I feel like a broken record....THISWilford Brimley wrote:AngryTaco wrote:What pistons are you running Cricket? I was looking at getting a set of wiseco and bump the compression up to 10.5:1
You're asking for even more detonation problems than you're already having by going 10.5:1 with boost. You could get away with doing it on a decently cammed 4v/cyl VAG motor running E85, but not something as detonation prone as the 20vt.
Audi sport used compression ratios even lower than the MC1 in the early 20vt group B cars. If you're going to model after something using ancient technology like CIS, just make sure you use an example that had a well-funded engineering department and factory backing
Re: Tacos 4KTQ 20vt Swap: The Red Baron - Sparkplug Damage P
E85 is definitely the key to success for the 20vt. Audi sport 10 were in the 6 to 1 range and guys like Jim Green ran with stacked gaskets on mc1 engines for around 6 to 1 ad well.
- themagellan
Taco's just going to start running positive timing let's be real here for a moment.
6 to 1? Holy Hell that is low.
I wanna see an IMSA 4ktq. Doit.
HOLY SHIT! thats crazy low. Im not looking to go huge power out of my MC1, so I think I should be OK.Hank wrote:E85 is definitely the key to success for the 20vt. Audi sport 10 were in the 6 to 1 range and guys like Jim Green ran with stacked gaskets on mc1 engines for around 6 to 1 ad well.
I couldnt imagine the off-boost torque with that low of a compression. It's given me something to think about. I'm pulling the head off tomorrow and inspecting the damage so that may determine what happens in the next few months.
If Audi Sport did it I'd trust it to be a good idea. Run a LWFW and 4.11's and the off boost won't be quite as bad. Spool it with some a quick spool valve, nitrous and throw some meth at it just for good measure.
Noisy Cricket
I've driven nonturbo engines with compression that low or lower. Smoooooth engines
Pete, that rallycross guy
'06 Volvo S60 R (Swedish GTR)
- ringbearer
AngryTaco wrote:I couldnt imagine the off-boost torque with that low of a compression. It's given me something to think about. I'm pulling the head off tomorrow and inspecting the damage so that may determine what happens in the next few months.
Low off boost power or constant rebuilds?
Pick one...
Mebbe an LS swap?
What is this "off-boost" you speak of?I couldnt imagine the off-boost torque with that low of a compression.
I think you could get away with 10:1 on e85, but it would be e85 only, don't even think about running gas through it on any boost.
Noisy Cricket
One of the things I plan on playing with is rotational idle... idle under boost...Hank wrote:What is this "off-boost" you speak of?I couldnt imagine the off-boost torque with that low of a compression.
But he is running E85 which means he has to carefully map out his journeys and sometimes it's a Mad Max like search for "the precious juice"... and he can only run 17 pounds before he runs into issues anyway. i forget if that was because of knock or because that's just the limit of the turbo he has. Although the second can lead to the first.
How about you just run some normal compression ratio and then just switch programs depending on what type of fuel you are running? Just don't forget.
My archaic, 25 year old factory ecu has dual knock sensor knock control and with some very minor code tweaks it blinks the CEL on every detonation event. Yea it obviously has it's limits but I don't get why you VEMS, 034, and MS users don't have knock control or at least knock indication?
Noisy Cricket
MS3 has knock detection. From speaking with Matt, you can tell it what frequencies to look at and in which angles of crank rotation to look at, and which knock sensors read what cylinders, to help distinguish between engine noise and knock. Just like the OEMs do. (This after conversing with him when I mentioned planning to run FAST XFI and he said "Why? Their knock detection is nowhere near as robust as ours."
Funny thing is the MC engine block I picked up does not have the MC2's knock sensor bosses milled or drilled, they are just casting knobs. The first MC1 block I picked up had them milled, drilled, and tapped. Strange...
The only real problem with relying on knock control is that once it happens, you have by definition had a knock event. No big deal under cruise/light accel but knock under hard boost is going to be hurting things. Could be worse, though. I come from the land of rotors and under boost you not only avoid knock like the plague, but you also avoid misfire... because misfire is just as damaging as knock, and misfiring can LEAD to knock.
E85 / Racefuel was the plan.Hank wrote:I think you could get away with 10:1 on e85, but it would be e85 only, don't even think about running gas through it on any boost.I couldnt imagine the off-boost torque with that low of a compression.
I'll be running e85/e98 in the Dodge with 10.0:1 compression on a vortec supercharger setup, but this is completely irrelevant to the 2v Audi designs. I'll still be able to run pump but just with an ultra-conservative tune (on the Dodge).
Looks like I got a Southbend Stage II clutch kit on the way soon. It's the Stage II OFE (Endurance) Package
Fingers crossed the motor only needs rings but I don't have my hopes up
This right here is clearly something I was dealing with... a crazy misfire that only happened after hot runs and progressively got worse at idle... drive it for 5 minutes and the misfire vanished... Matt, Chris & Kevin were in the car at Carlisle when slight signs of it started popping up...Noisy Cricket wrote:under boost you not only avoid knock like the plague, but you also avoid misfire... because misfire is just as damaging as knock, and misfiring can LEAD to knock.
No VEMS is not sophisticated enough (with my current firmware anyhow) to detect, monitor, warn or adjust for such events.
Looks like 1.2.16 has the knock sensing feature worked out, but nothing on the misfire side of things... GenBoard/UnderDevelopment/FirmwareChanges
Wilford Brimley
A friend is running 10.5:1 on his 4v mod mustang. It's stroked to 5 liters, CNC ported heads, cams, and a D1SC to name a few of the mods. On a 97 degree day it made 796whp on a mustang dyno. With a good base engine that has a high VE, 10:1 and higher can be done with boost on E85.AngryTaco wrote: E85 / Racefuel was the plan.
Just look at some of the SFWD and outlaw civics. They're in the 12:1 range running 40+psi
The concern is the Audi 20v head and the limitations that it imposes, low knock limit, not the compression ratio. I put a lot of miles on my stock 7a with 15psi from the H1C and no known issues, granted I still need to get a real tune but that will be better/safer so moot.Wilford Brimley wrote:A friend is running 10.5:1 on his 4v mod mustang. It's stroked to 5 liters, CNC ported heads, cams, and a D1SC to name a few of the mods. On a 97 degree day it made 796whp on a mustang dyno. With a good base engine that has a high VE, 10:1 and higher can be done with boost on E85.AngryTaco wrote: E85 / Racefuel was the plan.
Wilford Brimley
Mcstiff wrote: The concern is the Audi 20v head and the limitations that it imposes, low knock limit, not the compression ratio. I put a lot of miles on my stock 7a with 15psi from the H1C and no known issues, granted I still need to get a real tune but that will be better/safer so moot.
100% understood. The heads flow terribly, but boost can make up for that (to a point). The detonation threshold is pretty low on the 20v chamber. If you look at the Nissan L28ET engine out of a 280zx turbo, it has similar CFM numbers to the 20v in stock configuration, similar compression ratios, 2v/cyl, yet 400whp isn't completely unheard of on a stock log manifold that is almost as poorly designed as the MC mani.
Now on that note. I am going to experiment with opening up the chamber a bit to help increase knock resistance. This includes adding more CCs by reducing the "ledge" and perhaps transforming it into a more cylindrical design such as those found in the domestic V8 motors. It will be interesting to see how I go about it and what I come up with
mr_aj_johnson
Have you pulled the head yet?
Sent from my SM-G900V using Tapatalk
- themagellan
Ok taco - looks like it's time to save some money and just stack some head gaskets and be done with it.
coming from the abaT world, headgasket stack is used more often than a spacer.
oh deer
You keep doing that you will end up with one hell of a bald spot!AudiSport4000 wrote:oh deer
Im confused. What do chicken of the forest have to do with turbos?AudiSport4000 wrote:oh deer
