Grillage
Re: Re: Ben's V8 CQ - Carlisle Prep
Post by Grillage »
I found a couple things I missed the last time I put it all together. With no AC I wasn't sure which wires I didn't need anymore.
CURRENT
PAST
Grillage
Re: Re: Ben's V8 CQ
Post by Grillage »
Well Carlisle was a success! I made it there and back with the only issue being the emp gauge dying. 1000 miles of highway driving at 4000 rpm. I really need an 01E swap
A couple things showed up while I was gone that I'd really hoped would be there before the trip:
New plates:
New wheels:Image
CURRENT
PAST
UrSobsessed
Re: Ben's V8 CQ
Post by UrSobsessed »
That thing looks great Ben! Nice work!
Re: Re: Ben's V8 CQ
Post by AudiSport4000 »
Really enjoyed seeing (and hearing) this thing over the weekend. What was great was the conversation at night revolving around coolant and your radiator cap set up. I always learn something new which is why I love Carlisle....tons of knowledge and brains in one place. :)
frostyflax17
Re: Re: Ben's V8 CQ
Post by frostyflax17 »
that was so much fun riding in it.
me: "was that full throttle?"
Ben: :lol: "no" :floors it:
me "weeee!" :lol:
Cory
11 Touareg TDI - Daily
91 CQ - Lifted Rallyx Mudder
90 CQ - 3.0T Rombotis
90 CQ - Wannabe S2
91 200 3b - restore and sell
Sparkyjack
Re: Re: Ben's V8 CQ
Post by Sparkyjack »
frostyflax17 wrote:that was so much fun riding in it.
me "weeee!" :lol:
Me from the back seat "wow"
Jack
PLANETARY4
Re: Re: Ben's V8 CQ
Post by PLANETARY4 »
Great meeting you Ben. Can I get a ride next time? :)
Alex
'90 V8q
'95 S6
Re: Re: Ben's V8 CQ
This car looked very clean at Carlisle. I would have liked to look at little closer and get involved in some discussion, but time constraints dictated that I leave short of that. Oh well. Nice work on this thing! Gotta love V8 coupe swaps.
Grillage
Re: Re: Ben's V8 CQ
Post by Grillage »
Rides for all next time! I need to get a new transmission setup by then though.
Believe it or not, I was super excited to hear from Alan and Marc that I had set the radiator up to not bleed properly. It explains a bunch of cooling issues I had on the prior setup. I think I have it pretty well bled now but I'm definitely changing the radiator cap out to make the coolant bottle the ONLY relief point.
Currently I have a 14psi radiator cap on which is not allowing any air to escape the top of the radiator. I didn't realize that the hose just under that cap was closed unless I hit 14psi (overheating). So with my current setup, the radiator has no connection to the expansion tank and therefore makes a great place for air to get trapped. I am pretty sure I had this problem before but mostly have eliminated it since with my current setup. The solution is a 0psi radiator cap and the expansion tank's cap at 14psi as the only relief valve. Then I can have air escape the top of the radiator into the expansion tank like it should!
Chris, I saw your car briefly but didn't get a chance to say hi. It was raining pretty hard at that point on Saturday and all the hoods were closed too! Maybe next year!
CURRENT
PAST
varia
Re: Re: Ben's V8 CQ
Post by varia »
¯\_(ツ)_/¯
project 2226
Grillage
Re: Re: Ben's V8 CQ
Post by Grillage »
Marc was talking about this setup too. I need more tools!
CURRENT
PAST
Re: Re: Ben's V8 CQ
Interesting, I bet that was my issue too.
Grillage
Re: Re: Ben's V8 CQ
Post by Grillage »
I figured out a solution to the radiator problem today.
I ordered this: http://www.summitracing.com/parts/sum-380175 to replace this: http://www.summitracing.com/parts/gri-km-70 as a cap for the radiator.
As I mentioned, the cap was blocking the passage from the top of the radiator to the overflow nipple. This is probably basic stuff, but I didn't realize how this worked and as I set it up I created a perfect place for air to get trapped.
On a pressurized cap, (like the one shown below that was replaced) the spring is pushed up when the radiator achieves a certain pressure (in this case 15 psi) and with the spring pressed up, the overflow tube is now accessible for coolant to dump out of.
So the replacement of the cap with one that is missing the lower part (a 0psi cap) opens that overflow tube up.
I also took the opportunity to replace the hose I had there with a much better silicone hose. I was previously using a hose (that may or may not have been made for coolant) with a molded 90 in it that I had going straight. This required a different fitting for the overflow tube. I used a 1/8" MIP tube and fitting to get up to the 3/8" that the coolant bottle nipple is.
When I went to open the top of the radiator to take the old cap off and put the new one on, there was 1 1/2" of air in the top of the radiator!
With it all the way to the top and the new cap on it, I had this much room in the coolant bottle. I had been at MAX fill.
The result after firing everything up was an instant circulation of coolant!
Now to figure out the misfire that appeared this morning :bangshead:
CURRENT
PAST
Grillage
Re: Re: Ben's V8 CQ
Post by Grillage »
I am working to figure out the misfire I have and have established that I have ground being pulsed through all the POS tracks.
I bought a coil tester http://www.amazon.com/AMPRO-T71240-Ener ... ge_o00_s00 that arrived today and I am going to test my coils.
I googled for a video on how to use it and this is the first thing that popped up. it's AMAZING
[youtube]https://www.youtube.com/watch?v=jsAJxy45YWE[/youtube]
CURRENT
PAST
Grillage
Re: Re: Ben's V8 CQ
Post by Grillage »
Coil #2 tested bad! problem solved.
This is probably from having the hood open in the pouring rain all day last saturday
CURRENT
PAST
90quattrocoupe
Re: Re: Ben's V8 CQ
Post by 90quattrocoupe »
Grillage wrote:Coil #2 tested bad! problem solved.
:thumbsup:
Re: Re: Ben's V8 CQ
Glad it an easy fix!
If you require any more info on the setup George is running on his B4, shoot him a PM rs4tech.
Re: Re: Ben's V8 CQ
Nice job on the coolant cap. Who would have thought? :)
Grillage
Re: Re: Ben's V8 CQ
Post by Grillage »
It's been a while and I have a couple questions for the collective.
Firstly, I'm blowing white smoke at decel and when coasting down hills etc. I first thought this could be bad valve stem seals but after talking with Marc at Carlisle, he suggested maybe the PCV system is pressurized. How would I troubleshoot this?
Also, I was screwing around with the engine the other day and realized that the open holes in the injectors (I use the ABZ vacuum shrouded injectors) are essentially 8 large vacuum leaks. So I took some spare silicone hose and connected them to each other. Now I have been stalling at decel quite a bit. I guess the easiest solution would be to just open them back up but I'd like to fix this in VEMS. Since I really haven't had to do much in VEMS I'm confused about where to find this. Is this fuelcut because the Vacuum is too high? Where would I adjust?
thanks!
CURRENT
PAST
Grillage
Re: Re: Ben's V8 CQ
Post by Grillage »
I got the stall issue fixed. Any suggestions on the pcv?
CURRENT
PAST
Grillage
Re: Re: Ben's V8 CQ
Post by Grillage »
B5 S4 at the junkyard! I pulled the 01E yesterday
Anybody have a 4000 driveshaft?
CURRENT
PAST
Re: Re: Ben's V8 CQ
Nice score! Are you planning to rebuild it? Also, dont forget the outputs from the B5 rear diff so you can use your current CV shafts. I believe they need machined 3mm to be correct.
Grillage
Re: Re: Ben's V8 CQ
Post by Grillage »
I'll go back and grab those outputs. Just the cups right?
What's involved in a rebuild? Is there a write up somewhere?
CURRENT
PAST
Re: Re: Ben's V8 CQ
Yes, should just be the cups you need. There is a write up on MG with the part# to be sure.
As for a rebuild, not sure total involvement. I do know the complete rebuild kit can be purchased from JHM, but not cheap. I should probably do my UrS 01E before I install it.
Re: Re: Ben's V8 CQ
JHM has a $20 install video for their rebuild kit. Well worth the cost. Aaron mentioned somewhere the only thing wrong with it is they consistently mention the order of the 5-6 gears or synchros in the opposite direction. And it drives him nuts lol
Rebuild kit is about $700.
https://jhmotorsports.com/shop/catalog/ ... -2054.html
