Page 4 of 4
Re: Kenny' s B3 Coupe Build
Posted: Sat Apr 04, 2020 3:38 am
by morris400
Got my block back from machine shop # 2. They were able to remove most of the imperfection/scratch/gash in cylinder 5. Its alot better now. Piston #3 will become a spare, #5 will move to cyl 3 and a new OEM piston with a .003 thick microslick coating will become #5 to get the correct piston to wall clearance.
Posted: Sat Apr 04, 2020 8:33 am
by Afterthought
Do you by chance remember the length of battery cables you used ?
Posted: Sat Apr 04, 2020 10:59 am
by morris400
Afterthought wrote:Do you by chance remember the length of battery cables you used ?
20in of negitive and 192in of positive. Probably 2ft more then i needed for positive
Posted: Sat Apr 04, 2020 11:32 am
by Afterthought
Ok , thank you! One of the next things I need to do on mine .
Posted: Mon Apr 06, 2020 8:01 pm
by morris400
Posted: Mon Apr 06, 2020 9:06 pm
by jbrentd
Nice! That’s gonna look good.
Posted: Tue Apr 07, 2020 1:21 pm
by morris400
All I need now is someone to do all the wiring for me and ill be set lol, I hate wiring.
Posted: Sat Apr 11, 2020 12:25 am
by morris400
Got the wastegate cap back today, and the oil pump so i get that rebuilt. Really loving the powdercoating thing. The quality from my local shop is out standing.
Should have the crank and rotating assembly in tomorrow.
Posted: Sat Apr 11, 2020 9:59 pm
by morris400
Well, crank is in its home now. Calico coated bearings, OEM main bolts ( i have ARP but a line hone was $$$) OEM thrust washers.
Everything is well within Spec. 0.051 and 0.038 on the mains. Thrust clearance 0.023-0.025.
Tomorrow i pick up the 5th overcoated piston and can start getting the reeast of the assembly together. Need to start clearing space on my bench.
Posted: Fri Apr 17, 2020 12:03 am
by morris400
Posted: Mon Apr 20, 2020 9:15 am
by morris400
Posted: Mon Apr 20, 2020 8:30 pm
Holy hell that does look like a new head. Nice work.
Posted: Tue Apr 21, 2020 12:47 am
by morris400
Got the head build today. Bolted the exhaust manifold on as well. Cams go in tomorrow, waiting on a new chain.
Head was Vapor Honed at Strongarm cylinder heads in Panoka Alberta. Guy does amazing work. He made the head look OEM new again.
I assembled the head at home
Ferrea 6000 series valves ( intake and exhaust)
New INA 64g lifters. ( not the LW ones)
Stock springs
Stock retainers
Wagner manifold
034 hardware kit ( no turbo studs...come on 034!)
Posted: Wed Apr 22, 2020 12:46 am
by morris400
Posted: Mon Apr 27, 2020 9:49 pm
by morris400
Posted: Tue Apr 28, 2020 8:47 pm
by cuatrokoop
Looks good!
Posted: Sun May 10, 2020 3:45 am
by sayoda
Great work, powder coating looks awesome!
Posted: Mon May 11, 2020 12:11 pm
by morris400
Thanks guys, progress has slowed down a bit for sure. COVID has made some things really hard to get done. Need to send my fluidamper to Jeff to have it machined a bit. Currently working on getting the accessories bolted up and hope to have the engine dropped in the car soon.
Got the 034 intake spacer mounted ( had to fine some of the powder coating off the intake manifold)
Posted: Wed May 20, 2020 12:17 am
by morris400
Well, another project come to an end. The Coupe sold today to a good friend locally. He took the Coupe, all the Euro parts, custom harness, S2 suspension and intercooler. All the 3B intake parts and so on. AAN and 7A blocks as well.
For me this project became to much and i had to move on. Im glad it will go on to live in another enthusiast's stable. He owns a Silver coupe that hes doing an AAN swap and that car will get all the good AAN parts. This coupe will return at some point to a solid 7a car.
I will be keeping the engine i built and be putting that in my Urs4 thos summer instead.
The end of this project, but the Urs project will continue.
