Page 36 of 62
Re: 4 FOX SNAKES - project suspension underway
Posted: Sat Feb 15, 2014 10:05 pm
by glibobbo21
the seals dry up and shrink. dont get too excited;-)
Posted: Sun Feb 16, 2014 8:59 pm
Omg. Found this today
Don't see it? How about now...
Yes, missing a bolt and all loosey goosey. I don't know how I didn't notice anything.... I had my family in this car! Scary as hell to think about.
Other than that she's up on the hoist, wheels off, ready to be disassembled and made awesome. I need one ball joint and two CV boot, both front, one inner one outer. I may also pick up new rear tie rod assemblies, gonna think about that one for a bit but it makes sense to just do it all once and only pay for one alignment.
Posted: Sun Feb 16, 2014 9:02 pm
by vt10vt
Have had a couple mechanical moments like that too, glad you caught it and it didn't do any damage! I'd say, if you can, drop the extra money on the rear tie rods. Like you said, do it once, and you're going to absolutely love how it drives with all that nice new rubber and poly so might as well make it so you don't have to touch it again!
Posted: Sun Feb 16, 2014 9:19 pm
This is why buying a used car can be scary. I didn't touch the brakes but have only put like 5-7k km on the car. I am thinking I agree with you Shawn, they're only 66 bucks each.
Posted: Sun Feb 16, 2014 10:01 pm
Sigh, another order. lol. Now I will have literally everything but the inner cv boot kit (including front outer tie rod ends). It should feel like a brand new car.
Posted: Mon Feb 17, 2014 10:10 am
by highlander69
Looking great !!
We're going to have a fun drive to Carlisle this year !!
Cheers,
Craig
Posted: Mon Feb 17, 2014 9:41 pm
Squeezed an hour in at the shop tonight, so the front subframe/CAs/swaybar came down. All it'll need is a basic cleaning, the subframe is so cute and light compared to the C4 chassis. The old swaybar bushings are garbage. Actually, all of the bushings are pretty cracked and dried out or all split up. The control arm bushings MAY have been replaced some point because they looked best.
It's nude!
Posted: Tue Feb 18, 2014 12:03 am
by 85oceanic
Looking good man! Keep up the good work. BTW I ALWAYS put either blue or red on caliper carrier bolts. It's not worth the risk of having them loosen up, even if they are torqued to spec, I've seen the aftermath of them coming off cars, not pretty.
Posted: Tue Feb 18, 2014 8:25 am
That's a good idea. Will be doing that for sure.
Posted: Tue Feb 18, 2014 9:26 am
by 20VAvant
chaloux wrote:It's nude!
Dude! NSFW....
I also had the exact same problem with the caliper after I bought it. I had driven around for a few hundred miles and the first time I took the wheels off I noticed the caliper was wobbly, luckily my bolt was hanging in the caliper. I second with Ben and always put blue Loctite on mine now.
Oh, and the car looks incredible btw..
Posted: Tue Feb 18, 2014 11:58 am
by themagellan
chaloux wrote:Omg. Found this today
That is pretty wack, complete carelessness on someones part. Might be worth printing out a lengthy default inspection and going through everything (read do it)
Posted: Tue Feb 18, 2014 4:06 pm
There has been some scary shit found in this car. if you recall, the same side lower ball joint was totally loose and would shake like crazy at 70mph, which is probably what caused it to fail. Then stuff like the alternator pulley being half mounted, the 60-2 wheel being barely attached with one tiny screw holding it, the seats not having the gliders and moving around... lots of "Git'r done fix it later" type stuff. But the ball joint and caliper are the worst. Which is why I'm now quite glad I'm essentially disassembling the entire suspension and driveline.
Thanks for comments. I hope to have this stuff all wrapped up in a couple weeks of an hour here and there. I really love that this car wasn't winter driven. The bolts just loosen, it's like magic.
Posted: Mon Feb 24, 2014 8:20 pm
Hey look, a box of boxes and stuff! This completes my suspension rebuild... rear tie rod assemblies, front tie rod ends, fuel filter, ball joint, cv boot kit, and two new door handles! Plus some bushings/strut mounts for my jetta.
Removed the front subframe bushings a few days ago. Control arms up next, then strut mounts. Then rear. And then, and then, and then... lol. More pics less text next time.
Posted: Mon Feb 24, 2014 11:19 pm
Aaaand we're back again. Also have a 7a fpr incoming from Dana.
When bumping the fuel pressure, should I just recalculate req fuel based on the injectors being 727cc instead of 630cc (listed right on the VEMS site, dats handy)? I think that'd be much easier than redoing the ve table. Especially since they're the same injectors, I shouldn't have to go through anything peculiar.
Posted: Tue Feb 25, 2014 8:54 am
by mushasho
I just did this last night... 2200/5/(3bar injector flow in cc) ... Then multiply that figure by 6.49 ... Then Marc states "To allow for finer grain fuel control I usually use 75% of this calculated number."... That I don't know why but I'm sure he did this to your base setup... So use 75% of that figure...
Posted: Tue Feb 25, 2014 9:07 am
Yeah I'm familiar with the req fuel calculation. So you just use the 3 bar flow value even though I'm using a 4bar fpr?
Posted: Tue Feb 25, 2014 9:10 am
by Marc
mushasho wrote:I just did this last night... 2200/5/(3bar injector flow in cc) ... Then multiply that figure by 6.49 ... Then Marc states "To allow for finer grain fuel control I usually use 75% of this calculated number."... That I don't know why but I'm sure he did this to your base setup... So use 75% of that figure...
basically, you want your VE table numbers "centered" around 100 or so. the values have a minimum of 0 and a maximum of 255, so if your req_fuel is too high or too low you'll be bumping up against those limits in your table potentially.
Posted: Tue Feb 25, 2014 2:44 pm
by AngryTaco
just turn the boost up if you are running rich
Posted: Tue Feb 25, 2014 6:29 pm
AngryTaco wrote:just turn the boost up if you are running rich
I'll be able to now with my .82!
Posted: Tue Feb 25, 2014 7:04 pm
Holy crap. The volute in the Garrett .82 is HUGE. Mos def visually larger. Plus I can go hand deep in'r. I'm so stoked. I'm gonna pick up some new stainless hardware though... Lol. Pics to follow
Posted: Tue Feb 25, 2014 7:30 pm
by AngryTaco
generally hand deep is a sign of usage. Stay away! The tighter the more funner!
Posted: Wed Feb 26, 2014 11:59 am
by Marc
fisting your turbine housing? whatever does it for you man.....
Posted: Wed Feb 26, 2014 12:49 pm
by EDIGREG
lol. wtf matt get it together
Posted: Wed Feb 26, 2014 3:19 pm
by AngryTaco
LMAO ^^
Matt, I am very curious to see how the .82 housing acts for you. It will definitely influence my next turbo purchase since I'm shooting for some pretty radical numbers
Posted: Wed Feb 26, 2014 9:47 pm
Always go .82. I have a feeling I'm going to like my car very much this summer. Unless it is a stupid piece of shit, which is always possible for this thing. lol
