amd is the best wrote:Before you get all worked up, this was the modified one and hank now has a better way to shorten them
Did it shear at the point where it was welded after shortening? Looks like some kink too.
Custom chromoly axles soon?
AngryTaco wrote:why are you going the 300 shot of nitrous route now with the reduced boost?
scubagli wrote:But it's got no power under the curve...
vt10vt wrote:Watching the tach at the beginning of that pull is awesome.
Is that the tilton making the clicks when you shift or a linkage/01E noies? In watching the video it looks related to the movement of your left leg.
loxxrider wrote:Sounded like wheelspin. That's awesome
dana wrote:i was thinking I heard wheelspin at first too![]()
that thing is flying. Awesome. Are you coming to Wolfgart next weekend?
dana wrote:i've actually only been the first year, but its gotten pretty big and they had a dyno in years past. Not sure if they will or not this year. I will see if I can find out. Your car would be a mega crowd pleaser on the dyno for sure. There is a big party saturday night, plus burlington nightlife.
http://wolfsgart.com/
EDIGREG wrote:looks to be spooling about the same as it was on the dyno (in 2nd gear in the vid). When are you hitting 34psi in 4th?
How do you like that clutch? Curious how modular (or NOT at all) it is.
mushasho wrote:Similar to the hot start issue I had up in your neck of the woods at the gas station...
