Page 17 of 27
Re: Nick's Black 90 - 3B Swap: Wiring Help Please :)
Posted: Fri Jun 07, 2013 9:59 am
Toph just hooked you up lol. I was going to say that most of the pain is tying into power for things like injectors, coils, fp, and ecu power. I used an AAN with AAN harness and VEMS AAN pnp ecu. So I just brought power to the wires I mentioned above and hooked everything else I had for connectors in the engine bay up. Lickety split!
Posted: Fri Jun 07, 2013 2:44 pm
by nsimps
He did! Thanks for taking the time to spell it out. My hope is to document this part of it as well as I can for the future and this will help out tremendously. This is still pretty daunting but it will be so worth it when completed
Posted: Sat Jun 08, 2013 4:27 pm
by Audilard
Is this thing done yet?
Posted: Sun Jun 09, 2013 12:30 pm
by nsimps
I thought you were going to work on it this weekend while I am out of town?
Posted: Thu Jun 13, 2013 8:22 pm
by cqcollection
get this thing done tonight!
Posted: Fri Jun 14, 2013 11:17 am
by nsimps
Made some headway last night. Got the transmission bolted up and then moved the motor out of the way to make room for the car. It's back in the garage! My bother Jay came over after work and helped out a lot getting things re-organzied (again), getting the tranny bolted up and most of all, pushing the car up the driveway. I seriously was only steering as he pushed the car. Pretty impressive even without the motor weight in the car.
Got the 7a harness out! There were a few wires that I had to snip but I took pics and grouped them together. Now it's putting the 3b through and then...
then...
I beg peoples to come over and help me figure this out
My plan at this point is to get the harness through and then put the motor back in. Since I'm going through the driver's side this should work out fairly well. We'll see though. If I can get the motor back in it will be a huge motivator to keep going!
Question: Do I put the tranny mounts on the frame before putting the motor back in?
Onto the pics:
Fuse panel, left side looking down from the hood. I pulled the black clip off to get the harness out:
Fuse panel, center & right side looking down from the hood:
One of the plugs in the cab:
Couple more plugs in the cab:
This green/red wire goes up into the fuse panel. Not sure what it does:
This wire goes into the bay and comes into the cab and goes across from driver to pass side. Not sure what it does either:
Two brown/white wires. One goes up to the fuse panel and the other across to the pass side:
Current status of the bay. It's not going to get much cleaner than that unless the Engine Bay Cleaning Fairies come:
7a harness that I pulled out. Pretty awesome I got this thing out I won't lie
Re: Nick's Black 90 - 3B Swap: Motor sitting in the bay
Posted: Tue Jul 02, 2013 10:59 pm
by nsimps
Posted: Wed Jul 03, 2013 11:02 pm
by nsimps
not much time tonight to work on things. Did get the replacement prop shaft installed though so we'll see if that takes care of the annoying off-throttle rattle.
Posted: Thu Jul 04, 2013 7:56 am
by Toph
Off throttle rattle? Was it perhaps just the distributor? How's the wiring going - you figure out what the wires were that you mentioned above?
Posted: Thu Jul 04, 2013 12:20 pm
by nsimps
It's more of a shimmy. It may have been the worn out engine/trans mounts but not sure.
The wiring...oh the wiring...I'm soliciting some help on that one and in the mean time getting everything else ready that I can. I think those wires will be easy to figure out especially with the help coming
Posted: Mon Jul 08, 2013 1:50 pm
by nsimps
Got my hybrid downpipe today via direct drop off
Looks amazing!
Re: Nick's Black 90 - 3B Swap: The Nitty Gritty
Posted: Fri Jul 12, 2013 12:53 pm
by nsimps
Had a good fab evening with my dad yesterday evening. I've been waiting to work on my car with my dad for a long time now. Little background: growing up my dad had a wood working business he ran out of our garage in Washington. I would help him after school run custom molding, arches, trim work. Not much talking because of the noise but it was good father/son time. More recently my parents have lived pretty far from us kids so my mom could finish her doctorate. Just last week they were able to move here to Utah and be close to us so of course the first order of business was a little father/son work session.
Back to the update:
With the intercooler situation coming up fast, I've been stewing over what solution to go with. In classic Nick fashion, I'm making this more difficult than necessary and at first wanted to make a stock 3b s2 intercooler work with a modified core support. I have an intercooler from an EVO 8 as well and after some convincing, decided to try and make it work. First order of business is the core support. We ended up with a simple angle iron and square tubing solution which should work nicely. The EVO intercooler is going to require some bumper rebar massaging to get a good fit but should work out nicely and support my temporary power goals. The stock turbo to intercooler piece will be replaced with a couple 90's and an aluminum piece with bung for the diverter valve.
My brother also came over and I put him to work on the axle joint cleaning it up to be repacked
Is that mean to do?
Onto the pics:
Look how clean that is! Didn't have to touch any grease
Posted: Mon Jul 22, 2013 11:50 am
by nsimps
Posted: Mon Jul 22, 2013 12:10 pm
by Audilard
Too bad our fabricator/welder is no longer close by.....
Keep at it Nick, time is ticking.
Posted: Mon Jul 22, 2013 1:15 pm
by nsimps
True, I've been doing ok with my little 110amp flux welder. Once I have all the hard lines for the IC done in exhaust tubing I'll exchange them for aluminum sometime. Next big hurdle is still the wiring harness. I've got both Bentley manuals and a lot of notes so should be an evening or two of tracing, testing and connecting and then it's putting stuff back in!
Btw, did you say you had some oil lines that might work?
Posted: Mon Jul 22, 2013 6:33 pm
by Toph
...still the wiring harness...
You have the 7a harness out, the 200 20v harness out, both Bentleys, help here
, and you're procrastinating on it still?
I'm still here to help when you really start to get into it.
Posted: Mon Jul 22, 2013 7:48 pm
by nsimps
I'm actually in the thick of it right now... I'll send you my info if you have a few minutes. It's starting to make sense but still very foreign.
Posted: Wed Jul 24, 2013 11:46 pm
by nsimps
well looks like i screwed something up pretty bad with the clutch. went to depress the pedal and it was a brick. pushed a little harder and it gave in. a few depresses and releases and it seemed weird on the release. look underneatht the car and big ol puddle of brake fluid. :frustrated: :frustrated: :frustrated:
Posted: Thu Jul 25, 2013 4:11 pm
by Audilard
Where is the brake fluid coming from? Inside the bell housing? If so, pull the MC and see if it went "bye-bye".
Posted: Thu Jul 25, 2013 6:58 pm
by scubadave
Posted: Thu Jul 25, 2013 9:50 pm
by nsimps
It did go bye bye, and fell apart into the bell housing. Looks like I'm getting good practice pulling this thing out. Soon I'll be as fast as Hank!
Posted: Sat Jul 27, 2013 10:32 pm
by nsimps
I gave in. bunched up wires and connectors en route from across the pond...
Re: Nick's Black 90 - 3B Swap: Bahhh!!!
Posted: Thu Aug 01, 2013 12:38 am
by nsimps
Posted: Sat Aug 03, 2013 9:26 pm
by Audilard
Wow Nick! I hope you were able to get something back from the seller. That's ridiculous. Keep your head up. You're close!
Posted: Sat Aug 03, 2013 10:51 pm
by nsimps
Haven't talked with him yet. If I could just get a pic of the plug he cut off that would be all I need. I think what may have happened is he pulled the harness through backwards thus the messes up interior side.
