Page 119 of 125
Re: Jim Green's 90q 20vt - 636whp 07k
Posted: Tue Sep 06, 2016 8:40 am
Oh ok. I wonder what the system is like in a t44. It's something I've been planning on fixing eventually, but havent had the time to look into it at all.
Posted: Tue Sep 06, 2016 8:57 am
by dana
loxxrider wrote:Oh ok. I wonder what the system is like in a t44. It's something I've been planning on fixing eventually, but havent had the time to look into it at all.
I bet its the same thing. I have found that the electrical contacts in the stalk have almost always been corroded to the point of not sending any outputs anymore. The stalk gets switched 12v in and it sends 12v out on 3 different wires.
-12v out for "cruise on" this remains constantly energized when switch is in the on position
-12v momentary out when the set button is pushed
-12v momentary out when the resume button is pushed
These are what my contacts looked like before
after
Posted: Tue Sep 06, 2016 9:47 am
Good info, I am always surprised mine still works by just hooking up the vacuum hose to the actuator.
Posted: Tue Sep 06, 2016 9:58 am
by dana
audifreakjim wrote:Good info, I am always surprised mine still works by just hooking up the vacuum hose to the actuator.
probably because you live/lived in dryer climates? mine usually just need that corrosion cleaned off and they work again. Everything corrodes around here, too much moisture.
Posted: Tue Sep 06, 2016 11:25 am
Posted: Tue Sep 06, 2016 11:07 pm
by elaw
Sweet!
Any chance you could supply some part numbers for those of us less clueful about bearings?
Posted: Wed Sep 07, 2016 12:32 am
Here are the bearing cups.
http://www.fkrodends.com/AINCP18.htmlI went with the CP8 cup and FKSSX8T bearing. Stainless and Teflon lined.
https://m.summitracing.com/parts/fkb-fkssx8t*Edit* Here are the QA1 SN8-66 high misalignment spacers I used
https://www.summitracing.com/parts/qa1-sn8-66
Posted: Sat Oct 01, 2016 11:20 pm
by PRA4WX
Money!
Posted: Thu Oct 13, 2016 5:33 pm
Been driving around the last few days with the spool valve forced open by accident. Have thought to myself numerous times, "wow this car sounds better than normal". I think can accomplish this with a small pressure tank and a check valve.
-Open most of the time except for the area of the map where its needed, above 100kpa and below ~4700 rpms
Posted: Thu Oct 13, 2016 6:30 pm
by 2.5TYPE44
I was thinking the same thing. I'm not knowledgeable enough to do it with tuning but thought it would be nice to have both sides open when you wanted. For example... stop and go traffic where you don't build up enough boost to cause it to open and you want it open to let the hot exhaust gas to to get out easier and make everything run cooler. I was thinking of a cable operated lever that would be inside the car near the shifter and was attached to quick spool rod so all you would have to do is pull the lever and the cable would draw the butterfly open.
Posted: Thu Oct 13, 2016 8:13 pm
We can help you set it up in VEMS josh. It's really easy to do with the check valve and pressure reservoir as Jim says.
Posted: Thu Oct 13, 2016 8:20 pm
by 2.5TYPE44
Sweet! Thanks! I will definitely want some help with that especially when I go to a EFR 9180.
Posted: Fri Oct 14, 2016 8:56 am
by 2.5TYPE44
Jim, I was thinking about it and are you going to run a line to a two port tank/accumalator from the manifold or some point where you have boost, put a check valve on that side so the pressure will stay in the tank,.... then on the second port, have a solenoid valve controlled by VEMS that delivers air to the quick spool actuator to keep it open based on your programming...???
Posted: Fri Oct 14, 2016 5:14 pm
That's how I envisioned it but Jim may have some different plumbing in mind. An n75 (from Marc or even an AAN's stock one) will do the trick nicely, that's what we used to control the qsv.
Posted: Thu Dec 22, 2016 12:50 am
Time for an update. Had a bad noise develop at BBQ, turns out the flywheel bolts were backing out due to the mechanic not using loctite...
It rattled the thrust bearings out, which caused some side loading on the rod bearings.
Another interesting thing is the front pulley was loose too. Probably due to the flywheel hammering the crank.
New crank, rod bearings, thrust bearings, and flywheel are going in. Might do inconel exhaust valves too.
Also going to swap out that heavy ass full face spec clutch disk for a lighter, more TQ capable spring 6 puck
Posted: Thu Dec 22, 2016 11:52 am
by dana
Wow, I am little bit surprised about the bearing damage and the front pulley loosening. I suppose it makes sense, those were some pretty nasty vibrations.
I'm sure that rip through the gears that you so kindly provided us did not help
Sorry to see this happened, but, like usual, the car will be even better than it was.
Posted: Thu Dec 22, 2016 12:13 pm
It had to come apart anyways, I probably would do it again even if I know it was going to cost me a set of rod bearings
Posted: Thu Dec 22, 2016 5:58 pm
by SEStone
A little tiny piece of me hopes this isn't a sign of a death vibration like Hank talks about that breaks TT-RS cranks in half when using a single mass flywheel. Might be wise to invest in a better crank balancer? We deal with the same shit on the super lightweight Porsche stroker cranks and flywheels vibrating loose. A front crank damper/balancer seems to have solved it.
Sam
Posted: Thu Dec 22, 2016 11:34 pm
I'm running a TT-RS balancer in the front already. Not sure if that's a good thing bad thing now. Didn't know that was an issue!
Posted: Fri Dec 23, 2016 1:19 pm
by Afterthought
Is that Fluidampr that Issam is making now made to help with this?
I'm no engineer but I know that there are a couple ways that you can change the critical speed of a rotating mass, if you change the weight that is one way and also to change that damping is another. If you are going to change the flywheel and clutch you'll be changing that equation quite a bit.
Posted: Fri Dec 23, 2016 2:01 pm
I'll hit him up. Now is the time to change it.
Posted: Mon Dec 26, 2016 12:46 pm
by Einbilden
Man I am sorry about your engine. This is the reason I do everything myself. Sometimes that is hard to do with work and other fixits in general. But I hate paying someone hard earned money and then have to go in there and fix it the right way.
Hope you are back on the road soon.
Posted: Wed Jan 25, 2017 9:54 am
by Herbehop
Was the spool valve that broke the original version or the Super HD version from Sound Performance?
I'll be running a similar setup so I'm wondering what precautions I need to take so I don't grenade my turbo.
Your build is awesome! Thanks for the help.
Posted: Thu Jan 26, 2017 10:10 am
Super HD, the latest revision.
Posted: Thu Jan 26, 2017 11:52 am
by Herbehop
Thanks - I was afraid you would say that. Will definitely weld mine and look at disabling when using anti-lag.
