Hanks URQ 2.6L Autopsy
Re: Hanks 81 URQ Dyno 612whp 527wtq
this is the unit im planning on running in my cqvr build
http://www.pegasusautoracing.com/produc ... RecID=5741
RSCoupe
Just bit the bullet and by the AiM MXL.
haenszel
ShavedQuattro wrote:Yeah, and the problem of only having a 7500 rpm tach still exists. I need a 0-9000 scale that is fast. I really like the ProSport gauges, and the tach and speedometer that they offer. The tach would be a cinch to wire up, but the Speedometer wants a signal from the ECU to drive it. What the hell does that mean??
I wish I was smarter with electronics so I could figure out how to get a speedometer in my life.
Most ecu's you can input speed via an HSI into the ecu, then using gear/speed tables it will figure out your speed and you can then use an output on the ECU to trigger an electronic speedo. Or if the frequencies are the same you can run a pull up on the VSS to trigger the speedo, but if its an aftermarket speedo my guess is this woudln't work out quite right.
Tim, that tach is sick, but at 450$, I would double up the cost and take Mark's advice. I do like the small footprint though.
I need to keep my eye out for a used AiM dash. Nate had one for me form the 90, but he couldn't help himself when the a3 was taken into the stable.
Brian, That is good information. So the ProSport would not be able to be driven off just the 01e input off the 2 wire hall sensor is what your gut says? It would be awesome if I could output the Speed tables off the IIc into the Speedo!!
a_CQ
Hank, any GPS will tell you your speed...
Or do as Mark says...you can alway sopt for a cheaper MyChron dash by AiM. Configurable RPMs, CAN input and you can read a lot of sensors' data too.
Tim, this place has them for a hundred cheaper at 374. That makes it an attractive alternative to the other gauges I have looked at. Ideally, I want Tach, speedo, Water, Oil Pressure, Fuel pressure, AFR and Boost in the main cluster. That isn't too much to ask for right
http://www.proracestore.com/index.php?m ... ceid=GPPRS
It is true Peter. I don't need a lot of the logging that is included with the higher end AiM stuff. I'll go waste an hour looking at them.. brb
haenszel
ShavedQuattro wrote:Brian, That is good information. So the ProSport would not be able to be driven off just the 01e input off the 2 wire hall sensor is what your gut says? It would be awesome if I could output the Speed tables off the IIc into the Speedo!!
It might work just fine. I believe aaron has his stock sensor running a speedo(or maybe just to his ecu). Mine is wired up like stock to the cluster(b5) but then pull-up'd to the ecu. He has a diagram for how to wire it, I remember seeing his MS paint skills when i was doing my wiring.
- speeding-g60
mine only runs the ECU for VSS.
you want said mad Paint SKILLZ YO?????
The SPA tach/speedo is sweet. I found them for 350 new, but I really wish they had an odometer. I long to track gas mileage for some retarded reason.
FYI, the rev limiter is set at 4000. One mandatory court date down today, 2 to go. Red is a biatch.
dwalmop
ShavedQuattro wrote:FYI, the rev limiter is set at 4000. One mandatory court date down today, 2 to go. Red is a biatch.
Uh-oh!
:eek:
That sucks! Does MMP have a season pass?
Triple digits?
Trade ya my stealthy white one :wink:
No Triple digits or Reckless drivings. Just some bad breaks. Driving style has not changed... Never had a ticket in white.
BlackBox
Hi Hank, I may be able to help with the custom electronics for your tachometer issue. Contact me some time and we can discuss it.
bimmerboy
Weren't you complaining about how your car never got any attention from cops?? Ahhh how I love avants
- speeding-g60
its that flashy red, amongst other things
Does anybody know the resistance range of the gas sender on the URQ or 4kq?
Easy enough to check, you dont have a tank sitting around?
- ralleyquattro
Hank,
Bentley's gauge procedure shows it as 40 Ohms at full and 283 Ohms at empty.
HTH
HTH
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
91 Coupe Quattro
nismo
bimmerboy wrote:ShavedQuattro wrote:FYI, the rev limiter is set at 4000. One mandatory court date down today, 2 to go. Red is a biatch.
Silver Buick Regal FTW!
Eric
I would rather get tickets than drive a silver buick.
- speeding-g60
until you cant drive anymore, whereas with the granny car you'd still be drivin.
rather drive a silver Buick (Grand National) LOL.
chapel
Hank, 1552 can now source those compomotive mo1690
nismo
ShavedQuattro wrote:I would rather get tickets than drive a silver buick.![]()
Didn't have the money to keep my Audi...had to have a cheap/easy to maintain car, so I decided on the 3800 motor, and this was the absolute best choice for me. At least its quick! It would mop the floor with my CQ, manages better mileage, has more power, and can comfortably haul 4 people.
My mileage money is paying for it, so hopefully my wife will get a job soon and I can get a toy. I'd love to have an UrQ (I hate red though
)!Eric
