Posted: Tue Nov 22, 2005 12:19 pm
Who has a torque plate for the 5 cylinder? The local machine shop has one for a 4cylinder vw that I'm tempted to have them use on my audi.
Justin
Justin
Do this, just have them move it for every new cyl...olsonjus wrote:Who has a torque plate for the 5 cylinder? The local machine shop has one for a 4cylinder vw that I'm tempted to have them use on my audi.
Justin
Nice, haven't seen those yet. Yea, I think for now 7500, maybe 7800 depending on how it acts on the dyno will be a good goal.olsonjus wrote:That sounds reasonable. When you have the money, do some Ti Retainers and HD springs.
http://www.034motorsport.com/product_in ... cts_id=357 ... cts_id=357
Regards,
Justin
Looking forward to seeing how the PS pump works... where is it mounted... low and to the back I hope!audifreakjim wrote:A little update, <clip>. Also got the MR2 PS pump in, but have yet to wire it up so pics of that will be coming later. <big clip>.
It's actually where the ABS unit used to be. I was looking at mounting it like Javad has his, but the stock radiator shroud is kinda in the way. it turned out really well. I'll get it wired up and take some pics.WAUG0806 wrote:Looking forward to seeing how the PS pump works... where is it mounted... low and to the back I hope!audifreakjim wrote:A little update, <clip>. Also got the MR2 PS pump in, but have yet to wire it up so pics of that will be coming later. <big clip>.
Well, with your same setup (well, stock lifters, not afc) and HD springs I hit 8000 NO problem, I say you get the springs and let it rip, especially since changing them in the future is a biatch,and nothing like revving another 500 rpm to make the most of a big turbo.audifreakjim wrote:Ok, so given the head specs, how high should I look at setting my rev limiter?
7A cams
Stock springs
LW AFC lifters
7500 rpms?
Or should I just dig even deeper and buy some HD valve springs. I feel like I may only gain a few hundred rpms before the hydro lifters crap out so is it worth it?
Here are some: http://www.80tq.com/gallery/Progress052904WAUG0806 wrote:Hey Javad -
Do you have pics of your electric PS system, comments on how it works, feels?
Did you ever try to get the 034 output to shut it down at speed, or is it fine just hard wired to the power?JShadzi wrote:Here are some: http://www.80tq.com/gallery/Progress052904WAUG0806 wrote:Hey Javad -
Works wonderfully, feel is less assist than stock, buttery smooth, and all the room at the front of the motor makes me smile
Yea, definitely considered it for a GPO, but frankly the best option would be wheel speed, and I haven't gone through the effort to set that up.WAUG0806 wrote:Did you ever try to get the 034 output to shut it down at speed, or is it fine just hard wired to the power?
I guess it must work pretty well or Jim would not be planning to run it!
Ok, gotta ask, do you stock the springs yet?JShadzi wrote:Well, with your same setup (well, stock lifters, not afc) and HD springs I hit 8000 NO problem, I say you get the springs and let it rip, especially since changing them in the future is a biatch,and nothing like revving another 500 rpm to make the most of a big turbo.audifreakjim wrote:Ok, so given the head specs, how high should I look at setting my rev limiter?
7A cams
Stock springs
LW AFC lifters
7500 rpms?
But of kourse 8)audifreakjim wrote:Ok, gotta ask, do you stock the springs yet?JShadzi wrote:Well, with your same setup (well, stock lifters, not afc) and HD springs I hit 8000 NO problem, I say you get the springs and let it rip, especially since changing them in the future is a biatch,and nothing like revving another 500 rpm to make the most of a big turbo.audifreakjim wrote:Ok, so given the head specs, how high should I look at setting my rev limiter?
7A cams
Stock springs
LW AFC lifters
7500 rpms?
