Page 3 of 82
Posted: Tue Jan 25, 2011 6:38 am
by amd is the best
xileh wrote:Nice car. May I ask where you got that M3 lip on the trunk?
Thank you! It's a universal M3 lip spoiler thats 50.5in long: http://cgi.ebay.com/ebaymotors/50-5-Inc ... 4717wt_939" onclick="window.open(this.href);return false; ... 4717wt_939
Re:
Posted: Tue Jan 25, 2011 6:42 am
by xileh
amd is the best wrote:[/quote]
Thank you! It's a universal M3 lip spoiler thats 50.5in long: http://cgi.ebay.com/ebaymotors/50-5-Inc ... 4717wt_939" onclick="window.open(this.href);return false; ... 4717wt_939[/quote]
Did you have to cut it, or is the size good? Don't know how wide the trunk on my car is :o
Re: Re:
Posted: Tue Jan 25, 2011 6:48 am
by amd is the best
Did you have to cut it, or is the size good? Don't know how wide the trunk on my car is :o[/quote]
The trunk is exactly 50.5. Perfect fit!
AMD's 91 200q Project
Posted: Wed Jan 26, 2011 7:27 am
by amd is the best
Pulled the trigger last night on the turbo :)!
Standard GT3076r, braided line oil/water kit, silicone intercooler hoses and a wastegate spring.
Tax return = VEMS, coils, external LCD display and hopefully injectors.
In the meantime I am cleaning up the engine bay and trying to resolve the hydraulic systems leaks.
More pics to come.
Re: AMD's 91 200q Project
Posted: Wed Jan 26, 2011 9:36 am
by McBitchin
very nice nick!!
Posted: Wed Jan 26, 2011 10:11 am
by WOMBAT
That's an awesome plan! (a bit jealous 8) )
Posted: Wed Jan 26, 2011 10:17 am
soo...by standard gt3076, do you mean a hybrid one that will bolt up to stock mani or are you getting a different manifold?
Posted: Wed Jan 26, 2011 1:13 pm
by amd is the best
McBitchin wrote:very nice nick!!
Thanks man!
WOMBAT wrote:That's an awesome plan! (a bit jealous 8) )
Jealous??? Yours is far sweeter! But thanks man!
loxxrider wrote:soo...by standard gt3076, do you mean a hybrid one that will bolt up to stock mani or are you getting a different manifold?
I got the K26/GT3076r hybrid to bolt on to the stock manifold just for cost savings and convenience at this point. Come this winter I'll swap out the housing for a Tial V-band and have a manifold built. Should still be pretty bad ass!
Posted: Wed Jan 26, 2011 1:15 pm
by WOMBAT
![/quote]
mine has a completion date much farther out than yours :( Thanks for the compliment, but your car looks dayum clean!
Posted: Wed Jan 26, 2011 1:22 pm
I see, not a bad plan. I like it
Posted: Fri Jan 28, 2011 6:03 am
by amd is the best
I've been working on cleaning everything as thoroughly as possible. Changed the timing belt, water pump, idler pulley and thermostat. De-greased all sorts of brackets, clamps, bolts, and coolant pipes. Painted a bunch of little covers and brackets satin black. Left the aluminum pieces raw. Also had the flywheel resurfaced and ordered a few fittings for the oil cooler and bolts from the dealer.
Still more cleaning to be done but here are a few pics:
Flywheel back from the machine shop:
Engine before cleansing:
New timing treats installed:
Timing all buttoned up and significantly more clean!:
Still more cleansing to do but MUCH better:
Thanks my Dad making custom tools for all these crazy Audi projects!
Slide hammer to remove timing idler and crank pulley lock tool:
Machining the crank lock too:
Turbo is in the mail along with the braided lines/fittings, silicon charge hoses and a wastegate spring (1.9bar). Next Friday (payday :)) I am ordering the VEMS ECU, wideband, coils, external display and injectors.
Anyone know where/how to get a direct replacement 4bar fuel pressure regulator?
Posted: Fri Jan 28, 2011 8:17 am
nice! I believe the AAN uses 4 bar FPR no?
Also, I don't know what that wg spring will put you at for boost (presumably around 13 psi), but that might be too much for stock injectors on a turbo that size even with 4 bar fuel pressure. You'll see when you go to tune though. I'd suggest just keeping your stock wg spring in there. Its plenty good for as much boost as you want and good spool especially with the ability to play with the PID settings in VEMS.
Posted: Fri Jan 28, 2011 8:20 am
by death 4kqt
aan FPR is totally different. Its like the 1.8t style drop in regulator. Wont really work on a 3b setup.
Posted: Fri Jan 28, 2011 8:22 am
oh nevermind then
Just get some injectors sucka! They shouldn't cost much more than a new FPR unless you get one from the jy or used or something
Posted: Fri Jan 28, 2011 8:28 am
by death 4kqt
i think you might be able to fit a 7a fpr to the 3b, and I think it will increase the pressure under boost. Might be worth checking into.
Posted: Fri Jan 28, 2011 8:33 am
by amd is the best
That WG spring should be good for a min of 14-15psi which would absolutely be pushing the stock injectors. I plan on getting some Siemens 60lb's or 83lbs for injectors when I order the VEMS but I also wanted to bump the pressure if there was a drop in solution like the 1.8t, 2.7t etc... If not, no big deal.
Posted: Sat Jan 29, 2011 1:17 pm
by amd is the best
No big updates but I wrinkle coated the valve cover:
Turbo and other 034 treats will be here next Friday and that's also the day I order the VEMS, coils, external LCD display, wideband and injectors.
Posted: Sat Jan 29, 2011 4:44 pm
you seem very excited...Its so awesome to see another t44 owner so enthusiastic :)
Posted: Sat Jan 29, 2011 5:25 pm
by pilihp2
Excited to see how this turns out as well. I'm addicted to t44 project threads...
Posted: Sat Jan 29, 2011 9:20 pm
by tbar
This is gonna be good!!! keep up the nice work!
Posted: Sun Jan 30, 2011 12:17 am
by auditude
Nice 200q20v man! Great project. Inspiring.
What part number H&R springs are those?
Posted: Sun Jan 30, 2011 8:25 am
by amd is the best
Thank you everyone! I'm getting excited myself!
auditude wrote:Nice 200q20v man! Great project. Inspiring.
Thanks man! They are H&R #29800.
Posted: Sun Jan 30, 2011 9:17 am
by TorqAddict
Nick, I absolutely love this car......tastefully done in every way.
One of my favourite threads.
Posted: Mon Jan 31, 2011 12:56 am
by amd is the best
Cleaned the intake manifold like crazy and wrapped the downpipe today:
TorqAddict wrote:Nick, I absolutely love this car......tastefully done in every way.
Thank you very much! Glad to see other appreciating the T44's!
Posted: Mon Jan 31, 2011 6:28 am
by WOMBAT
Keep it up Nick - looks great! Glad to see you're keeping the 3B valve cover - seems like that's the first to go on these motors and I love 'em
