Next I tried one of the super fancy, super light weight Shorai lithium-iron batteries (only 3 lbs!!!!) which had the same dimensions. That lasted for 3 days off of the tender and the guy at the battery store assured me that unlike an AGM, if an Li-Fe battery became fully discharged they would charge right back up when you plug them in. So of course I tested it. Wrong. It was kaput after that.
I finally conceded and bought a real battery to put in the trunk - an Odyssey PC925; still the smallest 'automotive' battery I could get. I spent yesterday I installing it in the trunk. Fits perfectly in the little storage area under the floor, and still leaves room for the tool kit and some rags.
In the process of running the new power leg to the front, I have to take most of the trim on one side of the car off anyway, so I figured now was as good a time as any for my black S2 trim swap. I bought this from Khai about 2 years ago, and it's just been sitting in a box in the corner of the garage since.
Stock light colored upper trim/headliner:
New trim... all bubbled up:
Black trim installed on the hatch:
Pulled out all of the interior trim, headliner, and sunroof panel:
Pulled the old headliner fabric off and started cleaning the old foam and adhesive off the board. This is sooooo much worse than the headliner I did on my Mk2 GTI... The foam and adhesive is all gummy and just pills up into little balls that stick to everything. I spent a good 2.5 hours just cleaning this thing up.
Starting to strip it:
I got some "industrial strength 300" locktite spray adhesive and 2.5 yards of foam backed headliner fabric. I don't like spraying that adhesive inside the garage, so I decided to do the reupholster job outside as well. I did the back half first since it's the flat and easy. Went fine. Then I started after the front, which has all the really sharp contours around the sunroof control. I failed hard. I think I used too much glue and it was too cold outside, because I could not get the fabric to stay down in the corners. I ended up pulling the fabric off and spending another hour cleaning the whole thing again. $50 in material trashed. I will try again later this week, probably in the garage with a space heater going and a helper... or maybe just pay a professional (as much as that kills me).
