Marc's 95 S6 Avant (daily driver)
WAUG0806 wrote:
a4kquattro wrote:I got a call today from the guy I sold my 90q20v to, apparently the car was having clutch slave issues. So I loaded up the wagon with tools to pressure bleed the clutch figure ............:
When does my warranty expire.... ??? :D
he's an audi virgin so I'm trying to break him in easy.
You popped your cherry long ago :o
WAUG0806
Post by WAUG0806 »
and i'm an audi whore :? :o :bump:
popped my clutch hydraulics cherry long ago for sure
pkw
Post by pkw »
if surfaces are flat, another thing that works well is no gasket.
pkw wrote:if surfaces are flat, another thing that works well is no gasket.
If the metals on both sides are equal, which they aren't
PRA4WX
Post by PRA4WX »
Marc- just reinforce and re-weld your pedal. I replaced on on my 200 20v, then had one go on one of my urs4's......after looking at it i was like, why in the heck would i source/buy another one when i can reinforce this one so i won't ever happen again, AND save money. JM2C.
Toxcheap
Post by Toxcheap »
"Ah.. I think it'll be fine"
Toxcheap wrote:"Ah.. I think it'll be fine"
In reference to....?
Toxcheap
Post by Toxcheap »
Pretty much everything, it has universal application!
Corey
Post by Corey »
Marc, just weld it back up. There is enough room to get a strengthening gusset in there. Just check the stroke of the mechanism to ensure it isn't bottoming out and isn't causing the bracket to fatigue.
Twisted5000
Post by Twisted5000 »
I had thought those pedals were aluminum, no?
cast aluminum:
HT Motorsport
Post by HT Motorsport »
NIeeeccceee :)
I hope thats the old one....
H
yodasfro
Post by yodasfro »
Bram
Post by Bram »
Marc. Are you still running VEMS? and if so, what boost pressure do you run?
Bram wrote:Marc. Are you still running VEMS? and if so, what boost pressure do you run?
yes, VEMS. For the street I'm tuning for 28 psi.
mdg3369
Post by mdg3369 »
When my father got his S6 Avant, he was pleased to see that the firewall was sturdier compared to the early cars, so that they don't crack around the clutch master cylinder. We then learned that instead of the firewall cracking, the pedal breaks, which is easier to fix, but still annoying! :bashtard:
Bram
Post by Bram »
Marc, got any new power curves to share running that 28 psi? :-D
Hi Bram,
haven't had any time. Been really busy lately finishing some non-car projects (the bill paying kind) I'll probably put the car back on the dyno next time I rent a full dyno day to tune customer cars.
Bram
Post by Bram »
Aha, yes. that is part of the game in order to spend it again on cars. Work! :horse:
chapel
Post by chapel »
updates!
no updates because there haven't been any. right now the car is in the garage, nicely detailed by germantoy and hasn't left the bay since! Part of the problem is I'm also using the car for some bench testing on a few customer projects...
chapel
Post by chapel »
that why you bought that blue B5?
chapel wrote:that why you bought that blue B5?
I bought the blue b5 because I have a disease for which there is no cure (not even more cowbell).
chapel
Post by chapel »
yeah, and the B5 S4 is the AIDS of that disease.
you planning on doing anything to it or just DDing it?
cuatrokoop
Post by cuatrokoop »
Hopefully for Marc he just DD's it!
