Page 2 of 3
Re: Reed's 95 //S6: RS2 Billet Pump Gas Tune
Posted: Tue Jul 02, 2013 1:41 pm
by urs6ville
Hank wrote:Marc is working on some map switch stuff which may turn out to be the ticket for the gassers :)
schwwwwwwwwwwwwwwwwwweeeeeeeeeet
Posted: Tue Jul 02, 2013 1:42 pm
by Audilard
:D :D :D :D :D :D :ty:
Posted: Tue Jul 02, 2013 1:43 pm
O ur on motronic?
on my stinking phone!
Posted: Tue Jul 02, 2013 2:48 pm
by urs6ville
chaloux wrote:O ur on motronic?
nope. VEMS. I assumed Hank meant something that could swap a tune without having to pull out a laptop and connect up and do the swap. perhaps Hank thought I was Motronic....
Posted: Tue Jul 02, 2013 2:59 pm
by mushasho
Pick up your phone, kid
Posted: Tue Jul 02, 2013 3:02 pm
I'm pretty sure it's as simple as a switch which either sends ground or +v to the ecu via an aux in (or whatever on that 6 pin connector) and that will signal a map switch.
Posted: Tue Jul 02, 2013 3:21 pm
by pilihp2
It's pretty much just that simple. If you have a switch for your launch control, it can also do map switching ( not at the same time )
But its darn easy.
Posted: Tue Jul 02, 2013 3:48 pm
by urs6ville
so can you have a tune and a staged tune both stored in VEMS at the same time? did not know that. nice.
Posted: Tue Jul 02, 2013 3:49 pm
by pilihp2
Just the flip of a switch and you're on an e85 tune, or pump gas, or high boost, or mega timing, or whatever you want.
Posted: Tue Jul 02, 2013 3:54 pm
Yep. This is how we will setup dad's w/m injection with the AEM failsafe system. It sends a ground signal if it sees too much or too little flow. Then map switch and you're still okay to drive without being too concerned!
Posted: Tue Jul 02, 2013 4:20 pm
by Marc
yeah Dan, VEMS has built in map-select.
What Hank was talking about though is we are looking at doing a dual-map e85 and pump gas tune set for stock motronic as well.
Posted: Tue Jul 02, 2013 6:38 pm
by Hank
My bad, I thought you were Motronic still. On Vems, it is cake. Just gotta have two maps and a map select. Marc can set this up very easily. Hello 400wtq..
Posted: Tue Jul 02, 2013 8:22 pm
by urs6ville
Hank wrote:My bad, I thought you were Motronic still. On Vems, it is cake. Just gotta have two maps and a map select. Marc can set this up very easily. Hello 400wtq..
no worries.. all makes sense now.
Posted: Tue Jul 02, 2013 9:48 pm
by DuBistS4
Dan, what injectors and pump are you running?
Posted: Tue Jul 02, 2013 10:22 pm
by urs6ville
60# and 044. Adjustable FPR set at 3bar
Posted: Tue Jul 02, 2013 10:46 pm
by DuBistS4
is 3bar stock for an AAN
Posted: Wed Jul 03, 2013 6:44 am
by mushasho
urs6ville wrote:60# and 044. Adjustable FPR set at 3bar
Why'd you bump it down to 3 on the FPR?
Posted: Wed Jul 03, 2013 7:43 am
by EDIGREG
DuBistS4 wrote:is 3bar stock for an AAN
4BAR is stock
Posted: Wed Jul 03, 2013 7:48 am
by urs6ville
When Marc installed VEMS he had me set it at 3. Dont remember the exact reason.
Posted: Wed Jul 03, 2013 7:50 am
by Marc
I dont recall that conversation, but it really doesn't matter as long as the tune is set for the particular regulator pressure.
Posted: Wed Jul 03, 2013 8:16 am
by urs6ville
Marc wrote:I dont recall that conversation, but it really doesn't matter as long as the tune is set for the particular regulator pressure.
While still on Motronic I had bumped it up to see if it helped with the pinging (to about 4.3 bar)... it didn't. So when I came up for the VEMS install and tune I had to dial it back down and you said to set it at 3bar for whatever reason, something about something being happier at 3bar... I don't quite remember, all I remember is having to thread on that crappy gauge adaptor from you know who and set it, then I took it off once set. (their adaptor leaked).
Doesn't much matter to me, as long as the tune has what it expects. Would there be any reason to set it back to 4bar if moving to e85?
Posted: Wed Jul 03, 2013 8:36 am
by EDIGREG
urs6ville wrote:Would there be any reason to set it back to 4bar if moving to e85?
Depends, you may not have enough injector for E85 @ 3bar.
Which injectors? 60#?
Posted: Wed Jul 03, 2013 9:33 am
by Marc
I think he'll be ok. if you look at the taper on these billet rs2's the torque comes down anyway toward redline which is what taxes injectors (increasing revs at constant injector pulsewidth).
Posted: Wed Jul 03, 2013 11:25 am
by DuBistS4
My base tune is for 4bar stock aan fp so my tune wont run right on your car...sorry
