Easy way to swap rear diff bushing without press?
Kuma
Re: Suspension rebuild- Soon to begin- waiting on SF bushing
Post by Kuma »
As of yesterday, I started working on my coupe. The trans bracket that was broken was a pain to get off. One of the Allen key bolts was stuck and stripped. So I hammered it off after removing three out of four bolts. I was careful not to whack the transmission. The bushing that is on the trans bracket was not on the one Dave K. Gave me, so I had to squish it out of the old one and in on the new one.
I am tired, so I took a break for today.
Tomorrow, I will start again.
Kuma
Post by Kuma »
i go the passenger side finished today. what a pain in the ass. I was lifting the subframe up with one arm and trying to put in the bolt with the other... anyways, got the new bushings on and bam. looks pretty good for a first time.
i had to swap the bushing on the trans mount to the new one I got from dave since it didnt come with one.
I had to press it out, and then i used dish soap to squish it back in.
stupid trans mount.
Kuma
Post by Kuma »
Yeah! Went and got new bolts. It tired of waiting. I'm gonna put the car together cause I need to drive it to school.
My alignment will have to wait. Not enough monies, unless something sells.
Re: Audi Coupe - front suspension almost finished - rear nex
Glad to see it going back together! Make sure to check the subframe bolts after you drive it a little. The aluminum mounts will settle, and the bolts could loosen up some. I don't want to see you loose any bolts while driving as I have heard others do.
Kuma
Post by Kuma »
Roof rack and front suspension done.
Had a fuel leak, apparently, but i fixed it. it was a dry rotted line. I need to adjust the idle again.
Kuma
Re: Audi Coupe - front suspension done! rear next
Post by Kuma »
Well, the ass end still wiggles around, so I'm gonna need to fix the back soon.
Idle is really high and comes down hella slow.
Kuma
Post by Kuma »
RAH.... i kinda sorta fixed the idle and the slow RPM drop. must be a vacuum leak somewhere still....
FUCKKkwnekhosidhgfoishdfoihasfgasfdjknasfklvnaksjv
Anyways, I NEED to get a new Rear diff bushing mount thingy. the one i mentioned in pages passed...
everytime i shift the rear of the car goes *clunk*
its awful.
Kuma
Post by Kuma »
roof rack done!
possible custom fairing?
showing off my Steekers and others
marking things off my list.
Kuma
Post by Kuma »
GRRRR. i hate doing rear subframe stuff... this shit is irritating.
ALMOST done.
for whatever reason the rear bolts for the subframe will not go all the way in. I am thinking that the subframe may be offcenter. gonna finish up today. hopefully i can get my alignment done today as well.
bushings were easier to knock out this time, but still was a pita.
i also forgot to order new rear diff mounts... one was in good shape, but the other was FUBAR. I dont have time to wait on ordering another one so i RTV siliconed the SHIT out of it. Yeah bad idea, but it is solid again and will have to do until i get more money to replace parts. when i replace the rear diff bushing, ill replace it then.
Kuma
Post by Kuma »
I get the rear subframe put back together and drop the car back down for a test drive.
Roll out of the driveway and drive a few houses down and CLANG!!!!!! Crackle crackle crackle!
Wtf now?!!
I'm thinki g great my trans or my diff finally went out at the most random time. But luckily it was just a rear axle inner cv breaking apart. Yay me.
I'll post some pics later.
Thanks to Aaron, Dave K ,and Derek W for offering pro advice.
Kuma
Re: Audi Coupe -Suspension DONE! then, my axle broke... ugh
Post by Kuma »
150$ for someone to rebuild my axle for me. But i dont have 150$ so im looking to Chris Semple to see if he has one for me for cheapies.
my exhaust has been hanging down and it had a hole rubbed through it with the axle...
i am thinking about utilizing the space here to make a side exit exhaust, using my borla muffler.
Kuma
Post by Kuma »
Chris Semple at Force5auto is the shit! got me all set with a inner joint kit.
phew! i just have to redo the axle joint and then i am all set!
i really need to get my car back together cause i need it for school.
Kuma
Re: Audi Coupe -Suspension DONE! FINALLY
Post by Kuma »
RAHHHHH
finally fixed the axle. I got the axle joint from a different axle from Chris Semple. I had to remove the joint then swap it out with the other one.
Car is much tighter.
i am waiting for a paycheck from working at The Circuit of Americas for the Moto GP Grand Prix this weekend.
Saw Bufkin at the race too with Brooke.
Very cool to see people i know.
Anyways. i am just happy i am finished with the suspension finally. Now i need new tires
Kuma
Post by Kuma »
At the alignment place. Yay. I finally can feel like my car is safety drive again.
I need to do valve cover gasket and fuel filter
Kuma
Post by Kuma »
well, got the alignment, but it still feels quite off.
Did you have a full tank of gas when you took it in? That does make a difference. I also see you took it to a tire shop, and not a dealer to have this done. Having worked at a tire shop, doing alignments, the machine they are using might not be the greatest. The dealer will have the specialty tools, and a high end rack to do the work on.
What kind of guarantee did you get with this alignment?
Kuma
Post by Kuma »
No full tank. I fill it up after I had the alignment.
I was gonna go to the dealer, but they were backed up and I didn't really have any other time this week to drop it off. On Thursdays I have school from noon till 1800.
The steering still feels really loose.
I know it sounds kind of dumb, but having a full tank will make a differance when getting these cars aligned. I talked to the local dealer, and was told specificaly to have a full (or very close to it) tank when I bring it in.
I hope you arent having a problem with your rack!
Kuma
Post by Kuma »
That would have been good to know before hand, lol.
Kuma
Post by Kuma »
the coupe drives well, but it started to lurching. I think that i might have a vaccuum leak again.. but i dont know why. i replaced all the hoses and its still driving like ass.
what are some things that can cause the car to do things like this.
*lurch*lurch*lurch*lurch*lurch*lurch*lurch*lurch
it almost feels like its not getting enough gas, then the throttle gets all crazy, ill get a TON of gas at one time then not enough the next..
now that i think about it. I think my fuel pump is taking a shit.
FUCK FUCK FUCK FUCK FUCK
and i still havent swapped the fuel filter...
Still need:
Fuel Filter
Fuel Pump
Replace the strut tower mounts ( have two new ones already)
Replace the Rear Diff bushing
Kuma
Re: Audi Coupe-new primer and matte black paint SOON
Post by Kuma »
So my outer cv joint started clicking g last night. Good thing I just got new boots, So those will go on today.
Also working on making my car have a side exhaust, yay borla xr1.
Kuma
Post by Kuma »
crazy rain today. modded my car with a few gallons of rain water.
El Guapo
Post by El Guapo »
check ALL of your vacuum lines, not just the ones in the engine bay. Look under the rear seat as well.
Kuma
Post by Kuma »
ahhhh, thats a good point. Never even though of that. Thanks for the tip.
Kuma
Post by Kuma »
Today, I removed the rear part of the exhaust that goes over the rear axle.
The bolts were so tight that they twisted and broke off.
But at least there is no more buzzing sound.
My buddy and I are going to be rebuilding an exhaust with my borla xr1 muffler. Side exit most likely.
