It's just a matter of playing with the lambda at 1v and lambda at 0v settings. Make the car run rich, and adjust the 0v field, make it run lean and adjust the 1v field. keep doing that until the zeitronix and 034 ecu read the same. Mine is spot on at stoich, and within a few tenths at the far end of rich nd lean.
Nothing to see here sir. So the good new is I just got back from the smug station. I failed the test because of to much HC, but passed the visual :woowoo: I forgot they don't test for Nox in CA, so I'll be going back to the same station with a lean running car. How did I pass visual you say? Here's some of the latest work.
djapothecary
Chad T
TheArchitect
Careful now, they DO test for NOX in California.audifreakjim wrote:Nothing to see here sir. So the good new is I just got back from the smog station. I failed the test because of to much HC, but passed the visual :woowoo: I forgot they don't test for Nox in CA, so I'll be going back to the same station with a lean running car. How did I pass visual you say? Here's some of the latest work.
Retard your timing, lean it up THEN it should pass.
Good to know, I guess they only printed out the things that failed, I was to high on CO in the 2500rpm test which just says I'm running to rich even at 14.7:1. I'll retard the timing 10 degrees and try 15.5:1
Seriously, I've taken the car from wow factor to blah factor. Still moves the same though :-D
TheArchitect
Where did you end up in CA jim?audifreakjim wrote:Good to know, I guess they only printed out the things that failed, I was to high on CO in the 2500rpm test which just says I'm running to rich even at 14.7:1. I'll retard the timing 10 degrees and try 15.5:1
San Clemente, it's a nice down here.TheArchitect wrote:Where did you end up in CA jim?audifreakjim wrote:Good to know, I guess they only printed out the things that failed, I was to high on CO in the 2500rpm test which just says I'm running to rich even at 14.7:1. I'll retard the timing 10 degrees and try 15.5:1
mdg3369
TheArchitect
Yeah could be the 4WD cars have a different procedure, Ive never had to test one.mdg3369 wrote:As of a few years ago, they only tested CO and HC on AWD cars. The 2wd cars get a NOx test on the dyno. Failed on HC once in the QSW, leaned the sucker out so much it would hardly run and passed with 0.000 on everything :-D
Thats pretty slick. Nice work on hiding the goods
I remebered you saying that as I was driving home and proceeded to kick myself the rest of way home.mdg3369 wrote:As of a few years ago, they only tested CO and HC on AWD cars. The 2wd cars get a NOx test on the dyno. Failed on HC once in the QSW, leaned the sucker out so much it would hardly run and passed with 0.000 on everything :-D
s2 on the way
I think its still got the wow factor completely.......I'm lovin the supersleeper.
looks so nice n tidy....
and as you said, it still goes
are you passing emiss with no cat?
ps. in cali, since the emissions isnt' run by the state, but by private shops, I know there are many shops that work on the tip basis if that would be needed...
