I was going to say something similar, except using a regular nut instead of a die.my2000apb wrote:run a die down over the threads, then cut them and back the die off, cleaning the threadsDFrosty wrote:Nice little addition, install almost complete. Waiting for AN fittings to arrive and need to find better way to cut threaded rod....angle grinder wheel deforms threads too much
90q IMSA GTO (wanna-be) build
psychorallyfreak
Re: 90q IMSA GTO (wanna-be) build
my2000apb DrBeastCar
you can also cut through a nut
Will do...Thanks gents
"I've been thinking about this, Mr. Hand...If I'm here and you're here, doesn't that make it our time?"
Got this sucker done!
No weeble-wobble for this thing!
Attachment ( 36782 ) : 90q_oil cooler brace_side copy.jpg
Attachment ( 36783 ) : 90q_oil cooler brace_cu copy.jpg
Twintowers
Need to get the black car started on the geek, my other red car made a brief appearance it's probably going to the mountains to stay there for a while make room for the black car...
http://www.motorgeek.com/viewtopic.php?f=6&t=24652" onclick="window.open(this.href);return false;
I got the 2 wheel fever at the moment, but that is ok it just frees up space for the project that is coming... Snow is coming to the Bay Area this year I can feel it... your about done there it looks like, when do we turn the key put some snow tires on her ??? :?
Haha....wut? Snow tires on the trackcar??Snow is coming to the Bay Area this year I can feel it... your about done there it looks like, when do we turn the key put some snow tires on her ??? :?
Have some for the Urq, but she's DIW right now
Twintowers
Spiked tires, what size rim to you need to clear the brakes now 17" ?
Yes, will be running 255/40 tires on 17x8 wheelsTwintowers wrote:Spiked tires, what size rim to you need to clear the brakes now 17" ?
Turbo boost gauge/sender unit installed...
Attachment ( 36971 ) : 90q_boost gauge sender copy.jpg
Attachment ( 36972 ) : 90q_boost gauge_firewall copy.jpg
Attachment ( 36973 ) : 90q_boost gauge completed copy.jpg
Twintowers
Update.. :?
Nada tostada....Twintowers wrote:Update.. :?
Well, actually, just got 'er back on the ground yesterday and buttoned-up some front suspension bits. Also, I'm stuck on this power issue to the wideband controller and boost gauge, then will have to figure out the RS2 fan wiring...so freakin close man.
...So after someone planted a seed of doubt about whether or not the crankshaft bolt had the required amount of torque and due to the removal of the keyway on the crank pulley by the machine shop, I had to make this:
Attachment ( 38086 ) : FW locking tool_a.JPG
Attachment ( 38087 ) : FW locking tool_b copy.jpg
Attachment ( 38088 ) : FW locking tool_c copy.jpg
Update:
Been working on wiring routing adjustments and what I think is the final BIG component addition required for this project....the RS2 fan:
Plate resistor....almost looks like it was meant to go there
Attachment ( 39035 ) : 90q_resistor plate1.jpg
Attachment ( 39036 ) : 90q_resistor plate_cu.jpg
Attachment ( 39038 ) : 90q_resistor plate_reverse.jpg
Attachment ( 39039 ) : 90q_resistor plate_top.jpg
Nice, you've got a couple of effective workarounds there. Keep up the good work!
Twintowers
I'm off next week, ur quattro drive shaft is ready, need to clean, and make way for spare engine I have here, do a parts sort out, perhaps reseal it, I have full gasket set with rings, bearings....... Probably want to get this bad boy going once and for all.....
Attachment ( 39047 ) : COUPE+REAR-1.JPG
Nice dude! What you going with....3B or AAN?Twintowers wrote:I'm off next week, ur quattro drive shaft is ready, need to clean, and make way for spare engine I have here, do a parts sort out, perhaps reseal it, I have full gasket set with rings, bearings....... Probably want to get this bad boy going once and for all.....
Thanks for the compliment. Soon as I can figure out the proper relayed wiring, I can finally crank up this pig! :dur:PRY4SNO wrote:Nice, you've got a couple of effective workarounds there. Keep up the good work!
Twintowers
Fire in the hole?
Fresh snow in the hills, firing up old red, space case on the roof, skis getting a hot wax, rain in driveway with no garage is not fun, however I will take snow in them hills any day.... Let it be known, I washed the bike few weeks ago, and bam, rain, rain, rain..... Stock WX block I got here with a ported head Ferrea highflow valves, nicely ported peace sign in the exhaust manifold, with a K26 #8 turbo...
Update...
RS2 fan wiring complete. Big Thanks to Tony Lum for figuring out that the pre-fabbed wiring harness I purchased was labeled backwards! :frustrated:
Few more wiring details to be sorted out, but finally got the danggum thing fired up!
Now waiting for Rad hoses to be completed and can start adding all fluids :woowoo:
Attachment ( 39315 ) : 90q_resistor plate wired.JPG
Attachment ( 39316 ) : 90q_rs2 fan wire routing.JPG
Attachment ( 39317 ) : 90q_relay-breaker mounted.JPG
Attachment ( 39319 ) : 90q_relay-breaker_wide.JPG
Attachment ( 39320 ) : 90q_relay-breaker_cu copy.jpg
Rad hoses complete:
BIG thanks to the Roose brothers, Steve and Paul, of Roose Motorsport UK/USA for their assistance!
Upper may need a little more fitment attention, but should be ok for initial start-up and break-in
Attachment ( 39460 ) : 90q_Roose hoses_wide.JPG
Attachment ( 39461 ) : 90q_Roose_main rad_top.JPG
Attachment ( 39462 ) : 90q_Roose_lower hose_front.JPG
Attachment ( 39463 ) : 90q_Roose_upper rad hose_intake mani.JPG
TopherGrace
^^Looks very good! where does the bottom line on the expansion tank go/come from?
Thanks. The hose that goes into the back of the Rad...on the fan side?TopherGrace wrote:^^Looks very good! where does the bottom line on the expansion tank go/come from?
Val
Looks like a "very clean" christmas tree :mrgreen:
TopherGrace
Thanks. The hose that goes into the back of the Rad...on the fan side?[/quoteDFrosty wrote:TopherGrace wrote:^^Looks very good! where does the bottom line on the expansion tank go/come from?
My bad I worded that wrong, I was referring to the lower hose on the expansion tank, I see the top hose comes from the rad, where does the bottom one come from
It's the most, wonderful tiiiiime of the yearrrrrrVal wrote:Looks like a "very clean" christmas tree :mrgreen:
