spring for more boost but it will be awesome!
Not quite gangsta status yet - need to get that aggressive stance back with some 18x10's all around 8)
Posted: Wed Oct 03, 2012 9:45 am
by busmn280
18x10's? What wheel/tire/offset combo would actually fit? Inquiring minds want to know!
Posted: Wed Oct 03, 2012 9:50 am
by 123quattro
18x10? 255s on 17x8 ET35 rub mildly out back.
