Page 65 of 82
Posted: Fri May 09, 2014 8:14 am
by 20VAvant
Posted: Fri May 09, 2014 8:52 am
It needs (bigger) turbo! The Avant that is.
Posted: Fri May 09, 2014 9:54 am
by amd is the best
loxxrider wrote:It needs (bigger) turbo! The Avant that is.
Ehhhhhh, maybe someday, lol. Just a chip would be nice for now.
Posted: Fri May 09, 2014 10:27 am
by themagellan
Could be a blessing in disguise, this will give you the time to give it a proper break in triple check everything. There is a lot of coin in this build always good to do things with enough time.
Hope you at least cranked the avant's waste gate down
Posted: Fri May 09, 2014 4:56 pm
by amd is the best
themagellan wrote:Could be a blessing in disguise, this will give you the time to give it a proper break in triple check everything. There is a lot of coin in this build always good to do things with enough time.
I agree. I hate to rush things and it was just too close. Avant is at stock boost. Cranking the WG spring would only make it hit overboost right?
Posted: Fri May 09, 2014 5:00 pm
Sweet, one more fast car knocked off the list, looking good fit the 4k. LOL.
Do it right, you know how/why.
Posted: Fri May 09, 2014 6:07 pm
by vt10vt
amd is the best wrote:themagellan wrote:Could be a blessing in disguise, this will give you the time to give it a proper break in triple check everything. There is a lot of coin in this build always good to do things with enough time.
You can crank it down until you hit overboost and then back it off just a bit. It would net you a few psi and at least make the trip down a little more fun!
Sent from my SCH-I535 using Tapatalk
Posted: Tue May 13, 2014 11:01 am
by Dave
Posted: Tue May 13, 2014 1:43 pm
Whoa, those are sweet.
Posted: Tue May 13, 2014 3:03 pm
by EDIGREG
loxxrider wrote:Whoa, those are rice.
There, I fixed it
Posted: Tue May 13, 2014 4:33 pm
by glibobbo21
Posted: Tue May 13, 2014 9:45 pm
by Dutchbroracer
Not a fan of the carbon fiber look. Though I must ask...Are those real or wrapped?
Posted: Tue May 13, 2014 10:23 pm
CF touches aren't rice if they're a feather in the cap on a completed build... if all you have is a 4" exhaust tip and some neon lights and a CF hood or something... then yeah, rice. Otherwise, CF because racecar.
Posted: Wed May 14, 2014 8:05 am
by EDIGREG
PRY4SNO wrote:CF touches aren't rice if they're a feather in the cap on a completed build... if all you have is a 4" exhaust tip and some neon lights and a CF hood or something... then yeah, rice. Otherwise, CF because racecar.
Yeah, but putting it in unnecessary places also makes it ricey in my opinion. CF door trim....really?
It's nice for aesthetic purposes in interiors & engine bays, IF NOT OVERDONE. And obviously it's great for weight savings on panels/etc.
Posted: Wed May 14, 2014 12:19 pm
by amd is the best
Posted: Wed May 14, 2014 12:50 pm
by themagellan
Ugh so jealous, everything looks like it was made to fit. lol….
Posted: Wed May 14, 2014 1:46 pm
by EDIGREG
lookin good dude
Posted: Wed May 14, 2014 2:54 pm
by Clem86
Posted: Wed May 14, 2014 2:55 pm
Looks the business.
Any reason you opted for OEM CP's instead of LS2? No worries about heat?
One other thing (I can't help myself)... looks like it's time for a CF TB cover
Posted: Wed May 14, 2014 3:34 pm
by amd is the best
Clem86 wrote::drool:
It's a RS2 exhaust manifold ?
Wagner Engineering Sport Quattro Evo.
PRY4SNO wrote:Looks the business.
Thanks! I ran LS2 coils for years and never had a problem until some strage misfire issues arose and couldn't be traced. After replacing every component, still no fix. Also tested my coils and harness on another car and they worked flawlessly. As a last ditch effort I tried the R8 coils and they worked perfectly. They also look nicer and cost under $20 to replace if they fail (which hasn't happened yet).
The CF timing cover would be sweet however I don't believe they make a 3B one that clears an aftermarket pulley. And there's no way I'm going to try cutting one up.
Posted: Wed May 14, 2014 5:19 pm
Pretty sure there's one for the adjustable on the 3b... I could be wrong.
Posted: Thu May 22, 2014 6:33 am
by amd is the best
[youtube]http://www.youtube.com/watch?v=CriQCG2Jcao[/youtube]
Posted: Thu May 22, 2014 6:39 am
by dana
sounds amazing.
Posted: Thu May 22, 2014 6:56 am
by EDIGREG
Yesssssssssssssss
Your passenger was pretty excited about 5psi or whatever that was
No launch control break in procedure?
Posted: Thu May 22, 2014 8:48 am
by themagellan
I honestly have no words, I am just proud to see this.
