Posted: Mon Oct 09, 2006 6:30 am
JShadzi wrote:Just to jump in here, there in no one in the country with more experience installing and supporting customers with these KKK/GT turbos. We've done at least 5 installs here in shop, and have supported and spoken with dozens and dozens of customers here in the states and worldwide during the install of these turbos.
While the physical positioning is slightly different than the original KKK housing, we've had no problems installing OEM, 2Bennett, our own 034 and other custom downpipes onto this turbine housing, the only modification that is required is the removal of the CV heat shield.
Marc expressed difficulty in making the Stromug system fit with this turbine housing, so it could be something specifically different about the Stromug system that causes fitment problems in this particular application.
However we want to be clear, we haven't seen this problem with other, "non-Stromug" downpipe applications as of yet. With that said, astromug specific fit would definitely be interesting.
HTH,
getting back to this thread WRT turbo fitment issues on the GT hot sides. It _is_ possible that I could have gained back some of the flange alignment by losening the turbo nuts and cheating the pipe over and down a mm or two. When I ran into the tie rod issue I gave up trying to fight the positioning problem since I knew I was going to have to reweld the downpipe anyway.
Appologies to Javad/034 Motorsport and Jeff/Stromung.
