Alex's 'New' '83 UrQuattro - BBQ X Success
Re: Alex's 'New' '83 UrQuattro
I have some of those mounts too, just installed them . I had to make the holes just a bit wider
T-minus 6 days until I leave for BBQ in Vegas
BBQ 2019 List
Completed:
*951 Intercooler with intake routing
*IIc ECU firmware upgrade and updated timing maps
*Rolled fenders
*3rd brake light
*Poly engine mounts
*Oil change
*Coolant flush
*MC2 cam swap with cam seal
*Passenger mirror change
*Rear brake refresh
*Aftermarket cruise control install
In Work:
*Front brakes (Coleman sent the wrong rotors, correct parts should arrive Monday just in time to leave Tuesday evening)
*New wheel/tire install
To do:
*Test drives
*Fine-tune cruise control
*Install seat-mounted fire extinguisher bracket
Working on installing the new wheels/tires. 16x7.5 ET35 Carlsson by Ronal wheels that I had stripped/powdercoated white. 225/50R16 Continental ExtremeContact Sport tires. Oversized slightly, but a MUCH better tire selection. Currently pictured with a 30mm spacer. I have a 25mm spacer that I think will just barely clear the caliper and give a little more fender clearance. Might also need to run more camber. I've got some adjustable strut mounts for that, but probably won't install prior to BBQ. The car rides high enough (due to downpipe/tie rod interference) and with stiff enough suspension that I shouldn't have issues. Car is begging for some Group 4 flares and mud flaps!
Before refurb:
IMG_20190924_170943 by Vex Art Media, on Flickr
IMG_20191018_153904 by Vex Art Media, on Flickr
Looks like plenty of clearance in the rear
IMG_20191019_123242 by Vex Art Media, on Flickr
IMG_20191019_123237 by Vex Art Media, on Flickr
Front with 30mm spacer
IMG_20191019_112846 by Vex Art Media, on Flickr
IMG_20191019_123328 by Vex Art Media, on Flickr
IMG_20191019_123337 by Vex Art Media, on Flickr
NOS goodies that might go on
IMG_20191019_140938 by Vex Art Media, on Flickr
MC2 cam swap. Wish I knew more about the history of this engine, the head looks damn near new! Curious if it was rebuilt with bigger valves...
IMG_20191019_162127 by Vex Art Media, on Flickr
951 intercooler install. Some people have been able to keep snub mount, but I wasn't. Hopefully the poly bushings are stiff enough. Eventually I'll fabricate some sort of snub. Tight everywhere!
IMG_20191020_132906 by Vex Art Media, on Flickr
IMG_20191020_132927 by Vex Art Media, on Flickr
IMG_20191020_124937 by Vex Art Media, on Flickr
IMG_20191020_150041 by Vex Art Media, on Flickr
Good news, oil cooler and shroud still fit
IMG_20191020_172321 by Vex Art Media, on Flickr
Pre intake routing
IMG_20191020_140409 by Vex Art Media, on Flickr
BBQ 2019 List
Completed:
*Rolled fenders
*3rd brake light
*Poly engine mounts
*Oil change
*Coolant flush
*Rear brake refresh
In Work:
To do:
*Test drives
Before refurb:
IMG_20191018_153904 by Vex Art Media, on FlickrLooks like plenty of clearance in the rear
IMG_20191019_123237 by Vex Art Media, on FlickrFront with 30mm spacer
IMG_20191019_123337 by Vex Art Media, on FlickrNOS goodies that might go on
IMG_20191019_140938 by Vex Art Media, on FlickrMC2 cam swap. Wish I knew more about the history of this engine, the head looks damn near new! Curious if it was rebuilt with bigger valves...
IMG_20191019_162127 by Vex Art Media, on Flickr951 intercooler install. Some people have been able to keep snub mount, but I wasn't. Hopefully the poly bushings are stiff enough. Eventually I'll fabricate some sort of snub. Tight everywhere!
IMG_20191020_150041 by Vex Art Media, on FlickrGood news, oil cooler and shroud still fit
IMG_20191020_172321 by Vex Art Media, on FlickrPre intake routing
Was able to squeeze and oval filter past the BOV and set it behind the grill
IMG_20191022_162651 by Vex Art Media, on Flickr
IMG_20191022_162729 by Vex Art Media, on Flickr
IMG_20191022_163123 by Vex Art Media, on Flickr
IMG_20191022_163159 by Vex Art Media, on Flickr
You can never have enough heatshields on a 20vt
IMG_20191022_185055 by Vex Art Media, on Flickr
Safety first, added a 3rd brake light since I fear getting rear ended. Used a universal one so the angle doesn't match perfectly but it'll do for now.
MVIMG_20191022_132505 by Vex Art Media, on Flickr
IMG_20191022_125602 by Vex Art Media, on Flickr
Rostra cruise with CV mounted VSS
IMG_20191023_152336 by Vex Art Media, on Flickr
IMG_20191022_184026 by Vex Art Media, on Flickr
IMG_20191022_163159 by Vex Art Media, on FlickrYou can never have enough heatshields on a 20vt
IMG_20191022_185055 by Vex Art Media, on FlickrSafety first, added a 3rd brake light since I fear getting rear ended. Used a universal one so the angle doesn't match perfectly but it'll do for now.
IMG_20191022_125602 by Vex Art Media, on FlickrRostra cruise with CV mounted VSS
IMG_20191022_184026 by Vex Art Media, on Flickr-Alex-
Dang Alex, the car is looking badass. I can't wait to see it! Where do you guys keep picking up these NOS mud flaps? I really want a set!!!
25mm spacers didn't work, so back on with the 30mm. Definitely needed some camber for the front tires so I installed my AK Motorsport offset strut mounts. Didn't come with exactly what I needed for the Ground Control hats, but was able to find some hardened washers that did the trick. Supposedly the newer AK mounts come with the right parts, but I got mine during a group buy years ago.
Going to install some spacers on the rear to help even out the stance.
Also raised it up probably 1/2-1" just to be sure it wouldn't rub the fenders. Suspension is pretty stiff regardless, but better to be sure with UrQ fenders!
Not sure how much camber this is, it's with the AK mounts all the way in.
3D printed a scaled up version of the stock Ronal R8 centercap to match the larger bore of the 16" Carlssons. Prototype print turned out nicely, just need to scale it up about another 0.5mm for a better fit and then I'll print 4.
Test drove last night with a rough alignment (getting a real one on Tuesday) and everything is working pretty well. It was pretty laggy with full boost coming on about 750-1k RPM later than before so I need to troubleshoot that. I either have a boost leak or the MC2 cam I thought I installed wasn't actually an MC2 cam. Idles right at 20mmHg so must not be too much of a leak. Going to troubleshoot that tomorrow. Boost leak test and then if all looks fine swap back in the other cam I removed.
Ecstatic about how she looks now! Some Gr4 fender extensions would certainly help complete the look.
IMG_20191025_161524 by Vex Art Media, on Flickr
IMG_20191025_161549 by Vex Art Media, on Flickr
MVIMG_20191025_163918 by Vex Art Media, on Flickr
LRM_EXPORT_810513056986600_20191025_191516590 by Vex Art Media, on Flickr
LRM_EXPORT_810564165425285_20191025_191607698 by Vex Art Media, on Flickr
LRM_EXPORT_810564165425285_20191025_191607698 by Vex Art Media, on Flickr-Alex-
- themagellan
way to go - this thing is spectacular
Boost is back, no leaks, swapped back to the MC1 cam... So the MC2 cam I bought must've been an N/A cam or something [PENSIVE FACE]
Interesting, I wonder which cam you actually installed. There is a cam chart around somewhere, and it shows the MC1 and NF/early NG to be the same, and the MC2 and Late NG to be the same. I'm running the cam from my original NG and it runs amazingly well.
Oh, and car isooking awesome! It's the little touches that make it so great!
Wow, haven’t been on in quite a while, car is looking fantastic!!
Yeah I was surprised. Maybe I got a JT/KX cam? It's a solid lobed one like the MC2 is supposed to be. But it definitely didn't like to build boost for whatever reason.DE80q wrote:Interesting, I wonder which cam you actually installed. There is a cam chart around somewhere, and it shows the MC1 and NF/early NG to be the same, and the MC2 and Late NG to be the same. I'm running the cam from my original NG and it runs amazingly well.
Re: Alex's 'New' '83 UrQuattro - BBQ X Success
Post BBQ Pre BBQ Update...confusing right?
The few weeks before BBQ were spent frantically doing updates to make the car more reliable and comfortable for the drive. Even down to the last few hours before we left I was working on the car.
Fresh rotor rings from Coleman rotors along with some Hawk HP+ pads. Still can't wait to get rid of the manual brakes and boy do the Hawks dust like a MF'er! Worse than my EBC Yellows on the S8.
IMG_20191028_170033 by Vex Art Media, on Flickr
3D printing center caps
IMG_20191027_201053 by Vex Art Media, on Flickr
IMG_20191028_173030 by Vex Art Media, on Flickr
Mystery cam that didn't like to spool. Changed out injector o-rings while I was in there again too. Really curious if the head has bigger valves because it certainly looks like it was rebuilt recently.
IMG_20191027_142941 by Vex Art Media, on Flickr
And ready to hit the road! Had a last minute snafu the morning that we were planning on leaving. Went to go drop off at the alignment shop and it wouldn't start! Turns out the crank trigger wiring pin at the ECU developed a short and I had to do some emergency electrical work to put on a new pin. Thankfully that solved everything. Unfortunately the alignment shop couldn't get one of the rear adjusters loose and didn't align the car. The right rear had 2 degrees of toe that I had never noticed and even drove to BBQ the prior year. I took it back home and was able to free the adjuster and did a rough eyeball alignment....drove well enough! And FYI with the AK strut mounts set to max camber I got -2.5 degress in the front.
IMG_20191029_082343 by Vex Art Media, on Flickr
IMG_20191028_170033 by Vex Art Media, on Flickr3D printing center caps
IMG_20191028_173030 by Vex Art Media, on FlickrMystery cam that didn't like to spool. Changed out injector o-rings while I was in there again too. Really curious if the head has bigger valves because it certainly looks like it was rebuilt recently.
IMG_20191027_142941 by Vex Art Media, on FlickrAnd ready to hit the road! Had a last minute snafu the morning that we were planning on leaving. Went to go drop off at the alignment shop and it wouldn't start! Turns out the crank trigger wiring pin at the ECU developed a short and I had to do some emergency electrical work to put on a new pin. Thankfully that solved everything. Unfortunately the alignment shop couldn't get one of the rear adjusters loose and didn't align the car. The right rear had 2 degrees of toe that I had never noticed and even drove to BBQ the prior year. I took it back home and was able to free the adjuster and did a rough eyeball alignment....drove well enough! And FYI with the AK strut mounts set to max camber I got -2.5 degress in the front.
IMG_20191029_082343 by Vex Art Media, on Flickr-Alex-
The trip....ended up just over 3000 miles
2019-11-20_07-04-41 by Vex Art Media, on Flickr
Day 0.5
Late Tuesday night my wife and I started the journey by a quick jaunt to Portland. LOVE these headlights.
IMG_20191029_211529 by Vex Art Media, on Flickr
IMG_20191029_231426 by Vex Art Media, on Flickr
Day 1
Stuck in construction traffic in the middle of Oregon
IMG_20191030_093534 by Vex Art Media, on Flickr
Only a few hundred miles in and the brake dust is accumulating
IMG_20191030_093501 by Vex Art Media, on Flickr
First stop on the trip, Crater Lake! My wife is amazing and glad she's crazy enough to join me on a 3000 mile journey in a 35+ year old car.
MVIMG_20191030_111852 by Vex Art Media, on Flickr
IMG_20191030_111714 by Vex Art Media, on Flickr
IMG_20191030_112047 by Vex Art Media, on Flickr
Random Cayenne Turbo owner that did a u-turn and chased me down to talk about the car.
IMG_20191030_113156 by Vex Art Media, on Flickr
As we made it into Reno where we were going to stop for the night I heard a grinding. I figured it was the front brakes, which I previously had some clearance issues with the pad and rotor hat on and had to space the caliper out slightly. But low and behold one of the rear caliper mount bolts fell off! Quick trip to Home Depot got me some bolts and loctite to solve that problem. Thankfully it hit the rotor and didn't rub against the inside of my freshly restorce wheels!
IMG_20191030_195853 by Vex Art Media, on Flickr
2019-11-20_07-04-41 by Vex Art Media, on FlickrDay 0.5
IMG_20191029_231426 by Vex Art Media, on FlickrDay 1
IMG_20191030_093534 by Vex Art Media, on FlickrOnly a few hundred miles in and the brake dust is accumulating
IMG_20191030_093501 by Vex Art Media, on FlickrFirst stop on the trip, Crater Lake! My wife is amazing and glad she's crazy enough to join me on a 3000 mile journey in a 35+ year old car.
IMG_20191030_112047 by Vex Art Media, on FlickrRandom Cayenne Turbo owner that did a u-turn and chased me down to talk about the car.
IMG_20191030_113156 by Vex Art Media, on FlickrAs we made it into Reno where we were going to stop for the night I heard a grinding. I figured it was the front brakes, which I previously had some clearance issues with the pad and rotor hat on and had to space the caliper out slightly. But low and behold one of the rear caliper mount bolts fell off! Quick trip to Home Depot got me some bolts and loctite to solve that problem. Thankfully it hit the rotor and didn't rub against the inside of my freshly restorce wheels!
IMG_20191030_195853 by Vex Art Media, on Flickr-Alex-
Day 2
Mono Lake vista point
IMG_20191031_095649 by Vex Art Media, on Flickr
Up and over Tioga Pass heading into Yosemite National Park
IMG_20191031_113707 by Vex Art Media, on Flickr
Tunnel view at Yosemite...LOVE this place
IMG_20191031_131521 by Vex Art Media, on Flickr
IMG_20191031_165530 by Vex Art Media, on Flickr
Brake dust starting to get thick
IMG_20191031_145358 by Vex Art Media, on Flickr
Did I mention how much I love these headlights?
IMG_20191101_063956 by Vex Art Media, on Flickr
IMG_20191031_095649 by Vex Art Media, on FlickrUp and over Tioga Pass heading into Yosemite National Park
IMG_20191031_113707 by Vex Art Media, on FlickrTunnel view at Yosemite...LOVE this place
IMG_20191031_165530 by Vex Art Media, on FlickrBrake dust starting to get thick
IMG_20191031_145358 by Vex Art Media, on FlickrDid I mention how much I love these headlights?
IMG_20191101_063956 by Vex Art Media, on Flickr-Alex-
Day 3
Pre-sunrise at tunnel view as we head out of the park
IMG_20191101_070640 by Vex Art Media, on Flickr
Somewhere along the way, found some killer roads between 395 and Nevada
IMG_20191101_094901 by Vex Art Media, on Flickr
Thirsty girl...roughly 20mpg for the entire trip like last year. Don't have EGO feedback enabled
IMG_20191101_100850 by Vex Art Media, on Flickr
Made it into Vegas and cleaned her up!
IMG_20191101_153302 by Vex Art Media, on Flickr
Jamie Orr vehicle spottings
MVIMG_20191101_171402 by Vex Art Media, on Flickr
The cool kids (myself, Greg, Alan)
IMG_20191101_231743 by Vex Art Media, on Flickr
IMG_20191101_070640 by Vex Art Media, on FlickrSomewhere along the way, found some killer roads between 395 and Nevada
IMG_20191101_094901 by Vex Art Media, on FlickrThirsty girl...roughly 20mpg for the entire trip like last year. Don't have EGO feedback enabled
IMG_20191101_100850 by Vex Art Media, on FlickrMade it into Vegas and cleaned her up!
IMG_20191101_153302 by Vex Art Media, on FlickrJamie Orr vehicle spottings
MVIMG_20191101_171402 by Vex Art Media, on FlickrThe cool kids (myself, Greg, Alan)
IMG_20191101_231743 by Vex Art Media, on Flickr-Alex-
Day 4
Don't worry, I'll update with the good pictures when I get through them...just cell photos for now.
Lunch on Saturday before we headed out to the Valley of Fire
IMG_20191102_114938 by Vex Art Media, on Flickr
IMG_20191102_131529 by Vex Art Media, on Flickr
IMG_20191102_134238 by Vex Art Media, on Flickr
IMG_20191102_140537 by Vex Art Media, on Flickr
IMG_20191102_150540 by Vex Art Media, on Flickr
Dinner at Hofbrau Haus!
IMG_20191102_181531 by Vex Art Media, on Flickr
Greg has attended all 10 BBQs and did it in the same car! Sean and I came up with the idea to get him a present the previous year, so I made sure to take some extra nice phots of his car and had one printed.
IMG_20191102_193549 by Vex Art Media, on Flickr
It wouldn't be Hofbrau without some spankings
IMG_20191102_194932 by Vex Art Media, on Flickr
Day 5
Chill BBQ at Seans house
IMG_20191103_143837 by Vex Art Media, on Flickr
MVIMG_20191103_143908 by Vex Art Media, on Flickr
IMG_20191103_143932 by Vex Art Media, on Flickr
IMG_20191103_144015 by Vex Art Media, on Flickr
IMG_20191103_144032 by Vex Art Media, on Flickr
Everyone admiring the glory of 10 valves and channeling their inner AngryTaco
IMG_20191103_170349 by Vex Art Media, on Flickr
IMG_20191102_150540 by Vex Art Media, on FlickrDinner at Hofbrau Haus!
IMG_20191102_181531 by Vex Art Media, on FlickrGreg has attended all 10 BBQs and did it in the same car! Sean and I came up with the idea to get him a present the previous year, so I made sure to take some extra nice phots of his car and had one printed.
IMG_20191102_193549 by Vex Art Media, on FlickrIt wouldn't be Hofbrau without some spankings
IMG_20191102_194932 by Vex Art Media, on FlickrDay 5
IMG_20191103_144032 by Vex Art Media, on FlickrEveryone admiring the glory of 10 valves and channeling their inner AngryTaco
IMG_20191103_170349 by Vex Art Media, on Flickr-Alex-
Day 6
Back on the road heading home
IMG_20191104_105244 by Vex Art Media, on Flickr
IMG_20191104_105752 by Vex Art Media, on Flickr
IMG_20191104_105916 by Vex Art Media, on Flickr
IMG_20191104_105938 by Vex Art Media, on Flickr
Random brush fire
IMG_20191104_141633 by Vex Art Media, on Flickr
IMG_20191104_161154 by Vex Art Media, on Flickr
Day 7
Cold morning in Central Oregon!
IMG_20191105_051923 by Vex Art Media, on Flickr
IMG_20191105_074014 by Vex Art Media, on Flickr
MVIMG_20191105_091839 by Vex Art Media, on Flickr
IMG_20191105_074043 by Vex Art Media, on Flickr
IMG_20191105_074058 by Vex Art Media, on Flickr
IMG_20191105_093637 by Vex Art Media, on Flickr
Back in Washington!
IMG_20191105_103922 by Vex Art Media, on Flickr
IMG_20191105_104449 by Vex Art Media, on Flickr
IMG_20191105_140623 by Vex Art Media, on Flickr
IMG_20191105_140959 by Vex Art Media, on Flickr
HOME! And very dirty
MVIMG_20191105_155742 by Vex Art Media, on Flickr
IMG_20191105_155804 by Vex Art Media, on Flickr
IMG_20191105_160605 by Vex Art Media, on Flickr
IMG_20191104_105938 by Vex Art Media, on FlickrRandom brush fire
IMG_20191104_161154 by Vex Art Media, on FlickrDay 7
IMG_20191105_093637 by Vex Art Media, on FlickrBack in Washington!
IMG_20191105_140959 by Vex Art Media, on FlickrHOME! And very dirty
IMG_20191105_160605 by Vex Art Media, on Flickr-Alex-
Awesome pics as always, Alex. It was great seeing you and Jen!
Awesome Alex! Thank you for sharing!
Epic trip! Glad all that pre-trip prep paid off, sounds like it was super reliable. Definitely making me a little sad my car likely won't be road trip worthy (I don't mind zero interior and a straight exhaust but... some... people do) because that looks like an absolute blast!
Great pics, out of interest who's is the red coupe? anymore pics?
Thanks, I recognize the name off fb groups. It looks good and suits the red.varia wrote:John Cryan on FB
Cryanquattro
Yes, Alex great pics As always . And I’ll try to get a page on the red cq started here soon.
I would be interested in reading that, might help me keep motivated with my cq.Cryanquattro wrote:Yes, Alex great pics As always . And I’ll try to get a page on the red cq started here soon.
Seconded.pete82 wrote:I would be interested in reading that, might help me keep motivated with my cq.Cryanquattro wrote:Yes, Alex great pics As always . And I’ll try to get a page on the red cq started here soon.
