Bill's 200 20v for sale
audios
Bill's 200 20v, rebuild underway
Post by audios »
That could be, Ill ask Casey how he oriented them when installing. Here is the catch can/ccv set up. Although now I have the two lines going to BMW oil air separator's
I was told my my friend Ivan that i should not be venting out of the VC but only the block and he suggested doing what he on his 4ktq 20v where he had the return to the oil pan above the oil level. im still waiting on pics of his set up....
Sent from my iPhone using TapatalkImage
audios
Post by audios »
Pulled the piston rings today, seems to be some buildup behind the oil ring, does this look normal? Also the oil ring seems to be smaller in diameter than the middle and talk ring. Normally the VW/Audi oil rings work great and I do not change them, but think I may change these over
audios
Re: Bill's 200 20v, rebuild underway
Post by audios »
Pulled the rest of the Pistons and rods tonight, cylinder walls on three and five look scored. ImageImage
audios
Post by audios »
audios
Post by audios »
Found that the top ring was broken in cylinder number four. Looking to purchase rod bearings and the ultimate crankcase breather vent adapter from Marc at EFI express Image
How deep is the scoring? Tough to tell but looks like it should hone out without requiring a full rebore?
audios
Post by audios »
The poor leak down is making a lot of sense... Glad you're making her new and proper.
audios
Post by audios »
Soaking the pistons in seafoam to clean them up, seems to be working wellImage
audios
Post by audios »
There is definitely some build up in the ring-lands, especially the oil ring. the severity seems to correspond to the leak down #'s. dosent want to clean up with the nylon brushes, will have to look up best way to clean w/o damaging pistons
Post by dana »
Bill, I have a piston ring groove cleaning tool, works pretty well. Looks like this.
audios
Post by audios »
been doing a bit of reading, what do you all think of this :
http://www.angelfire.com/biz/snwvlly/bikes/dnthone.htm
Basically saying that you dont need to break the glaze or hone for the new rings...... just trying to make the best decision possible
audios
Post by audios »
Gave a shot at ball honing tonight. Used A flex hone 240 grit , my first time. Hatching pattern is not perfect, but more alarming is these two scratches on cylinder three and five…ImageImage
Can you catch your fingernail on those? I mean, they are going to effect compression and leak down, but hard to say how much. Looks like some rings were not de-burred during the gapping process.
audios
Post by audios »
Not sure, I did not assemble motor, I figured it would effect a bit. I plan to just run it and build good breather. Image
audios
Post by audios »
Out of the garage at the farm, getting ready to make the voyage to my houseImageImage
Post by Afterthought »
I never did figure out for myself the exact proper way to set up an aftermarket catch can ...
do you have a source of vacuum pulling through it to the intake ?
My car project isn’t running yet , At the advice of some others I have set mine up to collect everything and I will drain it myself rather than running it directly to the pan .
Some were finding some pretty weird milky substance in there that they didn’t want ending up in the pan so I figured I would run it for a bit and see . Maybe someone more experienced on here has some advice.
A pic for reference from quattroworld URS4 FAQ
That milky substance should be an emulsion of water vapour in the oil.
audios
Post by audios »
Just got back with the new van, snow on the white car
audios
Post by audios »
Installed piston rings tonight, also looked at the oil pick up tube. Found a lot of little plastic pieces. There were quite a few more than even in this picture…Image
Aktapod
Post by Aktapod »
Those plastic pieces are pretty common. I'd bet they're the remains of the cam splash shield that sat under the oil fill cap. They pretty much all disintegrate eventually and end up in the sump.
Great work on the car! Jealous of the snow too
audios
Post by audios »
Put on the new rod bearings tonight, took a few photos of the rod/ cap of cylinders 1&2 although they all looked similar. Any ideas of the possible cause of the markings?
audios
Post by audios »
Started on my take of a windage tray, based on Ian's (slacker20vt on MG)
http://www.motorgeek.com/viewtopic.php?t=23462
audios
Post by audios »
A bit more progress Image
audios
Post by audios »
Still not done, but bolted up.... Image
