sounds good. working the 12-midnight shift this week so its tough to tinker with it at 1 in the morning but hopefully with the holiday weekend I can find some time to get it running a little better. I will keep the updates coming for sure. . . might even start a consolidated build thread over here so im not thread jacking everyone else. here is the main thread for my 4000 if anyone is bored and looking for more audi porn.
http://grassrootsmotorsports.com/forum/ ... 655/page1/
Anyone else running MegaSquirt?
Re: Anyone else running MegaSquirt?
-'87 4000cs quattro 20vt
-'80 scirocco S 16v
-'77 280z L28
-'80 scirocco S 16v
-'77 280z L28
ok now I have another dumb question or two. do I really need to make a one tooth distributor cup or can I just use the one window I have? also, what pin does the cam sensor (distributor) signal wire go to when not running the MS3 expansion? everything I have found just talks about MS3X
-'80 scirocco S 16v
-'77 280z L28
-'80 scirocco S 16v
-'77 280z L28
If you already have a factory single windo dizzy, you should be fine. As for the cam sensor setup, I posted a link to what I think you need to do over on the other forum.
