Eric's '90 80QT: rustic bits
ur20v
Re: Eric's '90 80QT-to-be: driveshaft & engine mounting issu
Post by ur20v »
You seem to have a surplus of shaft length... Bet you never thought *THAT* would ever be an issue, hmm?
savagerocco
Post by savagerocco »
oh snap....
elaw
Post by elaw »
ur20v wrote:You seem to have a surplus of shaft length... Bet you never thought *THAT* would ever be an issue, hmm?
I'm not touching that one with a ten-foot... uh... oh never mind! :D
Eric Law
elaw
Post by elaw »
Oh, and the problem with the one in the car isn't its length, it's that it's crooked! :lol:
Eric Law
elaw
Re: Eric's '90 80QT-to-be: driveshaft success!
Post by elaw »
Well today things are going a little better than before... I got the driveshaft aligned!
Everything I read on the 'net and the illustration in the Bentley implies that it's supposed to be straight in the horizontal plane so that's what I shot for. And I aligned it "the right way"... with a frickin' laser beam!
:D
Eric Law
savagerocco
Did you have your "Quote" fingers up when you said Laser beam?
Did you end up needing to move the engine & trans placement?
elaw
Post by elaw »
savagerocco wrote:Did you have your "Quote" fingers up when you said Laser beam?
I'm not tellin'! :P
Eric Law
elaw
Post by elaw »
DE80q wrote:Did you end up needing to move the engine & trans placement?
Yeah, if you compare that photo to the one I posted earlier, the rear of the tranny is a bit farther toward the driver's side.
That, and a little cutting and filing on the bearing bracket to allow it to move toward the passenger's side a bit did the trick.
Eric Law
Post by AudiSport4000 »
Nice!
Was a shark with a fricken laser beam attached to its head used?
elaw
Post by elaw »
Nah... have you ever tried doing it that way? For one thing, your larger sharks won't even fit under the car when it's up on stands. If you do manage to get them into position, all they do is flop around. Plus, feeding them will cost you an arm and a leg! :P
Eric Law
elaw wrote:Plus, feeding them will cost you an arm and a leg! :P
:lol:
savagerocco
Its amazing that we get anything done we are such a silly bunch of goons...
elaw
Post by elaw »
:D
Eric Law
LOL!
Thats awesome :D
Nice!
ur20v
Post by ur20v »
savagerocco wrote:Its amazing that we get anything done we are such a silly bunch of goons...
Speak for yourself! I don't even have a job and I don't get shit done :D
elaw
Re: Eric's '90 80QT-to-be: oil cooler AN fittings?
Post by elaw »
Okay, enough about sharks... and driveshafts! :P
Can someone answer a hopefully-easy question for me? Suppose I want to switch to AN fittings and hose for my oil cooler (which came from a UrS6). I know 034 has adapters for the engine end... what do I use on the cooler end of the hoses? I didn't see anything on 034's site that looked appropriate.
Eric Law
my2000apb DrBeastCar
Post by my2000apb DrBeastCar »
jstu get an aftermartker AN in/out cooler!
they are 18 x 1.5mm off the oil filter housing
my2000apb wrote:jstu get an aftermartker AN in/out cooler!
:thumbsup: for good info I needed too. :)
if you really wnat to go use the stock oil cooler id bet they are the same for in/out on the cooler
savagerocco
I kept the fittings and got the hoses made, the AN fittings drop the flow down quite a bit. The hose fittings are kinda spendy though
elaw
Post by elaw »
I was wondering about that - the hoses on the Audi cooler seem quite large compared to the few others I've seen. I think the oil coolers on most Saabs use 3/8" ID hose, the Audi ones are closer to 5/8". Although -10AN hose is supposed to be 5/8" ID also, so in theory it shouldn't restrict that much?
I had actually tried to mod some of the OE Audi lines - I tried to cut the metal tube part shorter and braze it back together but I couldn't get the brazing filler to stick. I was pretty surprised - I've brazed a lot of different types of steel and stainless before with no problem, but had no luck whatsoever with those lines.
Eric Law
certain brands of fitting have more flow restriction than others, earls and aeroquip stuff is very nice, some summit and jegs branded stuff necks down smaller
elaw
Post by elaw »
To change the subject yet again... I don't suppose anyone here has a CQ or 90 20V A/C accumulator they'd let go for free/cheap?
I can get a new one for ~$30.00, but I'm not ready to close up the A/C system yet so a new unit would probably get ruined. I'm really just looking for something to throw in there so I can check clearances.
Note this is *not* the same accumulator as on the 20v cars! Those have the in/out on opposite sides, the 20V ones have the fittings next to each other as shown above.
Eric Law
