Page 116 of 125
Re: Jim Green's 90q 20vt - 636whp 07k and insane weekend
Posted: Sun May 15, 2016 11:16 am
Was kinda flying this under the radar, but it should be known what happened here. Don't subject your spool valves to backfires due to rev limiter, NLS or anti-lag. Sound performance fixed it but that doesn't fix the turbo although they did offer a Precision at an extremely good deal, although Hank helped me out with a new core. Solution? Weld it. Weld all of it.
Also, I now have a check valve on the spool valve so it stays open during these events, and will be re-engaged by a boost valve only when it's in an area of the map that needs it.
Posted: Sun May 15, 2016 3:07 pm
by ringbearer
Ouch, glad it's being sorted out.
Posted: Tue May 17, 2016 9:29 am
by PRA4WX
Nice stuff, Jim! No need for a full interior to be able to drive to Vegas! ;-)
Posted: Mon May 23, 2016 11:22 pm
Ok, new turbo and spool valve did not fix my wonky boost issues. Taking out the TTRS intake cam. Was going over logs and I was actually using more fuel without it at the same boost. Also got the header and turbine housing under a nice heat shield. Much better just to the touch under there. ImageImage
Posted: Tue May 24, 2016 10:25 pm
That's a clever idea with the check valve. So it will simply always hold a little pressure in the line to keep it open since the actuator runs off pressure. We did launch control quite a few times with dad's car and the butterfly valve actually bent, but did not break like yours. That sucks.
So right now you only have the ttrs intake cam in? No exhaust yet? And what was weird about the boost, I must have missed that.
Posted: Tue May 24, 2016 11:35 pm
The exhaust cam on the TTRS is variable, so it would probably take a lot of experimenting to get it to run right. Someday we will try adding variable exhaust to the regular 07k :)
The boost issue, I really can't explain it, strange stuff like this, started when the cam went in. The logs with the original cam are perfectly flat boost profiles. Tried three different wastegates, forcing the spool valve all the way open, retarding the exhaust cam, nothing changes, and nothing is consistent.
It give the motor a funky on cam feeling. But on the dyno under load, it never showed up.
Should have it running again before the weekend.
Posted: Wed May 25, 2016 10:42 am
The heat shielding looks really nice. I'm curious to see the results of the cam swap. Best of luck!
Posted: Wed May 25, 2016 9:19 pm
Weird. I just had this issue tuning a customer's car. Like exactly the same thing, but on an AAN. Stock cams I think, with a weirdo rs2 type turbo. It would boost to 240ish kpa and then take off. In lower gears it would all happen so fast that I couldn't notice it. But in 5th/6th it was very apparent. I'm on my phone so no pictures from logs but the boost profile looks identical. We didn't experiment a lot with wastegate springs or n75s though, both of which it could have been. But no amount of duty cycle would change it. Super weird.
Posted: Wed May 25, 2016 11:08 pm
Yeah, could be a bad N75, wastegate diaphragm, boost leak, all of which I ruled out. Now I am dying to know if the cam fixes it.
Posted: Thu May 26, 2016 9:16 am
by ringbearer
Get her running and come join us on our little drive this Saturday in Truckee ;)
Posted: Fri May 27, 2016 7:35 pm
Boost is fixed, everything is fixed. Faster than ever before. Almost died, now I am scared to drive it!
Posted: Fri May 27, 2016 8:10 pm
hahaha that's great news!
and it shows the importance of cam design!
Posted: Fri May 27, 2016 8:20 pm
This is what it looks like now. Solid. Image
Posted: Fri May 27, 2016 10:59 pm
by Audilard
audifreakjim wrote:Boost is fixed, everything is fixed. Faster than ever before. Almost died, now I am scared to drive it!
lol!!!! :lol:
Posted: Sat May 28, 2016 5:21 pm
Posted: Sat May 28, 2016 5:23 pm
by A20V200
Hmm....kind of hard to tell with that grin on your face!!! Sounds good!
Posted: Sat May 28, 2016 5:43 pm
Yeehaw! Looks like a blast :)
Posted: Sun May 29, 2016 12:17 am
Still grinning. It just RIPS!
Posted: Sun May 29, 2016 9:09 am
by FFF
I think it was Walter Rohl that said "A car is just fast enough when you stand in front of it in the morning and are afraid to unlock it."
Must be great!
Posted: Sun May 29, 2016 10:16 am
Ha, my goals exactly ^^^
Posted: Sun May 29, 2016 1:15 pm
by Mcstiff
Posted: Sun May 29, 2016 2:45 pm
Mcstiff wrote:
For Tapatalk
Posted: Sun May 29, 2016 8:21 pm
by pkw
Sounds like the turbo comes online nice and early in the rev range for a turbo that sounds like it is grabbing a lot of air when the engine is revved up. Not sure if everyone in the world notices or smiles when these sounds are made but when I hear both from the same powerplant it is music to me. :flag:
Posted: Sun May 29, 2016 8:44 pm
The whole setup is pretty wicked. It makes instant boost even at 3500, and is pretty pissed by 4k in most gears. This is why 1st is almost useless. It builds full boost so fast it just rips the tires loose. Pretty impressive for an 800hp turbo
Posted: Mon May 30, 2016 5:36 pm
by scubagli
Awesome.
