Haven’t accomplished too much on this but I’m trying to work on getting it road worthy .
Some of the main items I need to finish :
Install interior
Finish Parking brake
Install tie rods
Alignment
Shift linkage
So I’m trying to chip away at some of these things...
First installing the interior . I wanted to swap to black anyways so before reinstalling the dash I figured I better at least put in the black carpet , that and reinstallation of the dash wasn’t too bad considering how long ago I took it out .
So... next up is the shift linkage .
My original plan was to modify the linkage and use an us4/6 shifter box inside the car , because that’s what I’ve done before with O1E . Now after thinking about it I realized that I’ve only done that on B2 and B3 is different . So I was afraid it wouldn’t work.
So after I made my linkage for this, I had ended up sourcing a shifter box from a later 01E car, so I could go with the whole b6 linkage and a b5 shifter box .
More specifically, what I’m using is this .
03 A4 GBE code 6 Speed 01E trans
But the shift linkage and shifter box is from a manual allroad 6 speed .
Specifically a b6 A4 3.0 linkage , and the box is manual allroad.
Although Im tempted to do whatever is the fastest and just get the car on the road , but I decided to go ahead and do this linkage now since it is what I wanted to have done the road anyways so I started on that. I’ve read that it can work but may need some modification .
I’m order to get at this I disconnected the exhaust , removed the driveshaft from the back of the trans, and removed the rear 2 subframe bolts which allowed me to tilt the trans down which gives me enough space to get the linkage and shifter box in and out .
First I trimmed the shifter box a little and got it bolted up inside the car . I had to drill out the existing bolt holes to accept the threaded studs that are in the shifter box , then drill 2 new holes for the front .
With that in place I can get the main shift rod to bolt up , and the cross rod . It seems like it may be a little on the longer side but it works .
That main shift rod seems like it will
Work without shortening , or may need to be shortened a very small amount to be perfect .
Where I’m held up right now is what I refer to as the “stabilizer bar “ , don’t know if that’s really the name but anyway this third rod that is fixed and just bolts to the trans .
This thing , does not clear the tunnel.
So the issue I’m having so far is , that fixed bar , stabilizer bar or whatever it is . Is hitting the tunnel so I can’t get it into place .
Here is what is causing the issue
I’ll try and keep track of what I’m
Doing for future but the first thing I did is shortened this rod by 1” . The rod is hitting the tunnel in front of the shifter box .
This is what I think would make it fit
