Page 4 of 4
Re: Eric's 07K dumb questions thread
Posted: Mon Feb 27, 2017 1:22 am
Very true about sealing it up. I got the flywheel balanced.
Also, one word of advice. They are modified 034 flywheels which means they have the shitty ass starter ring. Replace it with a factory 7a or similar.
Posted: Mon Feb 27, 2017 7:10 am
by elaw
Ah... that would explain why it came in an 034 box!
What's the problem with the ring gears? I was pretty surprised to see it had holes drilled (and tapped) through it... is that the issue? It looked to me like those holes would reduce the gear's strength quite a bit as they take up so much of its cross-sectional area.
Posted: Mon Feb 27, 2017 12:11 pm
The holes are the problem. The gears fracture and blow up into 4 different pieces. Plus the teeth like to sheer off
Posted: Tue Mar 07, 2017 7:21 am
by gabriel.b
audifreakjim wrote:Very true about sealing it up. I got the flywheel balanced.
Which flywheel does he start with? the 7a or one for a transverse 07k?
Posted: Tue Mar 07, 2017 7:28 am
by elaw
Posted: Tue Mar 07, 2017 12:12 pm
Yeah, that's it. It's cheaper to buy it from Hank modified and ready to go.
Posted: Wed Mar 08, 2017 5:56 pm
by gabriel.b
audifreakjim wrote:Yeah, that's it. It's cheaper to buy it from Hank modified and ready to go.
Thanks.
Im about to put in an order to hank, and I am wondering if you are happy you went with the top exit intercooler?
I notice that the intake he made you is not the regular one he sells online
Posted: Fri Mar 10, 2017 12:22 pm
I really like the vertical flow, it's been rock solid. Hank made a vertical flow work with one of his standard intake manifolds on his car. The end tanks are a bit more custom, but it came out great. He also had to offset the radiator with a small frame rail notch. It works well and allows you to also use the stock accessories.
Posted: Sat Mar 11, 2017 10:54 pm
by ChrisAudi80
audifreakjim wrote:I really like the vertical flow, it's been rock solid. Hank made a vertical flow work with one of his standard intake manifolds on his car. The end tanks are a bit more custom, but it came out great. He also had to offset the radiator with a small frame rail notch. It works well and allows you to also use the stock accessories.
Such porn :drool:
